Old Apr 26, 2012, 07:14 AM
Bill Smudge is offline
Find More Posts by Bill Smudge
Bill Smudge's Avatar
United States, KY, Bowling Green
Joined Jul 2011
Question
Anybody use this wattmeter? Multi-function Wattmeter FD-WM
Hi Guys,
I came across this wattmeter on Ebay, I'm trying to get some opinions about it. Anybody out there have any experience with one?
http://www.ebay.com/itm/150633905792...84.m1438.l2649
Thanks Much,
Bill
Ok I bought one review on last post
Bill Smudge is offline Find More Posts by Bill Smudge
Last edited by Bill Smudge; May 18, 2012 at 06:53 PM. Reason: I bouhgt one reveiew on last post
Old Apr 27, 2012, 01:32 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Hi Bill, I've never used it but here's my comments FWIW.
Rated for 100A, however, I don't see a spec for how long. The absence of any
visible heat sink of any size would make me think the time limits are pretty short.
You might question the seller for that info.
hoppy is offline Find More Posts by hoppy
Old Apr 27, 2012, 09:33 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
HK sells a sim gizmo.
Bought one it was DOA, "finally' got a warranty claim.. Replacement half works
Caveat Emptor Kids.
Bare is offline Find More Posts by Bare
Old Apr 28, 2012, 06:57 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
So that is just for real time display, right? It does not record any data or anything? And I guess silver cylinder is the thermal probe?
As always, cheaper is an attractive quality. But I already have an eLogger and that brings up a need for it to also be viewed in comparison to that. This looks like another case where cheaper and better (or even as good) are mutually exclusive qualities.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Apr 28, 2012, 07:40 AM
Joined Jul 2011
Jack
Hey Jack,
I'm cheap, what can I say
, but it is fairly small, you can send it up with some planes.
You never know about some of this stuff until somebody trys it....it does have a temp prob (for what that is worth), it just looks halfway neat to me.
I'm hopeing for some first hand usage feedback.
Woud be nice if we could get a comment from somebody that has one.
May be a better than just a real time display, here is the "manual":
I might bite the bullet and buy one and give a review of the darned thing!!
Bill
FD-WM Manual
Features
The FD-WM is a style of miniature multi-function wattmeter, which is small volume and lightweight. It can be used on the R/C model to check the real-time current, voltage, watt and temperature, and also it has a battery voltage acoustic-optical alarm function, It can also record the maximum current, watts ,temperature and the minimum voltage. Users can easily understand their R/C power system via this item.
Specifications
FD-WM Voltage (V) Current(A) Temperature (℃)
Dimension:8029.47.9mm Measuring Range:7.4~45v (2~10s Lipo) Measuring Range:0A~100A Measuring Range:-20℃~100℃
Weight: 25.6g Resolution:0.1V Resolution:0.2A Resolution:0.1℃
Joint: T type Alarm Range:4.0V~49.9V Alarm Range:3A~99.9A Alarm Range:20℃~89.9℃
Packing: Plastic Initialize Alarm:9.9V Initialize Alarm:20A Initialize Alarm:50℃
LED State
All LEDs off: Wattmeter displays scrolling voltage, current, watt values and temperature.
V LED on: Displays real-time battery voltage.
A LED on: Displays real-time battery current Amps.
W LED on: Displays real-time battery output power in watts.
C LED on: Displays real-time temperature.
The corresponding LED will flash while alarming, and buzzer keep the beep ring
Operation
1. Connect the Wattmeter between the battery and the ESC. It will read the real-time voltage,
current, temperature and calculate watts. Press the right key each once, the wattmeter will change
between above states.
2. Press the left key, the wattmeter can get the minimum voltage, maximum temperature, current
and watts of this flight.
3. Press the left button more than five seconds in any state, the wattmeter will go into the alarm
setting state, via the right key to set the alarm extreme value, and then press the left key to confirm
and the right button for increasing, setting succeed, then press the left key to exit setting.
Old Apr 28, 2012, 08:09 AM
Jack
USA, ME, Ellsworth
Joined May 2008
OK, reading the manual has it sounding better already. It will probably remember all the data summaries mentioned until it is disconnected from the battery and that is good enough for a lot of purposes.
The temp probe would probably be good for taping to a battery pack but not so good for getting it to the windings or base plate on a motor.
It's another gadget that works out on OK when you can find a good use for it.
If you look at the eBay seller's listings, he has some other interesting RC stuff too.
