Old Apr 26, 2012, 07:43 PM
bill34207 is online now
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Build Log
Fightercat Cheetah - Red Bull Twin
My Cheetah hull arrived today. I have to say the packaging on these is nice.
It's really light (almost scary light) The hull & hatch by themselves come in at 3 lbs and less than an oz. It's just a hair too long for classing as a P boat by NAMBA specs though. Mine measures at 34 and 1/16". Close enough in my book but a real stickler for rules could still bust you in a race determining situation. If you're going to run P, better take a sanding block to the tips of the sponsons or something. Since my plans are for Q it's not an issue for me.
I'm looking at making it a twin so will only be able to run 1p on the packs. (One downside) I won't be able to use a single 6s pack per motor either. The only place big enough to slip one of my 5000 ma 6s packs in is at the rear where the rise in the hull is (and where the motors will be). A couple of 3s packs in series can be slid in up front with no problems though.
bill34207 is online now Find More Posts by bill34207
Old Apr 26, 2012, 08:50 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
What motors?
scorpion1 is offline Find More Posts by scorpion1
Old Apr 26, 2012, 09:03 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Originally Posted by scorpion1 View Post
What motors?
I'm thinking the same thing as madphil has in his Falcon. The HET 700-68/1680's or possibly go to the 1500's for better run times. I have local supplier for them with William from turbofanelectrics.com He'll treat me right on them even though I haven't bought a lot from since getting more into boats than jets.. He has the 1500's in stock but would have to order in the 1680's if I want them.
Latest blog entry: Freewing 80 mm Mig 21 Fishbed
Old Apr 26, 2012, 11:14 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
You may consider saving some big bux and checking these out................they would really rock on 6s!!
http://www.hobbyking.com/hobbyking/s..._Inrunner.html
Old Apr 27, 2012, 02:29 AM
madphil is offline
Find More Posts by madphil
Lets get the HUEY up
madphil's Avatar
bolton england
Joined Jan 2009
looks good bill ,
you can use your 6s packs if cut off the heat shrink split the packs into 2 x 3s packs then re heat shrink the packs the balance wires and connecting leads are long enough to do this without re soldering we do this in racing because a single 6s pack is lighter than 2 x 3s packs and you can still charge as a single pack
madphil is offline Find More Posts by madphil
Old Apr 27, 2012, 05:35 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Definately cheaper. Could probably get 3 of those for the price of one HET or 6 for the price of one Neu 1515. Not impressed by the specs on them though. Rated for 4s max and only 815 watts.
Even though I haven't tried the 700 series, I've used many of the smaller HET's in 70 mm edf's and they hold up well spinning high rpm's. I had one of their 28mm motors (2W-20) that made more watts in a 70 mm fan than the Turnigy's are rated for. Still have the motor although the airframe suffered from "sudden deceleration trauma" a couple of years ago.
Old Apr 27, 2012, 07:15 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Bill, those bogus HK specs cant be trusted............... you can set it up to pull around 60-70 amps(rated at 55), on 6s that's about 1500 watts which is more reasonable for that size motor.
Those HET's do look good though.................
Old Apr 27, 2012, 07:51 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Here's the HET spec sheet for the 700-68 series. http://www.highendrc.com/member/3170...8motorspec.pdf
William tells me he's pulling close to 4000 peak watts on one of the 1500kv in a 90 mm fan.
Old Apr 27, 2012, 08:09 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Are they 36mm dia. or 39 +/- ?
Old Apr 27, 2012, 08:48 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
The 700 series are 39 mm the 600 series are 36 mm. I have a couple of the 600's still in use in mild (1700 watt +/-) 90 mm edf setups.
Here's one
Sniper90-2.wmv (5 min 29 sec)
Old Apr 27, 2012, 10:55 AM
Pseudonym is offline
Find More Posts by Pseudonym
Pseudonym's Avatar
Joined Apr 2012
Any plans on what you are using for hardware yet?
Pseudonym is offline Find More Posts by Pseudonym
Old Apr 27, 2012, 12:00 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Just ordered a couple of these for stingers. http://fightercatracing.com/index.ph...emart&Itemid=1 (same as used on the DF Explorer when I built it) I had a couple of Speedmasters laying around but they are too tall for the sponsons with the overhang above them. Haven't decided on a rudder just yet. I need to see how far back the stingers will be in relation to the overhang before deciding on amount of setback needed for this hull.
Old Apr 27, 2012, 12:37 PM
Pseudonym's Avatar
Joined Apr 2012
Those stingers will definitely put the props well behind the hull. Fighter cat has another stinger that is shorter than the 110mm, did you see those?
Old Apr 27, 2012, 01:06 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
The shorter 78 mm he has two different ones of. The mono stinger is about the same size as a speedmaster and too tall. The other one is for a 4 mm shaft. I like running the .187 (3/16") size for a better prop selection.
Old Apr 27, 2012, 01:29 PM
madphil is offline
madphil's Avatar
bolton england
Joined Jan 2009
they are 39mm most of the guys in our racing club use HETs big power for the size not cheap but i think worth the extra money , they also do a longer 92mm x 39mm can,
a bit more power they can all stand high RPM without problems and good run time
Build Log Cheetah - Drambuie On Ice RayR Racing Boats - Electric 91 Dec 21, 2015 05:33 PM
Sold Seagate Cheetah 15K.5 300 GB,Internal (ST3300655SS) Hard Drive wrathofkhan Non R/C Items (FS/W) 3 Mar 29, 2012 12:31 AM
New Product Cheetah 70c 7000mah lipo bob2005 Product Announcements 0 Mar 25, 2012 03:55 PM
Wanted Cheetah or Super Cheetah mustang mark Aircraft - Sailplanes (FS/W) 5 Jan 31, 2010 02:42 AM
For Sale NIB Super Cheetah Kit by Cheetah Models surfimp Aircraft - Sailplanes (FS/W) 11 Jun 04, 2004 09:29 PM
