This thread is privately moderated by icharus, who may elect to delete unwanted replies.
Old Apr 26, 2012, 10:25 PM
icharus is offline
Find More Posts by icharus
Trader Rating: 98
Better than golf
icharus's Avatar
United States, CA, Irvine
Joined May 2008
Trader Rating: 98
Wanted
Wanted Topaz Center section with flaps and right wing with ailerons
Wanted Topaz Wing Parts.
There are 2 versions I need the center section with flaps and the wings with ailerons.
Before I start repairing the damaged wings Ill see if anyone out there has one ??
Looking for the center section any color and right wing any color any condition.
Thanks Louis.
icharus is offline Find More Posts by icharus
Last edited by icharus; Apr 30, 2012 at 10:10 AM. Reason: http://www.rcgroups.com/forums/editpost.php?do=updatepost&postid=21447786
Old Apr 27, 2012, 06:56 AM
eissman is offline
Find More Posts by eissman
Trader Rating: 4
Joined Apr 2007
Trader Rating: 4
Don't know if it'll work or not, I've never seen a Topaz, but I have an excellent uncovered center panel off an Ava Mini, (100" Ava).
I bought the wreckage for the fuselage. Except for the covering and 1 or 2 carbon caps,the center panel was fine. It has a JR digital 285 on the spoiler.
dimensions are as follows
Span - 32 1/2"
Chord at ends 9 1/16"
8x12 mm joiner box - 2" from leading edge to front of box.
The left tip panel is probably rebuildable, but the right was toast.
eissman is offline Find More Posts by eissman
Old Apr 27, 2012, 07:09 AM
allanp is offline
Find More Posts by allanp
Trader Rating: 24
AECS USN RET. P3 FE
allanp's Avatar
USA, FL, Winter Springs
Joined Mar 2004
Trader Rating: 24
Good luck finding one !! I've been looking for a year.
Repairing the wing is pretty straight forward until you get to the TE,it's really difficult to try and keep "true"
allanp is offline Find More Posts by allanp
Old Apr 27, 2012, 08:52 AM
HaoleboyRC is offline
Find More Posts by HaoleboyRC
Trader Rating: 17
HaoleboyRC
HaoleboyRC's Avatar
United States, CA, Auberry
Joined Apr 2009
Trader Rating: 17
Topaz center panel
I am in the same boat and when I did find a repairable right wing tip the joiner was canted off forward. There seem to be so many different variations that I quit looking. Good luck with your search. I decided to build a bubble dancer wing or tips to use with what I have.
HaoleboyRC
HaoleboyRC is offline Find More Posts by HaoleboyRC
Old Apr 27, 2012, 09:09 AM
icharus is offline
Trader Rating: 98
Better than golf
icharus's Avatar
Joined May 2008
Trader Rating: 98
MMMMMMM Looks glum out there looks like I might have to repair mine ;-(
Louis.
Old Apr 27, 2012, 09:34 AM
soprano1 is offline
Find More Posts by soprano1
Trader Rating: 2
RES flyer
Portland, OR
Joined Feb 2009
Trader Rating: 2
I have a pair or red tips available
soprano1 is offline Find More Posts by soprano1
Old Apr 27, 2012, 12:38 PM
icharus is offline
Trader Rating: 98
Better than golf
icharus's Avatar
Joined May 2008
Trader Rating: 98
Thanks soprano now to find a center section.
Louis.
Old Apr 27, 2012, 01:42 PM
jcstalls is offline
Find More Posts by jcstalls
Trader Rating: 398
Dragons, WindMills, all Same
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
Trader Rating: 398
Center sections can be tough to get sans newest and most popular models.
How bad is you Center Section and could it be repaired by someone in your area?
jcstalls is offline Find More Posts by jcstalls
Old Apr 27, 2012, 02:06 PM
icharus is offline
Trader Rating: 98
Better than golf
icharus's Avatar
Joined May 2008
Trader Rating: 98
Problem is I purchased this Topaz damaged and it was already repaired by a novice its wrong and ugly, I will repair it correctly if I have to its just tough undoing all the bad work and then do the repair.
Hoping someone might have a better one even if its damaged but untouched ???
Louis.
Old Apr 27, 2012, 02:52 PM
allanp is offline
Trader Rating: 24
AECS USN RET. P3 FE
allanp's Avatar
Joined Mar 2004
Trader Rating: 24
I've been toying with the idea of just bagging a center section,only problem I'm trying to work through is where to get a rectangular spar/joiner box.I haven't been deep enough into the "D" box to see if the original can be removed/cleaned up/and used in a foam core
Old Apr 27, 2012, 04:25 PM
icharus is offline
Trader Rating: 98
Better than golf
icharus's Avatar
Joined May 2008
Trader Rating: 98
Interesting Idea Not sure myself.
Louis.
Wanted Supra Center Wing Section tim_j58 Aircraft - Sailplanes (FS/W) 2 Sep 26, 2011 09:26 PM
Wanted Topaz Wing Ctr section 1st gen undamaged allanp Aircraft - Sailplanes (FS/W) 0 Sep 10, 2011 11:45 AM
Wanted Topaz center wing section. icharus Aircraft - Sailplanes (FS/W) 0 May 26, 2010 06:08 PM
Wanted Center section for Topaz wing new or used. icharus Aircraft - Sailplanes (FS/W) 2 Mar 13, 2010 09:36 PM
Wanted Looking for Center Section for a Topaz Wing icharus Aircraft - Sailplanes (FS/W) 0 Mar 10, 2010 06:45 AM
