Old Oct 22, 2012, 06:57 PM
gondoflier is offline
Find More Posts by gondoflier
Joined Jun 2012
Originally Posted by stanleyy View Post
hey,
it is not a starship with laser gyroscopes, it is a 500 Euro device I did about 30 flights with ecilop and I didn't observe any problems related to gimbal and wind. When I saw some wobble, it was always a problem of FC, not gimbal in the middle. We all are using quite cheap hardware (gyro/servo), so it is not a surprise that the results are not top-notch. I would also like to see a setup with military grade components, but I don't think someone is going to invest that much
At the moment it seems that we are unable to get Zenmus-like output from it (some shots are not far from it, but longer sequences are quite difficult to do). If that is what you are looking for, then you must search elsewhere.
I think Ecilop is a great piece of hardware and you won't regret if you buy it.
Stanleyy..I am also looking to get as much information as I can before getting a new frame. From what I've seen Nyc's hoverly combination looks very close to zenmuse if its not post stabilized. I think there is potential in this sort of stabilization but unfortunately its not completely tuned in by Alexey. I'm waiting to see more of the chinese clone and than decide what to do. I certainly wont spend zenmuse money even if I had it.
gondoflier is offline Find More Posts by gondoflier
Old Oct 22, 2012, 08:47 PM
InfinitR is offline
Find More Posts by InfinitR
United States, CA, San Diego
Joined Oct 2012
Just saying, I think it's better to support the original than clones. That better supports further innovation. But there is definitely a lot of config involved so I get that.
InfinitR is offline Find More Posts by InfinitR
Old Oct 23, 2012, 02:05 AM
Nordcopter is offline
Find More Posts by Nordcopter
www.flycamera.de
Nordcopter's Avatar
Joined Sep 2012
Originally Posted by nycewheels View Post
I have both lenses. The 16mm of course hides jerky movements better, the wider - the easier to get stable looking footage. The 18-55mm looks more natural but needs the rig to be dialed in better. If you think your rig is already perfect, slide the lens out to 55mm and fly again
Yes, the extra weight seems to help a little but i would rather strap on a larger battery than stacks of glass. An 18mm prime would be perfect for my needs.
Have you tried the 19mm Sigma? I haven´t put to the ecilop so far, but IMO it gives a lot better results in stills and movies than the stock 16mm.
Nordcopter is offline Find More Posts by Nordcopter
Old Oct 23, 2012, 04:50 AM
AliB is online now
Find More Posts by AliB
kitesurfer
United Kingdom, England, Hayling Island
Joined Dec 2005
Ecilop Testing. 5-7mph wind. dull light (3 min 30 sec)
AliB is online now Find More Posts by AliB
Old Oct 23, 2012, 04:55 AM
AliB is online now
kitesurfer
Joined Dec 2005
gonna put some more expo on the rudder to make it smoother, but i was just flying around to see what the footage would come out like. just converted from 1080 50p to 720 25p.
Old Oct 23, 2012, 05:16 AM
alek3d is offline
Find More Posts by alek3d
Slovakia
Joined Nov 2010
AliB,
that is looking awesome! :-) Great job setting up your gimbal! That is what I actually wanted to see. Thanks!
alek3d is offline Find More Posts by alek3d
Old Oct 23, 2012, 05:20 AM
stanleyy is offline
Find More Posts by stanleyy
Slovenská republika, Bratislavský kraj, Bratislava - Podunajské Biskupice
Joined Feb 2011
looks like your gyro+servo combo is working fine there is some offset caused by FC loop, but that is not so important.. looks good to me.
what about fast descend, how does it behave?
stanleyy is offline Find More Posts by stanleyy
Old Oct 23, 2012, 05:25 AM
AliB is online now
kitesurfer
Joined Dec 2005
heres wind readings from when i was flying... bout 830am-9
havent tried fast decent yet. not sure if ive got enough power to come out of a fast decent. did try a gps return to home. worked nice
Old Oct 23, 2012, 05:33 AM
stanleyy is offline
Joined Feb 2011
I didn't mean fall from the sky, just a normal usable descend.. My Naza is very stubborn and doesn't want to go down so easily.. And in most cases it wobbles when it is descending...
