Joined Jan 2005
Hi all,
I see in the recent bulletin that you need national identification mark on models. But when I read FAI ABR page 50 § b.17.6 : http://www.fai.org/component/phocado...94:sc4volabr12 it's written "except for indoor and scale model aircraft. So I don't understand if our light models will have some big and heavy stickers on them. Loic |
We usually print them on clear label stock(Fascal) in a laser printer. Here is an example in a pdf, 1:1 scale. IIRC the original was downloaded from the FAI web site. In addition to the sticker you need your national ID number somewhere on the model, but that can simply be drawn on with magic marker. Typically in processing they will apply another small sticker partly over yours as proof that the model has been processed. I have also seen them use ink stamps or initial them. Pat MacKenzie |
Latest blog entry: er9x heli 450 heli set up (flybar)
you are looking the 2012 Edition of the Sporting Code. Obviously there will be some changes in the 2013 version: Quote:
Jürgen
Latest blog entry: 12th. German- / 1st. European Indoor...
a sticker of 65x34mm made from Fascal will weigh approx. 0.24g. While this is completely negligible for an F3A or F3B model, it is quite a lot considering the efforts F3P pilots go through in order to reduce the weight of their models. Jürgen
We worry a bit about weight in F3K
![]() I just weighed a 24cm x 7cm piece of Fascal and it was 1 gram. So this sticker at ~ 2.4 x 4 cm weighs less than .1 gram. If that still worries you, you could always cut the foam away underneath it, might end up lighter ![]() Note in the rule it says "or marking to the pattern of the sticker", so a reduced scale or even a hand drawn version is acceptable. Hopefully those doing the processing will understand the goal: to ensure compliance with relevant rules regarding safety, model eligibility, etc. If they start measuring the size of FAI stickers then they have lost sight of what their job is. ![]() The other funny part about the rule is the section about models being pre-processed by their NAC. I can guarantee you that this part is never followed. Unless you live in Luxembourg and can drive across town to get your model inspected geography precludes it. Instead model specification books are generally pre-stamped, then filled out by the competitor. Often in line at processing.![]() Since the rules for F3P models are pretty short there won't be much to fill out in the book anyway. Pat MacKenzie |
Joined Nov 2010
Cargovan Truckrental
Hallo Janne,
as already mentioned above: all these companies have transporter available. The only problem: not at the airport. If you give them a call by phone they have more detailed information. As i have been told by phone a ford transit (9 seats) or mercedes vito is available at budget (but not listed at the internet). If you choose another location of the rental company at Frankfurt (not at the airport) they offer trucks up to 12 tons. These trucks have not too much seats for passengers ... so an additional car might be needed for the people.
The same vice versa at leaving. Sorry not the easiest way but your needs are also not very common for an airport rental station where usually people arrive with less than 20kg luggage in a view bags. If you or anybody else from a different country needs more support please send me an e-mail to f3p@indoor-rc.de and tell me your exact needs: which car, how many persons, additional car needed,... and we will try to find an arrangement. So good luck. Best regards, Karl-Ernst |
Joined Oct 2008
it seems there are 2 websites ?
what's the official website ? www.indoor-rc.de www.indoorwm.de I guess the second one ? |
| Thread Tools | |
| Gallery First pictures from nuremberg toyfair 2012 in germany | guyro | Electric Heli Talk | 15 | Feb 06, 2012 08:53 PM |
| Gallery First pictures from nuremberg toyfair 2012 in germany | guyro | Fuel Heli Talk | 3 | Feb 06, 2012 07:51 AM |
| Discussion My first F3P plane. Any reccomendations? | tele1974 | Indoor Pattern/F3P | 42 | Dec 23, 2011 09:36 AM |
| Discussion First F3P competition in Slovenia | alan_g | Indoor Pattern/F3P | 7 | Dec 14, 2011 06:05 AM |
| Discussion First Multicopter Flight School in Germany / Berlin - Open NOW - | Rc Heli Halle | Multirotor Talk | 0 | Sep 09, 2011 09:09 AM |
