Old Apr 26, 2012, 08:18 PM
1bwana1 is offline
Find More Posts by 1bwana1
Gotta have toys!
La Jolla, CA. USA
Joined May 2006
E-Flight F-4 Phantom Build/Fly Thread
It has been a long wait for this highly anticipated model. The "anticipation" thread is over 75 pages long. Now that they have actually begun shipping, I thought it would be better to start a new thread for build and flying information so people don't have to wade through the other thread for information.
I picked mine up from my LHS this afternoon. They had 12 pre-orders but only recieved 2. They have no idea how long it will take for the next shipment. I'm really glad I was number 1 on the list.
I plan on doing a fairly stock build.
Stock motor/fan unit, on 6S 5000 maH packs.
E-Flight retracts of course.
I will be doing an 8 channel setup using my JR-11X TX and a Spektrum AR8000 RX.
I will use a Castle ICE 100amp ESC, and a Castle 10amp BEC to power the RX. This is the same setup I have had great success with on my Habu-32.
I guess the biggest change from stock will be my servo choices. I just feel better having metal gear servos on a jet, so I have elected to go with Hitec servos as follows. I will set the BEC to 6 volts for max torque on the servos.
Aileron and Flaps- HS-82MG 47oz/
Rudder - HS-5085MG 60oz I like lots of rudder authority for knife edge and aerobatics so wanted more than the recommended power. After seeing the rudder, it is pretty small, so I am not sure this plane will hold knife or not. I guess we will see after flying. The smaller servo may prove to be enough.
Elevator- This one needs to be strong. I am using the HS-5245MG 76 oz.
Nose Wheel Steering- HS-85mg 49oz. I fly mostly off a fairly rough dirt field so wanted the strength of metal gear here for sure.
I will be happy to share my 11X TX programming for those interested once it is done.
I should start the build this weekend. I encourage anyone else to post their builds, and share questions and answers.
In the mean time here is a picture of the boxes.
Description:
1bwana1 is offline Find More Posts by 1bwana1
Old Apr 26, 2012, 08:32 PM
F-86FLIER4LIFE is offline
Find More Posts by F-86FLIER4LIFE
Landin' On The Canopy BAD
F-86FLIER4LIFE's Avatar
Lee's Summit, MO
subbed!!!!
F-86FLIER4LIFE is offline Find More Posts by F-86FLIER4LIFE
Old Apr 26, 2012, 08:38 PM
Jetnfast is offline
Find More Posts by Jetnfast
Jetnfast's Avatar
United States, CA, Temecula
Joined Feb 2008
Nice!!
Jetnfast is offline Find More Posts by Jetnfast
Old Apr 26, 2012, 08:58 PM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
You don't mind I like to share my on here too.
But I had to toss the coin either EDF or P-20 turbine.
If I has second kit that would be easy decission.
Tamjets is offline Find More Posts by Tamjets
Old Apr 26, 2012, 09:56 PM
heyop is offline
Find More Posts by heyop
heyop's Avatar
Southern Illinois
Joined Nov 2009
subscribed!
heyop is offline Find More Posts by heyop
Old Apr 26, 2012, 09:57 PM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
Present!
Michael Paxton is offline Find More Posts by Michael Paxton
Old Apr 26, 2012, 10:04 PM
Lojik is offline
Find More Posts by Lojik
Hope is not a Strategy
Lojik's Avatar
Australia, VIC, Caroline Springs
Joined Apr 2011
watching
Lojik is offline Find More Posts by Lojik
Old Apr 26, 2012, 10:09 PM
1bwana1 is offline
Gotta have toys!
La Jolla, CA. USA
Joined May 2006
Tam, I encourage you any any others to join this thread. That is what it is for. We can all learn from each other.
Old Apr 26, 2012, 10:23 PM
Lojik is offline
Lojik's Avatar
Joined Apr 2011
Just for the lazy ones can you advise what it would cost to get this bird in the air with stock setup retracts using the gear you have chosen as a base, essentially BNF cost?