Old Oct 23, 2012, 05:34 AM
alek3d is offline
Slovakia
Joined Nov 2010
maybe there is some problem with PPM signal from Naza. Did you try to reduce speed to 200 or even 50Hz in Naza configurator?
You should also try to install custom firmware into GY520, there you can adjust really everything...
Naza DOES have really "bad" PWM for servos. Known issue about which DJI does not give a crap. I was told "Naza does not like some servos", what a joke!
Another known issue is descent wobble. You can't fix it. You can make it better or worse by settings, heavier copters wobble less but they do no matter what your settings are.
Check this out and turn your volume up to hear that crap. First part servo connected to MultiWii at 300 Hz, second part I reconnect roll servo to Naza at 400 Hz (refresh rate actually does not matter, Naza sucks at any freq). MKS servos a kind of work better with Naza.
Old Oct 23, 2012, 05:39 AM
stanleyy is offline
Joined Feb 2011
Originally Posted by alek3d View Post
Naza DOES have really "bad" PPM for servos. Known issue about which DJI does not give a crap. I was told "Naza does not like some servos", what a joke!
hm, I increased pitch/roll gains and the descend wobble improoved a lot.. but I agree, it is not what I expected from a device that costs 500 Euro with GPS.
What controller are you using instead of Naza?
AliB is online now
kitesurfer
Joined Dec 2005
not had any real wobbling while normal decending. could be due to using 11" prop instead of 12. higher prop loading.
i got my gains around 140 and attitude at 80ish
what does yaw gain change? not really played with that at all. just left it at 100
Old Oct 23, 2012, 05:45 AM
alek3d is offline
Slovakia
Joined Nov 2010
I am still using Naza. Except those two things is't a great controller otherwise (I had KK, MWCs and FreeFlight). Exceptional alt and pos hold, auto level, much better than MultiWii. I am lurking in Autoquad thread, that FC looks promising, but initial calibration sounds like a bit of headache. Pricing about same as Naza + GPS and a lot more features.
Old Oct 23, 2012, 06:50 AM
alainphoto is offline
Find More Posts by alainphoto
Japan, Tokyo, Chiyoda
Joined Oct 2010
Originally Posted by RedSky View Post
I've flown a NEX-5N with Samyang 14mm lens - 910g all up. It was only for stills and needed 3 batteries to balance it (so another 350g to the aircraft weight). It flew, using T-motor 4008s and 14x4.7 props but wasn't very sprightly. The Ecilop frame is pretty strong.
You'd need to redesign the landing gear for X8.
Hello Redsky
Can you please comment a bit more on your experience with a 910g payload ?
I also need a better lens (and camera) so I will be looking at similar payloads (even maybe 1.1kg ...)
I will probably wait for the octo, but I am afraid it will be a non-foldable monster to transport (no car in tokyo ...) ... so if I can make it with the quad ...
alainphoto is offline Find More Posts by alainphoto
Old Oct 23, 2012, 08:05 AM
nicodh is offline
Find More Posts by nicodh
Joined Jan 2011
If you mod the arms to be a 8 (not x8) you don't have to redesign the landing gear.
I have an idea, but not enough motors, time to build it. Easy build by the way, using the same style as ecilop frame. :-). So it won't look ugly.
nicodh is offline Find More Posts by nicodh
Discussion Five easy piece f-14 tomcat bobdaeronort Foamies (Scratchbuilt) 80 Oct 25, 2012 05:43 PM
Discussion Easy Glider VS Easy Glider Pro (what's different?) MkFn Electric Sailplanes 7 Nov 17, 2011 07:42 PM
Discussion Easi Glider film boca55 Serbia 0 Apr 20, 2008 04:46 PM
Discussion Spring Easi* in NZ harrys one Aerial Photography 8 Nov 14, 2007 01:22 PM