Jack
Old May 18, 2012, 06:52 PM
Joined Jul 2011
Ok I bought one, looks pretty good!!
I got a chance to talk to a couple of fellas that bought one of the
Multifunction Wattmeter FD-Wm on Ebay, they had a pretty good review of the little wattmeter. I ordered one on May 8th and it got here today China Airmail, 10 days, not bad at all!!
The little widget has pretty good functionality, will scroll display battery volts, amps, watts and temp probe temp. Or you can lock the display on any one of the four items and read it real time. Also it remembers the highest peak reading during a run and will hold it until cleared.
Weighs 28 grams with temp probe and 26 without. You can send it up with larger planes to record peak readings, you can see its not too big using my hand for a reference.
Last but not least it can be set to alarm on low voltage, over current, over wattage or overtemp. Turns on a little beeper when that happens.
I have to say for $18.93 looks to be a pretty darned good deal...., that being said I have no idea how accurate the readings are but for my use it should more than suffice.
It can be found here if interested, this is the place I got mine in 10 days.
http://www.ebay.com/itm/Multi-functi...item1e6c4aa2d8
Best to all,
Bill
Old May 19, 2012, 07:27 AM
Jack
USA, ME, Ellsworth
Joined May 2008
Looks like a good one, Bill.
The temp probe is detachable, right? If you can use an multimeter and measure the resistance across that (it is a thermistor I think) you may find that you can make your own better and smaller temp probes and with longer leads. That will let you put them into places like the cooling slots on a brushless motor.
You read more about that here:
DIY Sensor for EagleTree eLogger.... - http://www.rcgroups.com/forums/showthread.php?t=1526363
Jack
Old May 19, 2012, 07:47 AM
Joined Jul 2011
Jack
Yes Jack, the temp probe comes off, reduces weight by about two grams..
Thanks for the DIY sensor link.
Bill
Old Sep 19, 2012, 04:26 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Bill,
Have you been using that? Maybe you can answer a couple of questions?
Does it remember the highest values for V, A, W, and C and can you review those at the end of a flight?
And if it is powered off and back on will it remember the last recorded highs?
Or does it clear and reset itself on each power up.
Thanks for the help on this interesting little device.
Jack
Old Sep 19, 2012, 05:29 PM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Originally Posted by hoppy View Post
Rated for 100A, however, I don't see a spec for how long. The absence of any visible heat sink of any size would make me think the time limits are pretty short.
It appears to be using an Allegro 100A hall sensor, which has a shunt resistance of 0.1 millohm. At 100A the Deans connectors will heat up more than the sensor!
LEDs draw a fair bit of current, so hopefully it has a switched mode regulator to power the display circuit.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Sep 19, 2012, 08:28 PM
Joined Jul 2011
Bill,
Jack
Hey Jack,
Yes I have been using fd-wm, yep it does remember the peak values of each powered on sesion--- V, A, W, and temp, you can review them after a flight or test sesion. It has complete memory loss after the battery is disconected (hey what do ya want for 18 bucks), even can be set to alarm on low voltage, etc.
I think it's quite a steal, to date I've never sent it up with a plane, but I could on some of my larger ones. I just use it for prop testing and current testing.
I'm surprised more folks haven't picked up on this little jewel.
Bill
Old Sep 19, 2012, 08:34 PM
Joined Jul 2011
Bruce your right I've never noticed any heat out of the device while testing motors, that being said I've never had current running through the device for any length of time. I need to give that a try and report back.
Bill
Old Sep 19, 2012, 08:52 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Thanks, Bill.
it was more a case of curiosity for me. I have the eLogger and that records, has an PC application, and the other bells and whistles. But FD-WM would be good for quick measurements in the field and stuff.
Sold Turnigy Multi Function Switch flyandi Aircraft - Electric - Power Systems (FS/W) 1 Apr 22, 2012 06:09 PM
Discussion Has anybody used this set up? RC-Tech 2.4GHz / 10mW video transmission set BlizzardWhite FPV Talk 2 Nov 20, 2011 04:23 PM
For Sale 7 Function Digital Multi testor for the modeler unclegeorge Aircraft - General - Miscellaneous (FS/W) 0 Oct 14, 2011 08:49 AM
Sold 7 Function Digital Multi testor for the modelers!!! unclegeorge Aircraft - General - Miscellaneous (FS/W) 0 Oct 08, 2011 12:42 PM
Sold Align Multi Function tester badbill Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 04, 2011 12:28 PM