Old Apr 26, 2012, 10:26 PM
evo101 is offline
Find More Posts by evo101
evo101's Avatar
Australia
Joined Jun 2009
P20!! :d
Originally Posted by tamjets View Post
you don't mind i like to share my on here too.
But i had to toss the coin either edf or p-20 turbine.
If i has second kit that would be easy decission.:d
evo101 is offline Find More Posts by evo101
Old Apr 26, 2012, 10:31 PM
1bwana1 is offline
Gotta have toys!
La Jolla, CA. USA
Joined May 2006
I opened the box and went through the parts. My first impressions are very positive. The plane is nicely finished. I would say a step above my Habu-32 which is a very nice kit. The F-4 is a more complicated plane, so this is even more impressive. I'm thinking the wait for QC issues was worth it.
I have glued the angled wing tips on, The fit is very nice, the seams are tighter than the Habu-32. This appears to be true for the wing to fuse fit as well. The seam is tight, and even, there was a small gap in the Habu-32.
The canopy, and fan compartment hatch are held on by a pin and magnet system. I have experienced problems with magnetic hatches in the past. I prefer to ahve a spring latch as well just for safety. The fit is good, and they snap on pretty tight, so it may be ok. Still, I may add some latches.
The battery compartment is much smaller than on the Habu-32. I'm thinking it will be much more difficult to go with high cell count, high power, setups on this plane than it is with the Habu-32. You won't be able to do it with width or height, so It looks like it will be have to be length. This will probably result in CG issues. I'm sure the clever people out there will find a way.
I may have time to do the hinges on the ailerons, and flaps tonight. We'll see...
Old Apr 26, 2012, 10:33 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
once i get mine flown i plan on doing some mods not so much for speed but to make it more scale and or different than the rest .
AIR SALLY is online now Find More Posts by AIR SALLY
Old Apr 26, 2012, 10:39 PM
1bwana1 is offline
Gotta have toys!
La Jolla, CA. USA
Joined May 2006
Well, I have been collecting parts during the long wait, so was able to take advantage of some sales, and deals. I think I have all of the parts I need at this point. My receipts so far total $906.69 including the AR800 RX. My guess is that will pretty much be the lower end. I would budget $1,100 to $1,200 as the most likely range.
Old Apr 26, 2012, 10:43 PM
Double E is offline
Find More Posts by Double E
Double E's Avatar
Atlanta, GA
Joined Mar 2009
I opened my box and inspected the kit. It looks great but the paint finish on the fuselage has been wet sanded a bit to hide some blemishes. Some of the decals are below the clear coat and look great but some of them are surface mounted stickers and look a little cheap with bubbles under them and wrinkles on the curved areas. I'd say the finish on the Habu 32 fuselage is a little nicer than the F4 but all in all she is a great looking plane and I'm sure people will be excited to see a Phantom at the flying field.
I'll probably get started on my build this weekend or next.
Double E is offline Find More Posts by Double E
Old Apr 26, 2012, 10:52 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i kinda wish they would have sold some in primer so guys could do a different version with out having to sand the paint off first.
Build Log Fly-Fly F-4 Phantom: BUILD CRCJA Foamy EDFs 2159 Yesterday 12:45 AM
Sold Master Fly F-4 Phantom II 1/7 scale 99"lenth 65"w dhf23 Aircraft - Electric - Jets (FS/W) 9 Dec 29, 2011 09:43 PM
Alert E-Flite F-4 Phantom 32 DF ChuckTseeker Electric Plane Talk 17 Sep 09, 2011 12:54 AM
Discussion Starmax F-4 Phantom 90mm Build Thread neversommer Foamy EDFs 31 Jan 12, 2011 03:56 AM
Anyone build/fly AERC F-4 Phantom War Bird Radio Parkflyers 3 May 11, 2003 06:19 PM
