Old May 18, 2012, 01:41 PM
stvinvegas is offline
Find More Posts by stvinvegas
stvinvegas's Avatar
United States, NV, Las Vegas
Joined Dec 2006
Originally Posted by 420flyboy View Post
Same place
Originally Posted by whmc View Post
I measured at LE, per David Payne. whmc
Awesome... thanks Boys!!!
stvinvegas is offline Find More Posts by stvinvegas
Old May 18, 2012, 03:19 PM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Originally Posted by vasek View Post
Looks like a close call in anycase I'm going for MGs just to make sure
That could be over flare when is too nose heavy.
With correct C.G 6 3/8" and 5/32"- 3/16" up elevator mix with full flap on landing.
Is so easy to land and not much flare needed.
If follow the C.G in the manual. You guys will had hard time landing. It so nose heavy and you had to hold too much elevator. As soon you touch the main. It slap down the nose and that start to bounce. You in for a ride.
BTW,
Friend of my just call me.
He found 2 kits sit on the shelf from the Hobby Shop somewhere he goes for vacation.
He bought them both and one goes to me.
So far I get kits not from my order. But from friends and groups.
Tamjets is offline Find More Posts by Tamjets
Old May 18, 2012, 04:09 PM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Tam, You must be a Navy Pilot,,, slamming it on the deck.
capt soap is offline Find More Posts by capt soap
Old May 18, 2012, 04:11 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Never join the Navy....but love green bottles.
So the day without drinking my green bottles.
That the day I do bad landing.
I fly better when hanging loose.
Old May 18, 2012, 04:59 PM
carguy1994ca is online now
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
Lol !
carguy1994ca is online now Find More Posts by carguy1994ca
Old May 18, 2012, 06:37 PM
hypstar is offline
Find More Posts by hypstar
hypstar's Avatar
Sweden
Joined Sep 2008
The less "nerdy" version would be this
yepp..you`r right,I have them in black, but they looks better on the wingtips.
those cf is nice,but they are not here...for easy fix,better with small glassfibertape strips on the stabtips, for protection on the maiden and first flights...
hypstar is offline Find More Posts by hypstar
Old May 18, 2012, 06:52 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Now I got my F-4 P-20 turbine all dial in.
I think started on the other fuse with TJ80.
Old May 18, 2012, 09:04 PM
Qcsteve is offline
Find More Posts by Qcsteve
United States, IL, Moline
Joined Sep 2006
Quick question on the fanjet80 setup. Going to be running an Arc/jf80/CC Phoenix HV 120 6c esc. I bought a CC 10 amp bec because there is no bec built into the esc. Is this the correct setup?
Qcsteve is offline Find More Posts by Qcsteve
Old May 18, 2012, 09:18 PM
420flyboy is offline
Find More Posts by 420flyboy
Mile High EDF
420flyboy's Avatar
United States, CO, Denver
Joined Jul 2011
That will work,
I have jetfan80 with arc and castle 100 , I disable the bec and use a 1100 mah life 2s, plugs direct into reciever .
420flyboy is offline Find More Posts by 420flyboy
Old May 18, 2012, 10:10 PM
smaze17 is offline
Find More Posts by smaze17
smaze17's Avatar
Joined Dec 2009
Tam, what size are the little Du-Bro wheels for the nose?
S
smaze17 is offline Find More Posts by smaze17
Old May 18, 2012, 11:34 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
S
Those are Hangar 9 Lite wheel 1.5".
The main wheel you need 2" Lite Du-Bro.
Old May 18, 2012, 11:49 PM
bdelapen is offline
Find More Posts by bdelapen
Sponsored by Team de la Peņa
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
The CC 10A BEC is good to 6 cells, if you plan to run more you will need to get the 20A BEC Pro. Or you could most probably just run a LiFe pack as a receiver pack and do away with the BEC altogether.
- Birger
bdelapen is offline Find More Posts by bdelapen
Old May 18, 2012, 11:50 PM
bmiller is offline
Find More Posts by bmiller
SoCal, Year Round Flying!
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Decided to replace my weak moving weird sounding front retract before I remaiden her tomorrow. So I bought another set of eflite 15-25s, huge difference, glad I did it.
Worked on CG using 7S 5000s, was able to get as far back as 6.5 inches!
Anybody know what the default setting is on CCproBECs? Can I just plug it in and forget about it or do I really need to program it with the CC link?
bmiller is offline Find More Posts by bmiller
Old May 18, 2012, 11:59 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
5.5v i think
Old May 19, 2012, 12:33 AM
bmiller is offline
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Good enough for me Tam. Thanks!
The "included" 2 wire jumper was not included!
Build Log Fly-Fly F-4 Phantom: BUILD CRCJA Foamy EDFs 2128 Jun 21, 2016 02:55 AM
Sold Master Fly F-4 Phantom II 1/7 scale 99"lenth 65"w dhf23 Aircraft - Electric - Jets (FS/W) 9 Dec 29, 2011 09:43 PM
Alert E-Flite F-4 Phantom 32 DF ChuckTseeker Electric Plane Talk 17 Sep 09, 2011 12:54 AM
Discussion Starmax F-4 Phantom 90mm Build Thread neversommer Foamy EDFs 31 Jan 12, 2011 03:56 AM
Anyone build/fly AERC F-4 Phantom War Bird Radio Parkflyers 3 May 11, 2003 06:19 PM
