Old Jun 11, 2012, 07:39 PM
bill34207 is offline
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I actually got a better shot overhead this evening after putting the shortened stingers back on Phil.
Ordered the Speedmaster bushings from OSE today and in the meanwhile robbed one from my mono to do the setup on the stingers. I basically honed the inside of the stingers to a very snug fit with a piece of 220 grit paper wrapped around a 1/8" dowel. Cleaned the insides thoroughly with spray brake cleaner and let it dry. Cut a couple pieces of 1/4" brass tube to act as sleeves for the bushing and roughed them up with some 150 grit paper. After coating the outside of the 1/4" brass with Loctite 603 dropped them in from the front side then used a 1/4 to 3/16 stub as a driver to seat them flush with the back sides of the stingers.
bill34207 is offline Find More Posts by bill34207
Latest blog entry: Freewing F-5N Tiger 80 mm EDF
Old Jun 11, 2012, 07:43 PM
Tiqueman is offline
Find More Posts by Tiqueman
Scottskis' Laminates
Tiqueman's Avatar
Parrish, FL
Joined Oct 2010
And youre not sure it will be back together before the 4th Sunday huh Bill? lookin good.
Tiqueman is offline Find More Posts by Tiqueman
Old Jun 11, 2012, 08:51 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Well... I do have to wait for the 6s 4000's that I ordered today. Even from the US warehouse seems like it always takes about 2 weeks for them to get around to packing and shipping my stuff.
Still gotta s/b a few props too. I already have a pair of raw X442's that I'd kind of like to try on 6s. Think I might already have an extra X447 laying around to replace the one the pond monster ate Sunday too.
Old Jun 13, 2012, 09:51 AM
wagondriver42 is offline
Find More Posts by wagondriver42
wagondriver42's Avatar
United States, NY, Rochester
Joined Jul 2011
bill did you see what is up for sale in the classified section?
http://www.rcgroups.com/forums/showthread.php?t=1671033
wagondriver42 is offline Find More Posts by wagondriver42
Old Jun 13, 2012, 05:20 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Yeah, I saw that this morning. He actually emailed me a link to his ebay ad a couple of days ago in case I might be interested in having it back. I have no desire to own it again though. It's like I told him when he was wanting it. It makes a good dragster but doesn't corner worth a crap.
Old Jun 17, 2012, 09:55 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Guess it's about time for an update on this one. I finished up the mods to it yesterday.
Wound up pulling the stingers back off again and adding in the transom wedges that I originally left out. Without them I could barely get the stingers to neutral with the hull bottom with them at full up adjustment. Not sure I'm much beter off with them in because now I can barely get the stingers to neutral with them at full down adjustment.
I got lucky on a reverse wind Hughey cable. Went to South River last week (after finding my spare was actually a standard lay that I'd stuck back in the bag with a R label) The site showed they were not in stock but ordered one anyways. Much to my surprise it shipped the same day and arrived in yesterdays mail.
Hobby King made a liar out of me, too. According to UPS tracking my 6s 4000's should show up Wednesday so this one will be ready for 6s testing at our normal run day next Sunday.
Old Jun 17, 2012, 10:23 AM
bostong is offline
Find More Posts by bostong
bostong's Avatar
Danmark, Sjælland, Sorø
Joined May 2011
Good luck bill
bostong is offline Find More Posts by bostong
Old Jun 17, 2012, 10:58 PM
Pseudonym is offline
Find More Posts by Pseudonym
Pseudonym's Avatar
Joined Apr 2012
I did the same thing with south river. It said "estimated arrival, 7 days" or something like that...I checked that for maybe a few weeks with no change, then finally just ordered and it was shipped the next day.
Pseudonym is offline Find More Posts by Pseudonym
Old Jun 18, 2012, 03:17 AM
madphil is offline
Find More Posts by madphil
Lets get the HUEY up
madphil's Avatar
bolton england
Joined Jan 2009
looks good bill have you fitted prop savers ???
madphil is offline Find More Posts by madphil
Old Jun 18, 2012, 04:27 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Going to have to show my ignorance and say that if I did I wasn't aware of it.
I set the shafts up with X447's with about 3 threads showing after the nut. With the 442's I cut a couple pieces of tygon line to take up some of the open shaft space to keep thread count about the same.
Old Jun 18, 2012, 01:50 PM
madphil is offline
madphil's Avatar
bolton england
Joined Jan 2009
Originally Posted by bill34207 View Post
Going to have to show my ignorance and say that if I did I wasn't aware of it. .
Theres many ways of doing this,. the simple waterside way is to remove the stinger with shaft still fitted put a ring of ca glue round the shaft after the bearing let it set then refit shaft , the glue will be enough to stop the shaft pulling through the bearing if the flex comes loose or breaks
a more perminant way is to glue a small section of brass tube in the same place just make sure there is enough clearance in the stuffing tube so it won't bind ( sometimes you have to cut a bit out of the PTFE liner to clear )
you will NEVER loose a prop again !!!!!!!!!
( there is a greater chance of loosing a shaft on a twin setup the boat will keep driving and drag the other shaft out )
Old Jun 19, 2012, 08:25 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Guess I can safely say that I haven't fitted it with prop savers Phil. Actually I don't think one would have helped me on the one I lost since the flex let go just in front of the stub shaft.
I've heard it said that the tygon like I used for spacers can save one if the prop nut comes off (1/8" id tube more or less threaded onto a 3/16" shaft) but I don't hold a lot of faith in it. I used it to avoid having the force a good stong locknut that many more turns down the stub.
Old Jul 01, 2012, 01:43 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Shortening the stingers really helped the cornering on this one. It will turn at wot and on 6s with X442's gps'd at 60 and some change on it's 1st run today.
There may be some gopro vid of it later shot by Jeremy on it's 2nd run. Brian had a pair of c/r Fightercat 445's he wanted me to try on it. gps only said 55 with those though.
Old Jul 01, 2012, 03:51 PM
Pseudonym's Avatar
Joined Apr 2012
60mph is perfect for this cat. Congrats, glad you got it worked out. This thing should be great when it comes to a fun-to-run boat. I need to get around to building mine one of these days...
Old Jul 02, 2012, 05:34 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Still not totally worked out. When I pulled the shafts found a lump/distoroin about mid way up on the standard rotation flex. Thinking I'll order another Hughey in standard rotation for that side as I'm not even sure of what make flex that one is. (Think it's an OSE brand but not positive) It was just one that was on my box. If putting a Hughey in doesn't fix it I'll probably have to replace the stuffing tube on that side (although alignment is good).
You're absolutely right about it being a fun to run boat at 60. In smooth water like we had yesterday you don't even really have to let off the throttle for the whole run. Biggest problem I has with it was at the left hand end of the front straight where the spray from the props would hide the boat as it started into the turn.
Build Log Cheetah - Drambuie On Ice RayR Racing Boats - Electric 91 Dec 21, 2015 05:33 PM
Sold Seagate Cheetah 15K.5 300 GB,Internal (ST3300655SS) Hard Drive wrathofkhan Non R/C Items (FS/W) 3 Mar 29, 2012 12:31 AM
New Product Cheetah 70c 7000mah lipo bob2005 Product Announcements 0 Mar 25, 2012 03:55 PM
Wanted Cheetah or Super Cheetah mustang mark Aircraft - Sailplanes (FS/W) 5 Jan 31, 2010 02:42 AM
For Sale NIB Super Cheetah Kit by Cheetah Models surfimp Aircraft - Sailplanes (FS/W) 11 Jun 04, 2004 09:29 PM
