Old May 19, 2012, 12:33 AM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
Originally Posted by bdelapen View Post
The CC 10A BEC is good to 6 cells, if you plan to run more you will need to get the 20A BEC Pro. Or you could most probably just run a LiFe pack as a receiver pack and do away with the BEC altogether.
- Birger
just to be clear the castle 10amp bec is 7.5amp continuous 10amp burst when hooked up to4s or less cells, on 6s voltage its 5amps
jcdfrd is offline Find More Posts by jcdfrd
Old May 19, 2012, 01:28 AM
vasek is offline
Find More Posts by vasek
Joined Nov 2003
Is someone using Jetfan with the stock motor? is it a good combo?
vasek is offline Find More Posts by vasek
Old May 19, 2012, 02:21 AM
ons_pk is offline
Find More Posts by ons_pk
Bristol, Great Britain (UK)
Originally Posted by bmiller View Post
I'm using 82s as well. I had to elongate one slot slightly to get full throw without binding
I have the same issue. The servo arm donot touch the slot ends but at full flaps I have lot of chatter from both servos, my full flap is 25mm with 130% atv. I am using Hs81mg.
Should I put longer servo arms..?
I think the geometry of the flap horn and servo arm.
Any Recommendations.?
ons_pk is offline Find More Posts by ons_pk
Old May 19, 2012, 04:50 AM
bmiller is offline
Find More Posts by bmiller
SoCal, Year Round Flying!
bmiller's Avatar
Newport Beach, CA
Joined May 2002
The manual listed 13mm for distance of control horn hole to center of flap servo.
Thats what I used.
Set your radio to full flaps down postion, then reposition the servo horn on the servo to the best angle that gets max travel without binding. Then adjust rod to get 30mm down flap.
Hope this helps...
PS, I did have to elongate one slot slightly (1/8)to prevent binding.
In my neck of the woods, HS81s are known to buzz alot, their centering is not the greatest but it's only an annoyance not a problem and the price is right!
bmiller is offline Find More Posts by bmiller
Old May 19, 2012, 05:37 AM
Bob Hunt is offline
Find More Posts by Bob Hunt
Mustang Fever
Joined Jan 2005
I'll second that- all the HiTec HS 80 series MG servos are buzzers. You get used to it after awhile.
Bob Hunt is offline Find More Posts by Bob Hunt
Old May 19, 2012, 07:13 AM
bdelapen is offline
Find More Posts by bdelapen
Sponsored by Team de la Peņa
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
Thanks, I didn't have the actual numbers at my fingertips but it's good to know the actual amps! I was just ensuring that no one tried to run it above 6 cells because that would be bad . At 5A then, for both the F-4 and Habu, it's probably not a great idea; even at 6S . So short version, use only the CC BEC Pro .
- Birger
bdelapen is offline Find More Posts by bdelapen
Old May 19, 2012, 09:55 AM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
My 3rd F-4 is coming tomorrow. Just need the wings to finish my second I got from James.
Since I did some number test with my TJ80 and notice the stock exit exhaust is way over 120% FSA. I goes tune it down correct FSA exhaust to bring the efflux velocity back up. Once got right size. I goes to flash the stock exhaust to made the plug for TJ80 set up.
Tamjets is offline Find More Posts by Tamjets
Old May 19, 2012, 12:16 PM
smaze17 is offline
Find More Posts by smaze17
smaze17's Avatar
Joined Dec 2009
Originally Posted by Tamjets View Post
Those are Hangar 9 Lite wheel 1.5".
The main wheel you need 2" Lite Du-Bro.
Thanks Tam!
S
smaze17 is offline Find More Posts by smaze17
Old May 19, 2012, 04:45 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Update of mod ducting to choke down the exhaust tube.
I use mixing cup to make the choke down nozzle.
I use the mylar to connect the fan to the bifurcated exhaust. The stock exhaust it had too much choke down right after the fan. That work work with 36mm-39mm motor housing.
Old May 19, 2012, 07:04 PM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Tam you really now how to keep sales going strong!
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old May 19, 2012, 09:02 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
I took this picture of Bruce's F-4 today ... video later, going out for dinner ...
E-flite F-4 Phantom EDF 80mm (2 min 8 sec)
Herb is offline Find More Posts by Herb
Old May 19, 2012, 10:06 PM
Qcsteve is offline
Find More Posts by Qcsteve
United States, IL, Moline
Joined Sep 2006
The stock esc is only a 5amp BEC, so why would you have to move up to aBEC PRO? I'm only going to use 6s.
Qcsteve is offline Find More Posts by Qcsteve
Old May 19, 2012, 10:16 PM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Remaidened w/ 6S, had some weird control problems. it wanted to turn right pretty hard right after liftoff then it flew straight with no trim needed.
Did a tighter turn and it went straight up into a stall but I got it straightened out, Decided to land, put the gear down and flew a big circle to a nice landing. Looked it over, nothing loose, cg 6 1/4, can't see anything wrong so went for 2nd flight.
2nd flight 7S cg 6 1/8, nice power increase, airborne quickly, again it wanted to turn right then flew straight. Went for a tight turn to do a speed pass and it again went straight up into a stall. This time it did not recover....
Old May 19, 2012, 10:20 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Bruce you should have come to la jets toady .
AIR SALLY is online now Find More Posts by AIR SALLY
Old May 19, 2012, 10:40 PM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Didn't know it was happening this weekend!
You going tomorrow too?
Build Log Fly-Fly F-4 Phantom: BUILD CRCJA Foamy EDFs 2120 Dec 13, 2015 10:54 AM
Sold Master Fly F-4 Phantom II 1/7 scale 99"lenth 65"w dhf23 Aircraft - Electric - Jets (FS/W) 9 Dec 29, 2011 09:43 PM
Alert E-Flite F-4 Phantom 32 DF ChuckTseeker Electric Plane Talk 17 Sep 09, 2011 12:54 AM
Discussion Starmax F-4 Phantom 90mm Build Thread neversommer Foamy EDFs 31 Jan 12, 2011 03:56 AM
Anyone build/fly AERC F-4 Phantom War Bird Radio Parkflyers 3 May 11, 2003 06:19 PM
