Old May 01, 2012, 08:11 AM
Gibb is offline
Find More Posts by Gibb
Livonia, Mi
Joined May 2010
Hitec 65MG servo specs (25oz in @ 4.8V, 31oz in @ 6V)
Recommended JR MC 35 specs (30oz in@ 4.8v, 35 oz in @ 6V)
The same MC35 servos were recommended for the Habu32. However, the control suraces for the F4 wing are about 3/4 of the size of the Habu.
I appreciate everyones thoughts on this.
Jim
Gibb is offline Find More Posts by Gibb
Old May 01, 2012, 10:34 AM
ZACATTACK is offline
Find More Posts by ZACATTACK
ZACATTACK's Avatar
Canada, ON, Hamilton
Joined May 2011
Jim
Those servos are good for a plane/jet 6 pounds and under. You want the 85 series of Hi-Tec servos in this plane. Read the Habu 32 threads and make up your own mind... the 85mg is the solution here.
ZACATTACK is offline Find More Posts by ZACATTACK
Old May 01, 2012, 11:05 AM
172AMD is offline
Find More Posts by 172AMD
Richmond B.C. Canada
Joined Aug 2006
For my Habu 32 I used HS65 MG's for ailerons and elevators, HS85 MG's for flaps. All on 6 volts. All my flying is on low rates (minimal surface movement). I would not use HS65 MG's on the flaps.
172AMD is offline Find More Posts by 172AMD
Old May 01, 2012, 11:33 AM
stvinvegas is offline
Find More Posts by stvinvegas
stvinvegas's Avatar
United States, NV, Las Vegas
Joined Dec 2006
Hey Guys,
Want some opinions, I am just finishing up my F4. Last step, I am putting on the retracts.
Did you guys use the stock screws? Did they fix the problem where the tops broke off, like on the Habu? I know bwana used different ones, but if they fixed the problem, I would like to use the ones with the kit.
Let me know what you think?
stvinvegas is offline Find More Posts by stvinvegas
Old May 01, 2012, 11:41 AM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Originally Posted by stvinvegas View Post
Hey Guys,
I repalce with better screw.
Make sure to drill 1/16" pilot hole.
Tamjets is offline Find More Posts by Tamjets
Old May 01, 2012, 11:44 AM
stvinvegas's Avatar
Joined Dec 2006
420 I'm with you, I don't really even like the look of the gear doors.
Old May 01, 2012, 11:46 AM
stvinvegas's Avatar
Joined Dec 2006
Thanks Tam, thats what I thought. Better safe then sorry, that was the worst part of the Habu build. Broke off a couple before I knew it.
Old May 01, 2012, 12:48 PM
KentF is offline
Find More Posts by KentF
FunkMaster
KentF's Avatar
United States, OH, Mason
Joined Jan 2011
When securing the wing spar in the fuselage, how tight is everyone making these bolts. Since they press against the carbon fiber spar, I'm afraid of damaging it. Any tips or knowledge would be appreciated. Thanks.
KentF is offline Find More Posts by KentF
Old May 01, 2012, 01:10 PM
420flyboy is offline
Find More Posts by 420flyboy
Mile High EDF
420flyboy's Avatar
United States, CO, Denver
Joined Jul 2011
As tight as I could get them, won't hurt that carbon fiber
420flyboy is offline Find More Posts by 420flyboy
Old May 01, 2012, 01:45 PM
stvinvegas's Avatar
Joined Dec 2006
What tool did everyone use, and how the %&%8 do you get your hand in there?
Also locktite blue, right?
Old May 01, 2012, 01:47 PM
stvinvegas's Avatar
Joined Dec 2006
I did that and stripped one on the habu, had to go with a bigger bolt. Sometimes you don't know your own strength, so not crazy tight, they can strip.
Old May 01, 2012, 04:44 PM
ZACATTACK's Avatar
Joined May 2011
Sorry for the off-topic. When I updated the Habu to 8S ..I update the servos too...that being said..I still only use these 65MG for planes/jets under 6 pounds..better safe then sorry..get the 85 MG's for your expensive Bird's guys or the best ones you can afford!!... the next round of servos will be HV in the 85 series...no more regulator on the next Jet Build.
Old May 01, 2012, 06:48 PM
1bwana1 is offline
Find More Posts by 1bwana1
Gotta have toys!
La Jolla, CA. USA
Joined May 2006
LOL! Getting these bolts in was the hardest part of the build. I am 6"5" with big hands and feet. I just couldn't get them in. I finally resorted to my least used, most expensive tool. I called in my 5'3" Wife with her small hands. She got them right in. I have a feeling it is going to cost me some day. LOL!
I used a ball driver to tighten them up. It is the only way.
Yes, blue Loctite on all metal to metal in the plane.
1bwana1 is offline Find More Posts by 1bwana1
Old May 01, 2012, 07:13 PM
1bwana1 is offline
Gotta have toys!
La Jolla, CA. USA
Joined May 2006
I just finished programming my F-4. I used the AR-8000 DSMX RX as suggested in the manual, and set my servos up as recommended in the manual. This means that the aileron servos are set up with opposite orientation so they can run off a "Y" harness.
My guess is that HH did this to support the DX-8 Spektrum radio, not because it gets you the best setup. When you get to the reccommended throws for the ailerons the manual calls for a couple of millimeters of differential. More throw up than down. This is usually done to take caare of rolling issues that cause the plane to pull slightly off line during rolls. However, since the ailerons are on a "Y", you cannot put in this kind of differential. I ended up having identical throws up and down. I'm not sure if this will be an issue because I haven't flown the plane yet. Hoefully it won't matter much. Still, for those that have a high channel radio like the 11X, I suggest you use at least a 9 channel RX. This way you will have complete control of the entire setup.
I also found that even with the longest arms on the Hitec HS-85 servos you will have trouble getting the full 30mm of throw for the flaps. I ran out at about 28mm. Once again, it probably won't matter.
One final thing. The manual calls for Up Elevator compensation with flaps. The habu-32 required down Elevator compensation which worked perfectly. Have you guys who have flown this plane think the Up Elevator is correct for this jet?
I will post my 11X file as soon as I have done the maiden and gotten it all dialed in.
Old May 01, 2012, 07:34 PM
bdelapen is offline
Find More Posts by bdelapen
Sponsored by Team de la Peņa
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
Hi,
You can still achieve Aileron Differential using Aileron servos on a Y harness, reset you neutral point on both your servo arms towards the front/nose of the airplane or away from the aileron (move the servo arms one or two notches on the spline and lengthen your push-rods). The more you move them the more differential you will get. Play with the angles until you get the recommended differential and then when you fly the plane you can increase or decrease it to your liking.
The right hand side of this picture illustrates this:
- Birger
bdelapen is offline Find More Posts by bdelapen
Build Log Fly-Fly F-4 Phantom: BUILD CRCJA Foamy EDFs 2128 Jun 21, 2016 02:55 AM
Sold Master Fly F-4 Phantom II 1/7 scale 99"lenth 65"w dhf23 Aircraft - Electric - Jets (FS/W) 9 Dec 29, 2011 09:43 PM
Alert E-Flite F-4 Phantom 32 DF ChuckTseeker Electric Plane Talk 17 Sep 09, 2011 12:54 AM
Discussion Starmax F-4 Phantom 90mm Build Thread neversommer Foamy EDFs 31 Jan 12, 2011 03:56 AM
Anyone build/fly AERC F-4 Phantom War Bird Radio Parkflyers 3 May 11, 2003 06:19 PM
