Old May 10, 2012, 03:27 PM
tritan is offline
Find More Posts by tritan
Joined Apr 2007
Originally Posted by Zaitsevsky View Post
small 9V BEC
you might have the brand name?
Also thanks for shipping today, same day as I payed - very fast service.
tritan
tritan is offline Find More Posts by tritan
Old May 10, 2012, 03:29 PM
tritan is offline
Joined Apr 2007
Originally Posted by EndOfDays View Post
Hello
Finally I mounted a WKM on the Elicop Easy. If somebody else wants to do so, you have to mount the IMU on the frame, otherwise it will not fly, the damping would be too much.
works not much better than with the Naza (since you can rely on the GPS-hold).
best regards
Ferdinand
I dont have the manual of the WKM here but can you really mount it (FC) upside down?
EDIT- I found it @ page 12:
Notices: Do not mount the IMUI upside upside -down.
Aleksey: we need a mounting solution for our DJI WKM FC!
Old May 10, 2012, 03:37 PM
Zaitsevsky is offline
Find More Posts by Zaitsevsky
Zaitsevsky's Avatar
Vilnius, Lithuania (EU)
Joined May 2009
self made linear with 7809 chip
Originally Posted by tritan View Post
Zaitsevsky is offline Find More Posts by Zaitsevsky
Site Sponsor
Old May 10, 2012, 03:44 PM
EndOfDays is offline
Find More Posts by EndOfDays
EndOfDays's Avatar
Austria, Niederösterr., Eggenburg
Joined Jan 2010
The IMU is not mounted upside down, it is just mounted underneath the frame, but the top of the IMU is still on the top.
best regards
Ferdinand
EndOfDays is offline Find More Posts by EndOfDays
Old May 10, 2012, 04:26 PM
Zaitsevsky's Avatar
Joined May 2009
I think, that dia. must be measured at the marked position.
Originally Posted by mackayb_87 View Post
The diameter was 60mm.
Site Sponsor
Old May 10, 2012, 04:45 PM
~>Miha<~ is offline
Find More Posts by ~>Miha<~
~>Miha<~'s Avatar
Joined Dec 2009
Unfortunately only integer values (dpreview image embedded):
~>Miha<~ is offline Find More Posts by ~>Miha<~
Old May 10, 2012, 05:46 PM
mackayb_87 is offline
Find More Posts by mackayb_87
Joined May 2012
Ok, I measured the 20mm to be 62.5mm while the 14-45mm lens was slightly smaller (~58mm).
mackayb_87 is offline Find More Posts by mackayb_87
Old May 10, 2012, 09:01 PM
emarketwiz is offline
Find More Posts by emarketwiz
emarketwiz's Avatar
United States, NC, Mooresville
Joined Sep 2011
Ferdinand, did you mean to say that the DJI WKM is NOT much better than the NAZA?
emarketwiz is offline Find More Posts by emarketwiz
Old May 11, 2012, 01:38 AM
EndOfDays's Avatar
Joined Jan 2010
Sorry, you are right I just saw what I have written ...
With the WKM it is much easier to fly (compared to the Naza) because of the GPS-hold.
best regards
Ferdinand
Old May 11, 2012, 02:07 AM
Zaitsevsky's Avatar
Joined May 2009
An Ecilop Y6 with its safety and better FOV would be just great .......
I am working on the prototypes of other models and plan to present a new drone this year. However, it won’t use any radically new technologies yet. I also assemble Ecilop-2 drones for some of my clients. This is quite expensive and affordable for large companies only. In fact, it’s easier to assemble and configure such a drone than to describe how to do it in detail. It is not optimized for serial production, assembling, repairing.
Site Sponsor
Old May 11, 2012, 05:16 AM
kwe is offline
kwe
Find More Posts by kwe
kwe
Joined Nov 2010
Zaitsevsky:is the system scalable to work with small cameras like gopros for exemple?
wery nice job anyway
i've been following your work
i also tried the gyroscopic dic stab with old hard drives
it really needs 2 contrarotating discs to work fine
thanks!!!!
kwe is offline Find More Posts by kwe
Old May 11, 2012, 10:03 AM
Zaitsevsky's Avatar
Joined May 2009
To achieve balance with a GoPro you can add some additional weigh below.
thanks!!!!
Site Sponsor
Old May 11, 2012, 01:25 PM
Brombo is offline
Find More Posts by Brombo
Sardinia Multirotors
Italy, Sardegna
Joined Nov 2011
This is mine not finished yet
Brombo is offline Find More Posts by Brombo
Old May 11, 2012, 01:40 PM
Brombo is offline
Italy, Sardegna
Joined Nov 2011
Sorry, but dia. must be approx. 50-70mm
Sorry i apologize..
1) 14-42 the diameter is 57mm where is the red point and 59mm where is signed 14-42
2) Little 14 diameter 54mm
Old May 11, 2012, 01:46 PM
tonton1993 is offline
Find More Posts by tonton1993
Joined May 2012
Wath is you configuration, (motor, prop, batterie) ?
tonton1993 is offline Find More Posts by tonton1993
Discussion Five easy piece f-14 tomcat bobdaeronort Foamies (Scratchbuilt) 80 Oct 25, 2012 05:43 PM
Discussion Easy Glider VS Easy Glider Pro (what's different?) MkFn Electric Sailplanes 7 Nov 17, 2011 07:42 PM
Discussion Easi Glider film boca55 Serbia 0 Apr 20, 2008 04:46 PM
Discussion Spring Easi* in NZ harrys one Aerial Photography 8 Nov 14, 2007 01:22 PM
