Old Jun 10, 2012, 02:13 PM
madphil is offline
Find More Posts by madphil
Lets get the HUEY up
madphil's Avatar
bolton england
Joined Jan 2009
that boat should be flying with them HET's
what props are you running ?
are you running 6s on them motors ?
where is the C of G now ?
what timing are you running the motors on ?
madphil is offline Find More Posts by madphil
bill34207 is offline
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Don't give up yet Phil. Those vids were shot with the props spinning in. In an act of desperation switched them to rotating outward.
Big improvement except for the GPS speed reading that still has me baffled
Fightercat Cheetah - Red Bull Twin.wmv (1 min 47 sec)
bill34207 is offline Find More Posts by bill34207
Latest blog entry: Freewing F-5N Tiger 80 mm EDF
Old Jun 10, 2012, 02:17 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
The props are X447 and X447R but was only running 5s this outing. CG was at about 31% and timing set at 7.5 degrees to play it safe since I'm not sure if they are Y or D winds.
bostong is offline
Find More Posts by bostong
bostong's Avatar
Danmark, Sjælland, Sorø
Joined May 2011
First it wanted to dive, now it wants to fly
Nice improvement, looks good..
bostong is offline Find More Posts by bostong
Old Jun 10, 2012, 02:28 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
After parking my Falcon early early grabbed the 5s packs from it to make one last run on the Cheetah today. It wound up being pretty short lived as well.
06-10-12 Cheetah 4.wmv (0 min 45 sec)
Old Jun 10, 2012, 02:31 PM
madphil is offline
madphil's Avatar
bolton england
Joined Jan 2009
Bill the last vid is a big improvement it looks to me like you can go bigger on props now i think you can try x447's (may have to cut ears to reduce lift but worth trying first)
we have found running a stinger setup the props don;t get as much "bite" because the sponsons part the water so theres a bit less in the water at speed
EDIT :- just seen your last post not sure about props now i am running the same motors in my 41" falcon its maxing out at 64 - 65 mph with x447's with very little hull in the water at full speed ,
whats the running weight with 2 x 6s packs ?
Old Jun 10, 2012, 03:59 PM
Pseudonym is offline
Find More Posts by Pseudonym
Pseudonym's Avatar
Joined Apr 2012
Have you tried props outward, stingers at zero, COG back as far as you can get it?
Pseudonym is offline Find More Posts by Pseudonym
Old Jun 10, 2012, 04:41 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Hull with all hardware & hatch was 7 lbs 10 oz.
The pair of 5s 5000's I used today weigh 3 lbs 2 oz so... 10 lbs 12 oz or 4.9 kg.
Old Jun 10, 2012, 04:46 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
1st run was with the stingers at 0 and 31% cg. 2 nd was with all the up I could get into them with 1.5 oz lead in the tail. Probably dropped it to 30 %.
Third vid I tried spinning them out instead of in and that loosened it up. Actually I did that (off camera) prior to the vid and blew it over before removing the lead that was added on run two.
Old Jun 10, 2012, 04:55 PM
Pseudonym's Avatar
Joined Apr 2012
Was the outward prop run with the stingers at zero?
Old Jun 10, 2012, 05:19 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
They were still a bit positive, up at the prop end.
Good news is I was able to get the broken flex out by pulling the port side stinger. (Went ahead and pulled both as I plan to shorten them about 3/4 to maybe a full inch and set them up with speedmaster bushings)
Bad news is I have to sharpen and balance a new prop and get a fresh pair of flexes..
Old Jun 10, 2012, 05:33 PM
Pseudonym's Avatar
Joined Apr 2012
I think you will see more speed when you shorten them. With the stingers at a positive angle, it moves the prop up, just like moving a strut up. The longer the stinger, the further up the prop moves from this adjustment. When you get the shorter stinger back on try it at zero with the props spinning outward. The props will be closer to the sponson and lower in the water, which should lift the hull out of the water better, even without the angle.
Was it the right lay or normal lay cable that broke? You should be able to use the other flex still, right?
Old Jun 10, 2012, 06:12 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I had meant to ask if you had the one you built for Ben spinning out or in but let it slip my mind until now. Which way were you spinning them?
I'll go back to 0 when I put it back together. Gotta order a couple of bushings for it and lightly ream the prop end so a piece of 1/4" tube will go in for the bushing to run in.
It was the standard lay that let go but going to replace both while I'm at it. I found my spare Hughey reverse cable (from Goldfinger) a couple of days ago and would like a longer stub than what is on the ones that were in it.
Old Jun 10, 2012, 06:22 PM
Pseudonym's Avatar
Joined Apr 2012
It's been a few boats, but I'm relatively sure I had them spinning out.
Dont throw that reverse shaft away...you can always use it on something else.
Old Jun 11, 2012, 05:51 PM
madphil is offline
madphil's Avatar
bolton england
Joined Jan 2009
Bill thanks for the pics , this is good news i would go with pseudonym shortening the stingers will help the ride and also help with turns
the weight is good its just a case of getting it up out of the water look at prop angle then you may have to play about with props to find what works on that hull maybe even 3 bladers
i also run props spinning outwards just for the record
Build Log Cheetah - Drambuie On Ice RayR Racing Boats - Electric 91 Dec 21, 2015 05:33 PM
Sold Seagate Cheetah 15K.5 300 GB,Internal (ST3300655SS) Hard Drive wrathofkhan Non R/C Items (FS/W) 3 Mar 29, 2012 12:31 AM
New Product Cheetah 70c 7000mah lipo bob2005 Product Announcements 0 Mar 25, 2012 03:55 PM
Wanted Cheetah or Super Cheetah mustang mark Aircraft - Sailplanes (FS/W) 5 Jan 31, 2010 02:42 AM
For Sale NIB Super Cheetah Kit by Cheetah Models surfimp Aircraft - Sailplanes (FS/W) 11 Jun 04, 2004 09:29 PM
