Old May 02, 2012, 06:36 PM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Originally Posted by AIR SALLY View Post
hey Tam did you get your turbine pipe today?
Later show and tell.....
Still on working hours for the shop.
My boss not let me play yet.
Tamjets is offline Find More Posts by Tamjets
Old May 02, 2012, 10:38 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
that boss is a slave driver
AIR SALLY is online now Find More Posts by AIR SALLY
Old May 02, 2012, 10:45 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
I know. He still make me working on customers order.
Old May 03, 2012, 12:45 AM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Here is the pipe.
Length 9.5"
Weight: 3.8oz
Old May 03, 2012, 12:50 AM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
Sweeet!!!!!
jcdfrd is offline Find More Posts by jcdfrd
Old May 03, 2012, 01:51 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
looks like a pair of pants for a cowboy looks good who makes those ? is it double walled ?
Old May 03, 2012, 02:07 AM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Here is the install.
Old May 03, 2012, 02:16 AM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
No wonder even the crashes of a turbine model look scale. All that fuel right next to a smokin hot motor.
I can't see a turbine in my hangar for quite a while yet.
jayb1rdz is offline Find More Posts by jayb1rdz
Old May 03, 2012, 02:20 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
looks right at home in there.
Old May 03, 2012, 02:27 AM
ColoradoHeliNut is offline
Find More Posts by ColoradoHeliNut
United States, CO, Lakewood
Joined Mar 2007
Originally Posted by stvinvegas View Post
How did you fix the silcone tube issue? I was afraid it would pop off if I pulled it down to low on the clevis.
I just moved it to the servo side clevis.
Tam, that looks fantastic!!!!!!!!!
Sorry to see you put the first one in so soon. Been there done that. This last winter I lost the right motor on my P-38 not long after take off.
It sounded just like yours did. I later found out one of the motor side bullit plus was cold soldered.
It also landed in sloppy wet ground but not anywhere near as bad as yours.
Failed Maiden Of the New FMS P-38, 1-19-2012 (0 min 51 sec)
ColoradoHeliNut is offline Find More Posts by ColoradoHeliNut
Old May 03, 2012, 02:41 AM
efflux RC is online now
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Pretty slick setup Tam.
Very nice.
efflux RC is online now Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old May 03, 2012, 02:43 AM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Sorry to said this. That is the most safe place for fuel cell. It got a lot shell around it to protect the tank when impact. The turbine front cold and rear is hot.
Old May 03, 2012, 04:56 AM
icicles is online now
Find More Posts by icicles
icicles's Avatar
Australia, ACT, Canberra
Joined Jul 2006
No doubt about it Tam, you do nice work.
I gave turbines serious thought. Went to one event and that turned me off them totally. The stink of unburnt fuel, having it in the car with me etc. Having to store significant amounts of fuel. I'll pass thanks. No thanks
Tam keep up the works for us EDF guys
Chris
icicles is online now Find More Posts by icicles
Old May 03, 2012, 08:29 AM
420flyboy is offline
Find More Posts by 420flyboy
Mile High EDF
420flyboy's Avatar
United States, CO, Denver
Joined Jul 2011
Originally Posted by ColoradoHeliNut View Post
Well mine is ready.
The couple of problems I ran into were.
1. Those stupid four bolts for the main wings. Geezzzzzz! Took forever. I barely got them in. I didn't use loc-tite though. I thought that's one place not to use it so you can take the wings off for transport. Hummm?
If you have to use loc-tite there then you might has well just glue the wings on.
2. The front opening for the gear is slightly off. Or the retract is. I had to cut a small notch so the wheel collar would clear.
3. I did cut a notch out for the rudder control rod. I don't see a problem with it. The tail cone is glued over the notch.
4. One wing, no matter how tight the two bolts. Was loose lateraly just a hair to see a gap when pushed forward & back. To fix it I wrapped the front & rear dowls with some of the clear tape that came with the kit. Now it's tight.
I think that's all.
Servos used: HS 85mg for all but the Elevator. There I used a HS-225mg. It's close to the recomended specs. It's 67 oz./in. Torque at 6v. I have my BEC Pro set to 6v.
If anyone really thinks it's not up to par, tell me.
100a CC Ice, CC BEC Pro wire to main battery.
AUW with a HP 3s x 2 5000mah 35c is 6.8lbs.
Oh, rudder & front steering are seperate.
Here's a couple of pics. Hows my Electronics bay look?
Couple of questions for you,
How did you maiden already if you just built it ?
AUW 6.8
We have the same setup , I use 1100mah 2s life instead of bec and nano tech 6s 5000mah 35c - 786 grams
Yours 428 grams each x 2 = 856 grams,
Looked at your pics and can't figure out how you shaved off 1/4 lbs of weight with the same setup as everyone else. And I hope you didn't fly without some wire management , I'd be scared something will come loose and get caught in something.
Looked at your posts in other threads , you got this plane last Thursday , most likely at action hobbies, then you post here that it's built , I private message you and you say you maidened it last week. Sorry dude , but I'm calling you out, on your maiden and AUW .
420flyboy is offline Find More Posts by 420flyboy
Old May 03, 2012, 09:34 AM
Bpitts is offline
Find More Posts by Bpitts
United States, TX, Texas City
Joined Dec 2011
Well i must but in i got mine last thursday stayed up untill was rtf could have maiden on friday but waited on better weither and did it sunday. Everyone has seen my video and i must say mine also is under 7lbs around 6.8 6.9 auw......using hyperion 6s 5000 mah pac all stock eflight 80 amp ecs. Ect.
Bpitts is offline Find More Posts by Bpitts
Build Log Fly-Fly F-4 Phantom: BUILD CRCJA Foamy EDFs 2120 Dec 13, 2015 10:54 AM
Sold Master Fly F-4 Phantom II 1/7 scale 99"lenth 65"w dhf23 Aircraft - Electric - Jets (FS/W) 9 Dec 29, 2011 09:43 PM
Alert E-Flite F-4 Phantom 32 DF ChuckTseeker Electric Plane Talk 17 Sep 09, 2011 12:54 AM
Discussion Starmax F-4 Phantom 90mm Build Thread neversommer Foamy EDFs 31 Jan 12, 2011 03:56 AM
Anyone build/fly AERC F-4 Phantom War Bird Radio Parkflyers 3 May 11, 2003 06:19 PM
