Old Apr 26, 2012, 07:28 AM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
detecting thermals
what do you know about telemetry for detecting thermals?
i have seen something with 'winged shadow'. has any1 tried it?
any other equipment?
should be interesting for all to hear about it.
or is there a thread on it already? where?
thanks
phil alvirez is offline Find More Posts by phil alvirez
Old Apr 26, 2012, 07:42 AM
Kenny Sharp is online now
Find More Posts by Kenny Sharp
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
I'd say that that sort of thing is a good learning aid.
I tried an Eagle Tree years ago... I could always tell I was in lift before I was notified.
Admittedly, I was always under 400 feet.
Way up high, it would probably be very useful for cross country flight.
Kenny Sharp is online now Find More Posts by Kenny Sharp
Old Apr 26, 2012, 11:47 AM
Gary Evans is offline
Find More Posts by Gary Evans
FPV Desert Beta Test Center
Mesa, Arizona
Joined Nov 2006
I use one on my FPV Bird of Time with an ear bud speaker. The audio is picked up by an on-board mic and sent to my ground station. I also use a Range Video OSD which has a analog bario vario and the two are in perfect sync. For FPV thermaling an audio vario is IMO very helpful.
This is a recent clip.
http://tinyurl.com/7t37u3b
Gary Evans is offline Find More Posts by Gary Evans
Old Apr 26, 2012, 12:11 PM
Leadchucker is online now
Find More Posts by Leadchucker
AMA7224 LSF1832
Leadchucker's Avatar
United States, DE, Seaford
Joined Sep 2008
Good heavens man, how do you listen to that for any amount of time? While I can appreciate it's job, that tone would drive me barking mad in short order. Nice ride none the less
Leadchucker is online now Find More Posts by Leadchucker
Old Apr 26, 2012, 12:21 PM
Mesa, Arizona
Joined Nov 2006
Then you wouldn't like a real sailplane because that's the music of cross country thermaling.
The volume should be just high enough to hear.
Old Apr 26, 2012, 12:24 PM
Harry D is offline
Find More Posts by Harry D
TLAR Aviation
Harry D's Avatar
Canada, AB, Edmonton
It would drive me "barking mad" too, in a few minutes.
And I've always thought it would be a bit like fishing with dynamite.
But it no doubt provides a useful function, and would be interesting to experience. To each his own.
Harry D is offline Find More Posts by Harry D
Old Apr 26, 2012, 02:03 PM
Joined Jul 2007
great advice
that's great. could you provide details? as many as you can.
everything you can throw in.
diagrams, sources.
of course, we can lower the volume to be barely heard
Old Apr 26, 2012, 02:30 PM
Mesa, Arizona
Joined Nov 2006
diagrams, sources.
The audio function is a recent addition to the vario. It originally was not intended for for FPV and would only wag the rudder upon entering lift. It generates a line level audio signal that can be turned on/off at the radio and can indicate either up only or up/down. It doesn't come with a speaker so you need to install your own. Being a line level signal only ear bid sized speakers can be driven without amplification. I already had an on-board mic to monitor engine run so just installed the ear bud speaker right next to the mic. It is only turned on during thermaling.
To receive the signal at a ground station requires an on-board Tx and ground station Rx/speaker which you would already have for FPV. If your not doing FPV it would not be very practical because of the added hardware. For non-FPV use the rudder wag would be the ticket. There are varios that can send down the signal to a special receiver but they are way more expensive.
Old Apr 26, 2012, 02:47 PM
Joined Jul 2007
scout
thanks, Gary. very interesting.
i rather go for something like the thermal scout from winged shadow, with the circuit they suggest on the manual, and sends a sound very much like yours. it's here: http://www.wingedshadow.com/thermalscout.html
See the Data Output Mode Instruction Supplement for full details.
has any1 tried it?
Old Apr 26, 2012, 04:40 PM
Mesa, Arizona
Joined Nov 2006
has any1 tried it?
Sorry apparently I didn'take myself clear but that is the vario I'm using.
Old Apr 27, 2012, 02:14 PM
Belem is offline
Find More Posts by Belem
Foam flogger
Roseville, CA
Joined Apr 2009
I use the Thermal Scout. It does a pretty good job and I can see the wag at over 2000 ft agl. I haven't set it up yet to my telemetry module.
Belem is offline Find More Posts by Belem
Old Apr 27, 2012, 02:39 PM
r/cmark is offline
Find More Posts by r/cmark
200 mph club
r/cmark's Avatar
United States, AZ, Fort Mohave
Joined Mar 2005
Anyone else have oppions on the Thermal Scout ?
r/cmark is offline Find More Posts by r/cmark
Old Apr 27, 2012, 03:56 PM
Lancer31 is offline
Find More Posts by Lancer31
Joined Jun 2005
Doo-doo-dee-dee........
Almost as bad as some of the crap they call "music", these days, but at least it is passing along some intelligence!
Lancer31 is offline Find More Posts by Lancer31
Old Apr 27, 2012, 04:24 PM
Joined Jul 2007
kind of advice i needed
thanks for your input.
i will get 1 and see if that is all that i need to catch-and stay in-a thermal.
Old Apr 27, 2012, 05:10 PM
Belem is offline
Foam flogger
Roseville, CA
Joined Apr 2009
I know a couple of people here use them. Try this post in the Thermal section and you might get more hits. I find that it does a pretty good job signaling lift. Staying in it is another matter lol.
Discussion Tower Pro 30A ESC not detecting throttle coldboot Beginner Training Area (Aircraft-Electric) 11 Jul 29, 2014 10:47 PM
Discussion Looking for Water Level Detection System for Model Steam boats bfinduswlds Steam Boats 8 Nov 11, 2012 10:19 AM
Discussion Mini DVR Camera Video SD Card Recorder HD Motion Detect rimshotcopter FPV Talk 2 Apr 24, 2012 03:43 PM
Question Laterst HP22 software detected as a virus -S- Hitec/Multiplex USA 1 Apr 08, 2012 03:35 PM
Discussion Loss of signal detection? coveredup Hitec/Multiplex USA 2 Sep 21, 2011 11:57 PM
