Old Apr 26, 2012, 11:34 AM
tdogg77 is offline
Find More Posts by tdogg77
Joined Dec 2006
New to DLG - First Glider Suggestions?
I like the ELF from Kennedy Composites, but it seems pretty expensive. Is there a reasonable, lower-priced starter DLG alternative?
Thanks!
tdogg77 is offline Find More Posts by tdogg77
Old Apr 26, 2012, 11:46 AM
like.2.fly is offline
Find More Posts by like.2.fly
Mike M.
like.2.fly's Avatar
United States, UT, Eden
Joined Jan 2010
-Alula
-Wright Brothers Gambler
-Mountain Models DL-50
-QuickFlick II
-TopSky mini
Or get a real DLG:
-TopSky 1 or 2
-Predator 2
-Find a used "bagged" DLG for a good deal
like.2.fly is offline Find More Posts by like.2.fly
Old Apr 26, 2012, 12:57 PM
samson55 is offline
Find More Posts by samson55
samson55's Avatar
United States, IL, Rockford
Go with the gambler or quick flick if you are good at building. They have great breeze penetration. I fly my Topsky mini a lot with good success, but she is on the lighter side. The ELF is too much money IMO and you could get a better DLG for the same money and fly on non-calm days too.
Originally Posted by like.2.fly View Post
-Alula
-QuickFlick II
-TopSky mini
Or get a real DLG:
-TopSky 1 or 2
-Predator 2
samson55 is offline Find More Posts by samson55
Old Apr 27, 2012, 09:42 AM
tdogg77 is offline
Joined Dec 2006
To clarify - I think I would like to buy a glider that qualifies for F3K competition. What would be a good first F3K glider?
Old Apr 27, 2012, 09:48 AM
browncbr1 is offline
Find More Posts by browncbr1
Craig B
browncbr1's Avatar
United States, TN, Knoxville
Joined Mar 2009
If you think $200 is expensive, then you might not want to take the F3K drug..... before you know it you will be spending $700-800 minimum on each model.. The only 1.5m F3K ships I know of that are around $200 are Topsky and predator... I recommend you start with one of these models, particularly to develop your building skills...
browncbr1 is offline Find More Posts by browncbr1
Old Apr 27, 2012, 10:20 AM
davidjensen is offline
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
Often you can go to the local contests and find a used DLG or look at the classified section for one. A budget of $200 is not realistic in the long run.
davidjensen is offline Find More Posts by davidjensen
Old Apr 28, 2012, 09:43 AM
homer49 is offline
Find More Posts by homer49
Bob Olson
homer49's Avatar
Granger, Indiana
Joined Nov 2006
starter?
Around early '08 I was having this discussion with a friend of mine about entry level DLG's - had watched the nats and one other contest - was contemplating an art hobby design when my friend said that if I did'nt jump in with both feet, I would be dissapointed with the outcome. He told me that if I went below a certain level, results would not be what I expected. He talked me into buying a Blaster. His reasoning was that I was already pretty old and you only live once. Since then I have had 6 blasters - that was when the Blaster's were about the cheapest - before the topsky's - Flew by myself for months - finally got some help and pointers from my friend, entered my first contest and placed second in Novice. ( got beat by some young punk named David A. !!!!) Had Lorry Green for a coach at the polecat - was in 10th place at the NATS after the frist day, got buried on the second! - - - Bottom line is that I have had the greatest time imaginable with DLG's in all the 48 years since I started flying R/C. Also, the cost/benefit per hour of stick time is the cheapest of anything else I have ever been involved in. You simply can't imagine the fun you will have until you take the plunge!! SAVE UP AND GO FOR IT - YOU WON'T BE SORRY!!!!!!!! Bob O. .
homer49 is offline Find More Posts by homer49
Old Apr 28, 2012, 10:56 AM
tdogg77 is offline
Joined Dec 2006
What would you buy if you were getting into it now?
Old Apr 28, 2012, 11:20 AM
Will fly for food
Bellevue WA,
Joined Dec 2003
If all you had was a radio you can get a good used DLG for $300 to $400. If you want to buy new they start at about $500
This is what I would do if you went new
Topsky 2 disser $350 to $400
3 to 4 servos at $25 = $100
Receiver = $75
battery = $20
The other alternative is the Gambler and the DL50. Both are 2 channel (rudder elevatror).
Help! CNC Machining Plugs for NEW MINI DLG RC Glider RobertTHaas Composites Fabrication 1 Sep 14, 2011 06:59 PM
Discussion First DLG glider zackesch Hand Launch 15 Mar 02, 2010 06:36 AM
Discussion My first try building a > 1m DLG depron glider Markus A. Hand Launch 1 Aug 10, 2009 12:27 PM
Discussion Ma First DLG glider RC flight Hand Launch 6 Feb 28, 2007 09:24 PM
Question HLG/DLG Choices for First Glider cactus Hand Launch 27 Jan 25, 2007 02:27 PM
