I could see crosswinds being an issue with the F-4 based on the design. I haven't flown mine since it is still in the box, so I will let others answer that for actual crosswind encounters.....I would say though try and fly on a calm day and use about half flaps on takeoff, I bet that will help. Make sure it has plenty of speed before rotation so there is ample airflow over the control surfaces.
Not my first rodeo when it comes to speed on take off! It went into the air completely on its own. I don't like half flaps on take because it can bring the jet off the ground before you might want it to. I like my jets hauling butt before they go airborne. Hopefully someone else that has delt with crosswinds on this specific jet could bring us their feedback, based on earlier flight reports I didn't think it was an issue despite the F-4's design which would seem to play some tricks with a crosswind.
As far as the calm day thing, well this is not a flagship jet for me, it's my daily flyer and I expect it to fly in most conditions. |
Man this poor thread seems to have just died....
So I am going to give it another go this weekend. I added the differential, toned down the rudder and moved the cg forward just a tad. I think on take off I might have been holding to much Nosegear/Rudder and it might have caused the roll. The crazy thing is my jetfan seems to like the F-4 more than it did the Habu, I wasent doing any high speed passes but I flew for 3 minutes and used less than 40% of the capacity of the packs, It also looked to be a bit faster than my Habu (Habu dopplered at 129) but it might just be the sound from the bifurcated exhaust (the Habu was pretty silent). So weather permitting I will ring her neck this weekend. |
Taiwan, 北市
Joined Dec 2008
Does anyone know if there's an Asia-based vendor that carries the F-4? I'm located in Taiwan so ordering it from E-Flite or any other US vendor isn't a feasible option due to the shipping cost. RC Castle in Hong Kong carries the Habu but not the F-4. Any suggestions? Tks!
Kevin |
Pittsburgh Allegheny, Pennsylvania, United States
Joined Feb 2004
SPRING, TX
Joined Feb 2007
I lost an A-4 - and almost an F-4 due to this. My F-4 doesnt need a lot of speed in order to start hopping off the ground, so I just make sure that im NOT pulling any up elevator on the take off roll until it is moving along and ready to fly. It OFTEN jumps off before I think it should - but what are ya gonna do??? You didn't comment on your landing, so I guess that was not an issue. Most of us have moved the CG way behind the recommended and she really is a different bird. I use a notch of flaps on take-off - just so the inboard wing stalls first if it does come off too soon. Its only about 15-deg. Im glad its your daily driver - it is worth it. Just go fly the heck out of it and get used to it. Enjoy! |
Just put 3 more flights on mine yesterday. 2nd flight I was at 170mm with a 6s3300 and testing slow speed at full flap. Lost perspective in the turn (and alt) and the nose got too high. Full power and full down and it went over its back (I'm sure due to the power). Plus, I was very slow. Took about 500' to recover. After leveling off, I pulled flap and shook her out at speed and she was fine. It was a little more sensitive on final, but got her down no issues. Used full flap.
The kicker to me is that it looks nose heavy carrying all that up elevator, yet you start to feel the CG when its back at 170. More testing for sure. |
Landing was fine, I have an A-7 and it had some of these same issues but the cg helped it out, I'll get her figured out, just got to fly the heck out of it and figure it out. |
United Kingdom, Northern Ireland, Belfast
Joined Jun 2011
hey there folks. I'm still plugging away at my F-4. I have made a few changes. Mainly to a 90mm fan. I now have the CS 12 blade 90mm fan installed, duct work done and she sounds wonderful. This has been complete effort. I've also had to go from my original 1400kv motor to a HET Typhoon 1700mah inrunner. On 6s she is pulling @87 amps and 1800 watts. I can't be sure at the moment... My watt meter wasn't up to the task and I'm waiting on a new more robust unit. I've also splashed and installed a 180/200 amp ESC. All of this adds weight. Phew. One thing I really wanted to be sure of was air flow and cooling over the speed controller so I've cut out the top of the duct work to allow the cooling fans to have air blown (at typhoon speeds) over it. All of this has been sealed and taped up using not duct tape but high tac hinge. Strong stuff to be sure.
I'm now working on the rudder installation. I'll post photos soon. It's good to see where everyone is putting the CG. It's heavy with the batteries and I haven't the wings on or the retracts installed. Go Team F-4! |
No need for a 180/200 amp esc, that is complete overkill and adds additional weight to an alreadt CG/Weight critical jet. I suggest going with a max of 120 amp esc, that is all you'll need based on the numbers your setup is pulling. A castle 120 would be ideal, plus it would have data logging to help you see accurate numbers on your setup.
So flight number 2 and 3 today...
The owners manual came with an addendum that seemed to want quite a bit of up for the elevator neutral position. In flight number one she nosed up in the corners and leaped off the runway on take off. I moved the cg slightly forward thinking that was the problem. Well that was definitely not the problem, flight number 2 was a nightmare! The elevator was non responsive and would just stall and roll over with to much, it took everything I had to get it on the ground. So I then moved the cg back knowing and got rid of that manufacture reccomended up trim ![]() Flight number 3 finally a normal take off!! And like so many have said it was way better (this was at 6 1/8 cg) it was the best it has flown but as I was bringing it around from base to final the elevator stalled again trying to pull up the nose. So another stall and another bit of crazy piloting to get her back on track. So next time around I'm going to 6 3/8 cg. I can't believe how wrong eflite got the cg on this model. I would bet anything that most of the losses of this jet have come from being to nose heavy. I also used 30% differential and the nose up issue disappeared. By the way, I don't know why but the jetfan 80 is working way better in the F-4 than it ever did in the Habu, not sure why, I figured with the bifurcated thrust tube it would be less efficient but it's really come alive! |
| Thread Tools | |
| Build Log Fly-Fly F-4 Phantom: BUILD | CRCJA | Foamy EDFs | 1381 | Yesterday 06:00 AM |
| Sold Master Fly F-4 Phantom II 1/7 scale 99"lenth 65"w | dhf23 | Aircraft - Electric - Jets (FS/W) | 9 | Dec 29, 2011 09:43 PM |
| Alert E-Flite F-4 Phantom 32 DF | ChuckTseeker | Electric Plane Talk | 17 | Sep 09, 2011 12:54 AM |
| Discussion Starmax F-4 Phantom 90mm Build Thread | neversommer | Foamy EDFs | 31 | Jan 12, 2011 03:56 AM |
| Anyone build/fly AERC F-4 Phantom | War Bird Radio | Parkflyers | 3 | May 11, 2003 06:19 PM |
