Old May 14, 2012, 05:45 PM
420flyboy is offline
Find More Posts by 420flyboy
Mile High EDF
420flyboy's Avatar
United States, CO, Denver
Joined Jul 2011
Anytime
Just headed out for more flying , put the keychain cam on top.
Nice part of that setup is you can keep flying your 6s packs.
420flyboy is offline Find More Posts by 420flyboy
Old May 14, 2012, 06:59 PM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
Back 2 more flights
Esc is just cooking , doesn't like tooling around at half throttle. Graph shows temperature dip when full power applied.
2300 watts
102.7 amps
250 F. Temp
The stock placement for esc is not good , no air flow, I took off the plastic around the castle esc just to get better flow , didn't help.
Old May 14, 2012, 07:10 PM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Originally Posted by 420flyboy View Post
Back 2 more flights
2300 watts
102.7 amps
250 F. Temp
Sorry to hear that James.
Made the mod had ESC behide the motor.
That fix all the over heat problem.
John and Nick over the weeken pushing the Habu 32 over 200mph downwind.
They send me the data log.
The max temp only reach 194F....this is double the power you are using and heat sink are remove from ICE HV120 to kept it light.
Tamjets is offline Find More Posts by Tamjets
Old May 14, 2012, 07:13 PM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
Tam, I need a 36mm heatsink with carbon tail for my jetfan and arc 36-65-1 , then I'll move my esc .
Old May 14, 2012, 07:14 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Get the TJ80 shroud..that fix the problem.
Old May 14, 2012, 07:17 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Bruce flew his yesterday ... stock fan on 6S. Flew well but it was a short flight
Herb is offline Find More Posts by Herb
Old May 14, 2012, 07:41 PM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
fixed, took the heatsink off the esc and then stuffed it between the ducts, very nice fit and doesn't weigh anything now then ran it up in the garage , looked at castle data and
Old May 14, 2012, 08:36 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Air cooling from sucking and blowing it work out great.
You don't need that heat sink at all.
That why ran all my without heat sink to save weight and still stay cool at full power.
Old May 14, 2012, 08:40 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
It is very draggy airframe and you had to be on the throttle most of the flight with stock set up.
I like little more power set up than stock.
P-20 is great because I fly with 80-100% power the whole flight and it get better when I burn off the fuel.
P-20 is about 2700 watts power compare to EDF.
Old May 14, 2012, 09:05 PM
stvinvegas is offline
Find More Posts by stvinvegas
stvinvegas's Avatar
United States, NV, Las Vegas
Joined Dec 2006
Can you post a pic if you get a chance
stvinvegas is offline Find More Posts by stvinvegas
Old May 14, 2012, 09:17 PM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
pics of the esc ,
Old May 14, 2012, 10:27 PM
stvinvegas's Avatar
Joined Dec 2006
Thanks 420! I don't get how it gets more air there though, the intakes are sealed. I did it on my Habu and will do it on my F4, I just dont get it.
Old May 14, 2012, 10:31 PM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
The intake isn't sealed , there is a small gap and I can see my spinner , pulls in air nicely . Dropped temp from over 250F to 129F.
Old May 14, 2012, 10:36 PM
Aaron Wallace is offline
Find More Posts by Aaron Wallace
Aaron Wallace's Avatar
San Diego
Joined Oct 2006
So, just being next to the ducting walls with the airflow through the ducting is enough to cool the ESC? Cool...pun intended.
Aaron
Aaron Wallace is offline Find More Posts by Aaron Wallace
Old May 14, 2012, 10:40 PM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
No, that's not it, took off the heatsink , it won't fit with it on, there is a small gap between the ducts , I swear , I then wedged it carefully between them and ran my wires . It won't do any good just being close to the side ducting, only right between where the air gets sucked through . I'll take a pic
Build Log Fly-Fly F-4 Phantom: BUILD CRCJA Foamy EDFs 2159 Yesterday 12:45 AM
Sold Master Fly F-4 Phantom II 1/7 scale 99"lenth 65"w dhf23 Aircraft - Electric - Jets (FS/W) 9 Dec 29, 2011 09:43 PM
Alert E-Flite F-4 Phantom 32 DF ChuckTseeker Electric Plane Talk 17 Sep 09, 2011 12:54 AM
Discussion Starmax F-4 Phantom 90mm Build Thread neversommer Foamy EDFs 31 Jan 12, 2011 03:56 AM
Anyone build/fly AERC F-4 Phantom War Bird Radio Parkflyers 3 May 11, 2003 06:19 PM
