Old Sep 07, 2012, 07:54 AM
TAP993 is offline
Find More Posts by TAP993
TAP993's Avatar
Joined Aug 2012
electronics layout - revised
Here's a revised layout based on your feedback. I switched RX around and straightened the Naza to flight direction. I would still like an opinion on whether my ESCs are positioned OK before I wire up motors. Thanks
TAP993 is offline Find More Posts by TAP993
Old Sep 07, 2012, 08:28 AM
stanleyy is offline
Find More Posts by stanleyy
Slovenská republika, Bratislavský kraj, Bratislava - Podunajské Biskupice
Joined Feb 2011
Originally Posted by TAP993 View Post
7 - Thanks found that now: roll to F1, pitch to F2, but which port on the AR8000? I bought a Spektrum DX8i, and which switch do you find it best to assign gain to?
I have almost the same configuration at home - AR8000, Naza + GPS, DX8 TX...
Unfortunately I left my Ecilop in my office, but as far as I remember, I used following configuration:
- flap switch configures flight mode (normal, att, gps)
- elevator dual rate switch can trigger safe mode anytime I press it.. I used some mixer settings to the flaps signal
- F mode configures one of three different modes of gyro gain (I have configured it to 0, 43, and 53 - 43 is the normal gyro gain that works fine with my frame)
- knob is set to aux 3 channel, it configures the "pitch" of camera.
- Aux2 switch (on the right) is used to switch the "intelligent orientation mode"
I have also configured dual rates for pitch/roll - I am flying with quite high exponential...
I hope this helps
Cheers!
stanleyy is offline Find More Posts by stanleyy
Old Sep 07, 2012, 09:13 AM
TAP993 is offline
TAP993's Avatar
Joined Aug 2012
Cheers!
Thanks that really helps Now waiting for some servo extension leads, RC switch, & bullet connectors to arrive to fix it all together.
Old Sep 07, 2012, 09:58 AM
~>Miha<~ is offline
Find More Posts by ~>Miha<~
~>Miha<~'s Avatar
Joined Dec 2009
Don't forget to post your harakiri pics here:
http://www.rcgroups.com/forums/showthread.php?t=1144377
Might sound harsh but if you are not 100% sure what you are doing don't connect the battery. The Ecilop with the relatively large props isn't the right tool for making noob mistakes (learning by doing?). Once the fingers are off or your face is sliced it's too late to regret. Get a mini quad with harmless props for practicing. Just my 2 cents.
~>Miha<~ is offline Find More Posts by ~>Miha<~
Old Sep 07, 2012, 11:33 AM
TAP993 is offline
TAP993's Avatar
Joined Aug 2012
Thanks. I fully appreciate the dangers and have been crashing a Blade MQX for the last few months to get my RC skills out of mothballs. I'll only fly the Ecilop once I'm ready
Old Sep 07, 2012, 11:54 AM
~>Miha<~ is offline
~>Miha<~'s Avatar
Joined Dec 2009
That's good. I didn't mean so much the flying skills though but to get familiar with the typical multi-rotor components and how they work/behave. I don't have a Blade MQX but isn't that a RTF thingy? If it is, it won't help you much to understand how to DIY build a multi-rotor, as you have to now with the Ecilop, and then painful trial&error might occur.
Old Sep 07, 2012, 12:20 PM
TAP993 is offline
TAP993's Avatar
Joined Aug 2012
It is RTF, and you have a good point. I'll start testing with blades off, then anchor the Ecilop down for first thrust tests. I'm not in any hurry. Back to soldering....
Old Sep 07, 2012, 01:43 PM
whizz101 is offline
Find More Posts by whizz101
Joined Aug 2012
I, about to buy my camera. I was planning on the nex 5, but afyer reading a couple of reviews i am tempted to go for the 5n...Has anyone had real experience with both and made a real comparison? I
whizz101 is offline Find More Posts by whizz101
Old Sep 07, 2012, 05:04 PM
RedSky is offline
Find More Posts by RedSky
Australia, SA, Renmark West
Joined Sep 2011
I've owned and used both. For video the 5N is very much better, for stills it's better but the difference isn't so marked. IMO the 5N is the way to go.
RedSky is offline Find More Posts by RedSky
Old Sep 07, 2012, 05:07 PM
RedSky is offline
Joined Sep 2011
Yes, and a way to crash a multi on takeoff is to have a wrong motor connection - with the props off you can check that the correct motors speed up and slow down when you tilt the aircraft. Also, watch for the NAZA numbering of motors (unusually, anticlockwise as viewed from above) and be sure of rotation of the motors (odd numbered motors anticlockwise) - errors in any of those result in an unflyable aircraft.
Old Sep 08, 2012, 07:08 AM
ABLomas is offline
Find More Posts by ABLomas
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
First Chinese "stadicam" hexa, now exact copy of ecilop?
http://www.buychina.com/products/19494232452
ABLomas is offline Find More Posts by ABLomas
Old Sep 08, 2012, 07:09 AM
stanleyy is offline
Joined Feb 2011
heh, ZeroUAV at least tried to make *something* based on original Ecilop design.. these new chinese guys simply steal the whole frame.. unbelievable
Old Sep 08, 2012, 10:32 AM
nicodh is offline
Find More Posts by nicodh
Joined Jan 2011
At least they have a diference, wich is important. Square holes instead of circular... :-D
nicodh is offline Find More Posts by nicodh
Old Sep 08, 2012, 10:58 AM
~>Miha<~ is offline
~>Miha<~'s Avatar
Joined Dec 2009
If I were an RCG sponsor and this Chinese copycat came to RCG to steal my IP/product and promote the blatant copy then on RCG, I'd be pretty peeved. Now people like that troll from .sk (the other copy thread) can cheer.
Old Sep 08, 2012, 04:45 PM
stanleyy is offline
Joined Feb 2011
hi guys, do you know if I can run the MG930 servo in DS mode? I am affraid to check it, as last time I damaged my older servos by accidentaly switching the gyro to high speed mode...
My ecilop is still a bit shaky, no matter what I do - I think it could get better in high speed mode..
What I also don't like is the fact that the FC is always located out of axis of rotation - I have the NAZA on the left side of my frame, which means that roll axis is affected (the motion of front controller is not symmetrical to the roll axis which means that output from the FC can't be properly control roll servo offset...).
I am wondering what can we do about it... (except of designing some custom controller which would take care of camera gimbal)
Discussion Five easy piece f-14 tomcat bobdaeronort Foamies (Scratchbuilt) 80 Oct 25, 2012 05:43 PM
Discussion Easy Glider VS Easy Glider Pro (what's different?) MkFn Electric Sailplanes 7 Nov 17, 2011 07:42 PM
Discussion Easi Glider film boca55 Serbia 0 Apr 20, 2008 04:46 PM
Discussion Spring Easi* in NZ harrys one Aerial Photography 8 Nov 14, 2007 01:22 PM
