Old Oct 13, 2012, 10:27 AM
TAP993 is offline
Find More Posts by TAP993
TAP993's Avatar
Joined Aug 2012
Originally Posted by Zaitsevsky View Post
You can read the manual of the gyro
Done plenty of that over the last month...Still can't reset the GA250, maybe I should put it in the freezer overnight to force a reset ?!
Here is as example of configuration:
Ecilop Easy, GY520 gyro, S9257 sevo, weak springs,
Well I found 1 GY520 gyro at a good price and will try that out. Will it be OK with the MKS9670A servos I got from you (& standard springs)?
TAP993 is offline Find More Posts by TAP993
Old Oct 13, 2012, 11:14 AM
Zaitsevsky is offline
Find More Posts by Zaitsevsky
Zaitsevsky's Avatar
Vilnius, Lithuania (EU)
Joined May 2009
I'm not using those gyros. It will be better to use HK401 or another one
Zaitsevsky is offline Find More Posts by Zaitsevsky
Site Sponsor
Old Oct 13, 2012, 11:07 PM
RedSky is offline
Find More Posts by RedSky
Australia, SA, Renmark West
Joined Sep 2011
Yes, that's been my experience, the cheap HK401B gyro and MG930 servo have produced the best results.
RedSky is offline Find More Posts by RedSky
Old Oct 14, 2012, 02:10 AM
alainphoto is offline
Find More Posts by alainphoto
Japan, Tokyo, Chiyoda
Joined Oct 2010
I'm planning to release octa, but I can't say when it will be.
I can't wait
I really hopes it will take a 1kg+ camera + lens load (1.5kg would be great). Please don't forget about the lens weight in your design. Nowdays light bodys are quite good in term of quality, but if you want good image quality you need to have good glass, that means most of the weight and the cost is in the front (500-600g sounds a good bet).
I also hope it will be some kind of foldable, that makes a huge difference in practice.
I also hope we'll have the parachute option !
Alain
alainphoto is offline Find More Posts by alainphoto
Old Oct 14, 2012, 03:10 AM
stanleyy is offline
Find More Posts by stanleyy
Slovenská republika, Bratislavský kraj, Bratislava - Podunajské Biskupice
Joined Feb 2011
I must only agree
stanleyy is offline Find More Posts by stanleyy
Old Oct 14, 2012, 05:21 AM
TAP993 is offline
TAP993's Avatar
Joined Aug 2012
Hmm, well the HK401s never turned up (ordered nearly 4 weeks ago), I think something must have gone wrong with the order. I'll try this GY520 and see how I get on when it arrives
Old Oct 14, 2012, 05:37 AM
AliB is online now
Find More Posts by AliB
kitesurfer
United Kingdom, England, Hayling Island
Joined Dec 2005
had some good testing this morning. ecilop flys sooooo much better than the mini650, before event talking about the gimbal ha.
i used exactly the same components, and the ecilop flys SOLID. hands free hovering in atti mode, and gps mode i can push the frame anywhere. never managed to get it so stable on the min650, and i believe this is due to the frame flexing.
gimabl wise, im using hk401b and mg930s. i have my roll perfect dialed perfect i think. but still not quite managed to get the pitch right. there always seems a little lag in the responce.
not sure if this is the servo or the gyro, or something else. tried 2 servos. and 2 gyros.
maybe i should try another servo.
AliB is online now Find More Posts by AliB
Old Oct 14, 2012, 11:09 AM
TAP993 is offline
TAP993's Avatar
Joined Aug 2012
Just a thought: I noticed that the springs were rubbing very slightly on the frame. I squeezed the ends with some pliers which gave greater clearance. I'm going to shim the pitch servo out a little too. This didn't cure my gyro problems, but rubbing could introduce a slight delay?
Old Oct 15, 2012, 04:53 AM
InfinitR is offline
Find More Posts by InfinitR
United States, CA, San Diego
Joined Oct 2012
Hello, very interested in this platform.
I am an APM2 user though. Can anyone confirm whether I can use APM2 gimbal controls with this gyro setup? Or do I need a separate gimbal controller? I've never used separate gyros before and am still trying to understand the interface.
Thanks.
InfinitR is offline Find More Posts by InfinitR
Old Oct 15, 2012, 10:02 AM
Ulda is offline
Find More Posts by Ulda
Czech Republic, Hlavní město Praha, Prague
Joined Sep 2012
Thanks.
I use the APM2 with Ecilop quite succesfuly. With Hk401b gyro and tgy930 servo. And hours of tuning and adjusting. And still not totally succesfull.
Ulda is offline Find More Posts by Ulda
Old Oct 15, 2012, 11:06 AM
InfinitR is offline
Joined Oct 2012
Thanks. Confused a bit though. You say you use it successfully, but not totally successful. What do you mean by that? Any info on setup? Are you able to configure in Mission Planner? Thanks again.
Old Oct 15, 2012, 11:54 AM
importon is offline
Find More Posts by importon
USA
Joined Aug 2009
Just wondering what some experienced users would say about prop and landing leg clearance of the ecilop easy for use with very wide lenses. Has anyone used a panisonic 7-14m m43 lens on ecilop? If so, is the camera placement such that there are no copter parts in your shot? Does anyone have any ideas/mods for how to use an extremely wide lense on the ecilop?
importon is offline Find More Posts by importon
Old Oct 15, 2012, 12:27 PM
InfinitR is offline
Joined Oct 2012
Regarding mods, I have an idea. I can't tell for sure from the product pictures, but it looks like that with one screw removed from the arm mount, there is enough room for it to swing out a bit. It may be possible to drill a secondary hole in the arm mount plate that would position the arms at 120 degree pairs front and back. Basically a flattened X pattern. Tri-copters use 120 degree arms up front with one centeral in the back. This basically just mirrors the 120 front and back. There is also the possibility for an X8 in this configuration using a bracket to stack motors on the arm (so long as there is enough clearance from the gimbal and the lower props). I've seen a successful build in this configuration on another copter and it was very stable with an increased FOV. Look up "XY8-ESOc" for an idea of what I am talking about.
One side effect would be the need for a modified landing gear configuration.
Old Oct 15, 2012, 03:49 PM
Patscherpofel is offline
Find More Posts by Patscherpofel
Patscherpofel's Avatar
Patsch, Austria
Joined Jul 2007
flying without landing gear is always an option for me
(for example) take off from a box ...and catch it with your hand
Patscherpofel is offline Find More Posts by Patscherpofel
Old Oct 15, 2012, 04:11 PM
Zaitsevsky's Avatar
Joined May 2009
I'm doing the same
Site Sponsor
Discussion Five easy piece f-14 tomcat bobdaeronort Foamies (Scratchbuilt) 80 Oct 25, 2012 05:43 PM
Discussion Easy Glider VS Easy Glider Pro (what's different?) MkFn Electric Sailplanes 7 Nov 17, 2011 07:42 PM
Discussion Easi Glider film boca55 Serbia 0 Apr 20, 2008 04:46 PM
Discussion Spring Easi* in NZ harrys one Aerial Photography 8 Nov 14, 2007 01:22 PM
