Old Jul 08, 2012, 05:04 PM
bill34207 is offline
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Chop slows a boat down regardless of what anybody says. This one GPS'd at 60 last Sunday when my video camera was broke. Today it was about 3 mph slower.
Fightercat Cheetah 6s Twin (2 min 18 sec)
bill34207 is offline Find More Posts by bill34207
Latest blog entry: Freewing F-14 Tomcat Build
Old Jul 08, 2012, 05:51 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Here's a 5s run on the Cheetah running the offset offshore course. Could have used a little more zoom with the camera. (almost looks like a GoPro but without the hi-def) Thought it hit a thermal or LVC on one of the motors but turned out to be the steering servo broke loose from the hull.
Fightercat Cheetah 5s Twin (3 min 57 sec)
Old Jul 08, 2012, 10:13 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Runs very well Bill........................do I hear WOT cornering??
scorpion1 is offline Find More Posts by scorpion1
Old Jul 09, 2012, 05:45 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Thanks scorp. I ran it 3 times yesterday. 6s - 4s - 5s. On 4s and 5s there is no need to let off the throttle. 6s is kind of iffy in the corners. Most of the time it will turn, but sometimes have to back off a little to get it to go.
Old Jul 22, 2012, 07:52 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Gonna go ahead and get this one out of the way. A very short GPS run of the Cheetah on 6s with the counter rotating X447's. Pushed it past 60 but not for long in todays east wind chop.
07 22 12 Cheetah (0 min 41 sec)
Old Aug 12, 2012, 03:30 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I know, it's a bump on a "done built" thread but was still pretty happy with todays GPS run.
08 12 Cheetah 6s (2 min 25 sec)
Old Aug 12, 2012, 09:22 PM
Pseudonym is offline
Find More Posts by Pseudonym
Pseudonym's Avatar
Joined Apr 2012
How's your current draw Bill? 450/3's and you would probably get her over 70, just for (bowel movements) and giggles. The Cheetah hull can handle some big props, and it will get the hull a little further out of the water too.
Pseudonym is offline Find More Posts by Pseudonym
Old Aug 12, 2012, 11:01 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Man, another smokin Cat from Mr. Hunt................ you are officially hooked on Cats. You outta throw the x450/3's on there as Keith suggested if you have room left amp-wise. Another fine boat Bill!
Old Aug 13, 2012, 06:26 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
No data logging capabilities on this one but the 4000 ma packs were showing 3.8v per cell when I put them on the charger for storage mode after that 7 lap run. Both packs were the same as I finally added in the balancing wires for 2p use. The outboard motor was around 120*, the inboard side a good 20 degrees warmer.
Originally Posted by scorpion1 View Post
Man, another smokin Cat from Mr. Hunt................ you are officially hooked on Cats. You outta throw the x450/4's on there as Keith suggested if you have room left amp-wise. Another fine boat Bill!
Thanks scorp. I seem to have pretty good luck setting up cats. The usually run cleaner than my monos. Jumping from 447/2's to 450/3's is a pretty healthy increase in prop area. Might get away with it for a few saw passes but wouldn't want to try running oval with them. I found out on the 1st lap that it would not turn (AT ALL) at full throttle with the 447's like it would with the 442's. Had to remember to back down to about 3/4 going into the turn or it would keep going straight.
Old Aug 13, 2012, 09:07 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Nice job on the balance leads....................What's with the props inside the hull.......................you keep your spares there?
Old Aug 13, 2012, 09:59 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Those are the ones I run on it. I pull the shafts and wipe them down after a day of running then just stick them in the boat they go to until prepping for the next run day.
Old Sep 22, 2012, 06:05 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Ordered a set of the CNC 45 mm aluminum props from OSE last week to try on this one tomorrow.
I'd have to agree that you don't have to worry too much about balancing them since they don't weigh enough to be able to tell if they're off with my balancer. They did get a bit of sharpening and polish though. When they came out of the bags the leading edges were pretty thick. Don't know how well they will hold up as they were super easy to work. Think I spent about 30 minutes on the 2 props combined.
Old Sep 22, 2012, 06:43 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
I like the shiny stuff too.....................getting tired of the drabby brass color and breathing in tons of berylium dust...................(i wear a mask )
I have one really pretty Chrome x460/3 and a 6017 from Dasboata............dont run them though
Old Sep 22, 2012, 06:44 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Got any Super 8's or Motel 6's near you Bill? Near Tampa right?
Old Sep 22, 2012, 07:16 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
There's a 8 not too far from my place and a Howard Johnsons too. Not sure I'd want to recommend them to a friend though. Unless they have been "cleaned up" recently there's lots of undesireable people that use them. A little further down the road there's a Holiday Inn. Not sure of what the rates are though. Winter months are "tourist season" here and accomodations can get pricey.
I live about 50 miles south of Tampa in south Bradenton, and Ackerman Park is in Sarasota off Fruitville Road. (about a 20 minute ride for me)
Build Log Cheetah - Drambuie On Ice RayR Racing Boats - Electric 91 Dec 21, 2015 06:33 PM
Sold Seagate Cheetah 15K.5 300 GB,Internal (ST3300655SS) Hard Drive wrathofkhan Non R/C Items (FS/W) 3 Mar 29, 2012 01:31 AM
New Product Cheetah 70c 7000mah lipo bob2005 Product Announcements 0 Mar 25, 2012 04:55 PM
Wanted Cheetah or Super Cheetah mustang mark Aircraft - Sailplanes (FS/W) 5 Jan 31, 2010 03:42 AM
For Sale NIB Super Cheetah Kit by Cheetah Models surfimp Aircraft - Sailplanes (FS/W) 11 Jun 04, 2004 10:29 PM
