UK, Cardiff
Joined Dec 2008
I dont think your clear on what it is you are trying to do.
You cant take a normal conventional Video\Audio link and somehow add FSK (as in direct data) modulation to it, although you can use the audio link for the likes of RTTY, Morse etc. |
UK, Cardiff
Joined Dec 2008
I have just built something along those lines, a GPS tracker that transmits location and\or distance and direction from home. http://www.picaxeforum.co.uk/showthr...on-Calculation I went the Morse route since you can decode slow speed morse numbers easy enough by ear and the unit has a ground range LOS of circa 20 miles. The module has a TX power capability of 100mW, which does not sound a lot, but there are similar beacons in orbit, flying at an altitude of 450miles, that can clearly be heard on terra firma. |
Canada, ON
Joined Jan 2009
Can you post those files? As I dont want to join yet another forum.
I just made this up, haven't tested it yet though. Quote:
And the ground station code is just as simple. So all you do is connect the rx to the gps unit and ground. Run this and check the serial monitor. If you want to use the modem then you should really put a filter. ![]() I will hopefully order some arduinos this weekend and play around with it next week, see if I can get it to work fine. This is just a really dirt cheap way of telemetry. |
Then you will have a FSK signal on your ground station, so you can either use another arduino to demodulate it and then use Earth Bridge to map it onto google earth.
That's basically what it does.. |
UK, Cardiff
Joined Dec 2008
What the Video appears to describe is actually RTTY using audio tones. This is audio frequency shift keying (AFSK) which and can indeed be sent down the audio channel.
FSK is something different, look it up. I have tried AFSK RTTY and I found the performance of the link no better (for this sort of application) than high speed Morse. Once you have the routines working its easy to switch to slow speed Morse which can be read by ear at 4 to 5 times the distance of PC\Micro based automatic decoders. |
I didn't realize there was a difference, I guess I will go for morse code due to your investigations. What kind of frequencies are you getting? |
| Thread Tools | |
| Discussion Has this been done that anyone knows? | dale4040 | Waterplanes | 30 | May 26, 2012 06:56 AM |
| Discussion Has anyone done a DIY CNC machine to cut out foam? | NeveSSL | Foamies (Scratchbuilt) | 6 | Nov 15, 2011 10:14 PM |
| Discussion has anyone done a wing with floats? | THESANDMAN | Foamies (Scratchbuilt) | 0 | Oct 17, 2011 02:26 PM |
| Discussion Has anyone done the DX7 DSM2 to DSMX | FlyorBust | Electric Plane Talk | 0 | Sep 26, 2011 11:45 AM |
| Question I am just wondering if anyone has done or seen a um t-28 on floats? | skarface | Micro RTF | 2 | Sep 18, 2011 09:39 PM |
