Old May 02, 2012, 03:52 AM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Originally Posted by AIR SALLY View Post
he did'nt get to fly ? where his F-86 ? the T conversion looks good .ck my F-20 Thread ..you need to put a turbine in one of these when i get it done
I didn't fix it for him. Too busy get the F-4 ready and I let him fly my Habu.
But I landed too close to edge of the run the weed caught me.
That why he upset without any planes to fly on sunday.
Tamjets is offline Find More Posts by Tamjets
Old May 02, 2012, 06:20 AM
ColoradoHeliNut is offline
Find More Posts by ColoradoHeliNut
United States, CO, Lakewood
Joined Mar 2007
Well mine is ready.
The couple of problems I ran into were.
1. Those stupid four bolts for the main wings. Geezzzzzz! Took forever. I barely got them in. I didn't use loc-tite though. I thought that's one place not to use it so you can take the wings off for transport. Hummm?
If you have to use loc-tite there then you might has well just glue the wings on.
2. The front opening for the gear is slightly off. Or the retract is. I had to cut a small notch so the wheel collar would clear.
3. I did cut a notch out for the rudder control rod. I don't see a problem with it. The tail cone is glued over the notch.
4. One wing, no matter how tight the two bolts. Was loose lateraly just a hair to see a gap when pushed forward & back. To fix it I wrapped the front & rear dowls with some of the clear tape that came with the kit. Now it's tight.
I think that's all.
Servos used: HS 85mg for all but the Elevator. There I used a HS-225mg. It's close to the recomended specs. It's 67 oz./in. Torque at 6v. I have my BEC Pro set to 6v.
If anyone really thinks it's not up to par, tell me.
100a CC Ice, CC BEC Pro wire to main battery.
AUW with a HP 3s x 2 5000mah 35c is 6.8lbs.
Oh, rudder & front steering are seperate.
Here's a couple of pics. Hows my Electronics bay look?
ColoradoHeliNut is offline Find More Posts by ColoradoHeliNut
Old May 02, 2012, 10:57 AM
BobH13 is offline
Find More Posts by BobH13
United States, VA, Fredericksburg
Joined Mar 2009
Whos nose gear is that? shulmans? The install looks ok to me
BobH13 is offline Find More Posts by BobH13
Old May 02, 2012, 11:17 AM
GuppyG is offline
Find More Posts by GuppyG
United States, CA, San Diego
Joined May 2004
Originally Posted by ColoradoHeliNut View Post
Well mine is ready.
This thread locker is used on fasteners that need to be reused (wing bolts). I have some at home for this sort of thing.
http://www.amazon.com/Vibra-TITE-VC-.../dp/B005ETYAX0
I would not fly it without some sort of thread lock on it.
scott.
GuppyG is offline Find More Posts by GuppyG
Old May 02, 2012, 11:50 AM
stvinvegas is offline
Find More Posts by stvinvegas
stvinvegas's Avatar
United States, NV, Las Vegas
Joined Dec 2006
I had the same problem with my front gear rubbing one side, I bent the wire a bit, but I am going to notch it out like you did to be safe.
I also found no problem with the rudder notch issue.
1. It did not move
2. The rear cover holds it in so I don't need to glue a piece of wood. However, if I was to do another one, I would string it through and then glue after like Bwana did.
Lastly, did anyone else have an issue with the steering clevis on the front retract. The problem I'm having is with front steering. The clevis will not move freely up and down as I retract the gear. I am thinking of going with a dubro black and gold locking clevis, I did the same on my habu and its worked great. any thoughts?
stvinvegas is offline Find More Posts by stvinvegas
Old May 02, 2012, 11:54 AM
Bob Hunt is offline
Find More Posts by Bob Hunt
Mustang Fever
Joined Jan 2005
Colorado:
Are you at all concerned about your antenna being that close to a carbon fiber object?
I'm not familiar with the Dx radios, but I know that Futaba says to keep the ends of the antennae 1/2" away from metal or CF objects.
CF does absorb or attenuate microwave signals- it's used as part of "stealth" mods to aircraft, etc.
Bob Hunt is offline Find More Posts by Bob Hunt
Old May 02, 2012, 01:15 PM
ZACATTACK is offline
Find More Posts by ZACATTACK
ZACATTACK's Avatar
Canada, ON, Hamilton
Joined May 2011
Originally Posted by Tamjets View Post
Nothing goes stop me now.
Working on the turbine conversion and this what I got so far.
Remove the front former to fit a pair of 10 oz each side fuel tank and it is right on the CG.
I be using 4oz airtrap tank in the front of the ducting. So all the fuel be right on the C.G.
Making new former to mount the turbine and bifurcated pipe.
The bifurcated pipe be done tomorrow night.
Go Tam Go!! The EDF Mad Scientist!!
ZACATTACK is offline Find More Posts by ZACATTACK
Old May 02, 2012, 01:33 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Turbine Conversion King....Lew
Old May 02, 2012, 03:14 PM
kevin is offline
Find More Posts by kevin
kevin's Avatar
United States, OH, Grove City
Joined Aug 1999
that battery looks suspect. is it puffed? ... or just looks that way in the picture. if it is stay away from it if you value your new plane.
Well mine is ready.
I think that's all.
kevin is offline Find More Posts by kevin
Latest blog entry: Video of my HK Cobra
Old May 02, 2012, 03:22 PM
Joined Mar 2007
Stock E-Flite strut
Old May 02, 2012, 03:25 PM
Joined Mar 2007
Not a flight battery. Thanks though.
It's an old "Voltz" 45c 4500mah battery I used in my FW F-18e
Old May 02, 2012, 03:35 PM
Joined Mar 2007
Originally Posted by Bob Hunt View Post
Colorado:
I didn't think the tubing was CF. It's pretty thin & week if ya ask me. Thought/think it's FG.
I just put it where the destructs, Ahhh I mean Insrtucts put it.
Page 33 http://www.e-fliterc.com/ProdInfo/Fi...125-Manual.pdf
Old May 02, 2012, 03:41 PM
Joined Mar 2007
Just the silcone tubing over the clevice caused the retract to bind/jam & stop it from retracting all the way. My retract worm gear starts slipping & screeeeeching. AHHHHH! It's like finger nails on a chalk board.
Old May 02, 2012, 05:16 PM
stvinvegas's Avatar
Joined Dec 2006
Mine too, it freaked me out and I could picture having to order a new one from HH cause it blew up. I know it has the protection in it, but still freaky sound.
How did you fix the silcone tube issue? I was afraid it would pop off if I pulled it down to low on the clevis.
Old May 02, 2012, 05:46 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
hey Tam did you get your turbine pipe today?
AIR SALLY is offline Find More Posts by AIR SALLY
Build Log Fly-Fly F-4 Phantom: BUILD CRCJA Foamy EDFs 2128 Jun 21, 2016 02:55 AM
Sold Master Fly F-4 Phantom II 1/7 scale 99"lenth 65"w dhf23 Aircraft - Electric - Jets (FS/W) 9 Dec 29, 2011 09:43 PM
Alert E-Flite F-4 Phantom 32 DF ChuckTseeker Electric Plane Talk 17 Sep 09, 2011 12:54 AM
Discussion Starmax F-4 Phantom 90mm Build Thread neversommer Foamy EDFs 31 Jan 12, 2011 03:56 AM
Anyone build/fly AERC F-4 Phantom War Bird Radio Parkflyers 3 May 11, 2003 06:19 PM
