Old Aug 11, 2012, 10:51 AM
stanleyy is offline
Find More Posts by stanleyy
Slovenská republika, Bratislavský kraj, Bratislava - Podunajské Biskupice
Joined Feb 2011
hi Redsky, I meant only the calibration of accelerometer... As the accelerometer is measuring absolute value of linear acceleration (compared to gyro, which is measuring a difference), this absolute value should not drift in time (assuming the device is stacionary and not accelerating in any direction).
I do understand that the estimated position and speed readings from accelerometer can get worse over time due to accumulative error coming from the integration process, but that is not what I was talking about.
I always thought that the only meaning of accelerometer calibration is to get the "zero" values of acceleration in x/y/z axis, nothing more (by calculating the mean value from all readings obtained in the calibration procedure)..
So I see no point why these values should change over time (all modern MEMS sillicons have quite a good temperature stability, so this should also be no issue).
Maybe they are doing some recalibrations of internal variables in their IMU routines, but I have never seen such sideeffects in other controllers (running on Multiwii, Aeroquad or Arducopter stacks which I have experience with)
stanleyy is offline Find More Posts by stanleyy
Old Aug 12, 2012, 01:21 AM
Tokaz is offline
Find More Posts by Tokaz
Sverige, Stockholms Län, Värmdö
Joined Mar 2011
Can someone please show your power distributions and how you have done it. Fredde
Tokaz is offline Find More Posts by Tokaz
Old Aug 12, 2012, 10:36 AM
kwe is offline
kwe
Find More Posts by kwe
kwe
Joined Nov 2010
hi,
can anybody tell us about the motors and esc you use on your ecilop?
thanks
kwe is offline Find More Posts by kwe
Old Aug 12, 2012, 11:22 AM
thomasamoth is offline
Find More Posts by thomasamoth
Joined Aug 2008
Some shot i've done
Beach (0 min 36 sec)
Green (0 min 58 sec)
Bicycle (0 min 44 sec)
Trees (0 min 28 sec)
thomasamoth is offline Find More Posts by thomasamoth
Old Aug 12, 2012, 11:40 AM
stanleyy is offline
Joined Feb 2011
thomasamoth: not bad!
Old Aug 12, 2012, 04:23 PM
koolkiwikat is offline
Find More Posts by koolkiwikat
koolkiwikat's Avatar
New Zealand, Auckland, Waitakere
Joined Sep 2007
Wheres the hexa or octo version?
koolkiwikat is offline Find More Posts by koolkiwikat
Old Aug 12, 2012, 07:27 PM
Jelico is offline
Find More Posts by Jelico
Joined Jul 2008
I think Aleksey mentioned in an email to me that the Octo (with larger camera capability) will be ready in 2013. Don't think there is any plan for a Hexa, but there is an updated quad in the works.
I have just bought my second Ecilop Easy and am in the process of putting it together. Going to run 700KV motors and larger props this time. Hopefully a cleaner wiring install too! For those of you that are trying to figure out a Power Distribution method. Its basically a bunch of deans connectors soldered together with some copper wire. Works great and makes replacing /moving ESC's really easy.
Jelico is offline Find More Posts by Jelico
Old Aug 13, 2012, 06:34 AM
nycewheels is offline
Find More Posts by nycewheels
Bert'sEyeViews of NYC
nycewheels's Avatar
United States, NY, New York
Joined May 2011
I have also just ordered a second Ecilop. I travel by bicycle as I don't want a car so need to make it foldable. I have a bunch of folding quads and they all seem solid enough. I have the same challenge as you, need to clean up the wiring. Might use a Gaui-Ins w OSD with separate Hyperfly Gimbal board - instead of the Wookong M. The Wookong M is nice but messy.
nycewheels is offline Find More Posts by nycewheels
Old Aug 13, 2012, 06:39 AM
stanleyy is offline
Joined Feb 2011
hi Jelico, what propellers are you using right now? 12 inches?
Because I am using 880Kv AC2836-358 motors with 12x45 propellers from aueroquad and I think the motors are getting quite hot when running on 4s...
So I am affraid of overheating... My auw is 2.6kg and I think that is too much for 10 inches propellers...
Old Aug 13, 2012, 06:48 AM
nycewheels's Avatar
Joined May 2011
Originally Posted by thomasamoth View Post
How do you fly FPV ? through the NEX5 ? or FPV fix camera ?
If you find a solution correcting the roll center at start, tell us
Flying with FPV cam (700 line NTC) but not a big fan of it. I have always flown my Gaui 500 with the GoPro live feed. I recently ordered the HDMI converter but it didn't arrive yet. (am afraid its clunky and heavy) I have started research on the electronic viewfinder pin-out on the Nex 5N but nothing so far. Planning to fly it with a dual camera switch, the FPV cam mounted on fixed frame, not the gimbal so you can see banking of the quad on faster maneuvers, like chasing a bike.
Old Aug 13, 2012, 11:45 AM
nycewheels's Avatar
Joined May 2011
Originally Posted by RedSky View Post
That's a really spectacular video - great shooting.
I too looked for a way of controlling roll on a WK-M stabilised gimbal. You can't feed any gimbal commands into the WK-M apart from pitch, all I came up with for roll was mixing a RC channel with the WK-M's roll output, using a cheap V-tail mixer. I still don't know if that would work as the V-tail mixer in my parts box appears to have failed.
What I ended up doing was buying a CRIUS-SE multiwii board and using that as the gimbal controller. That has the facility for inputting pitch and roll commands for the gimbal. It works well but I still have a problem in that my very classy Spartan Quark gyros have -50 exponential as default in rate mode. That's fine for what they're designed for - control of a helicopter tail but not what you want with a gimbal. The exponential is programmable but I'm waiting on a simplex adapter before I can change it. At the moment the gimbal (predictably, in view of the exponential) underreacts to small deflections giving it a rather nervous look in tutbulent conditions..
Thanks, I guess it was more luck than anything else as I have failed setting up much simpler projects than that one : )
I have also looked at mounting another servo right above the camera to slide it sideways to make it swing towards the low side but don't really want to deal with the extra weight and wires.
I have looked into the Cruis SE - http://www.rcgroups.com/forums/showp...45&postcount=1 but seems very intensive setup. Since I need a little bit of a write-off for my business rather than paying taxes, I might go for the $350 Hoverfly gimbal controller. From what I see this is getting nice results (It better for that kind of money)
Old Aug 13, 2012, 02:01 PM
Joined Aug 2008
Golfette (0 min 28 sec)
Old Aug 13, 2012, 02:40 PM
EndOfDays is offline
Find More Posts by EndOfDays
EndOfDays's Avatar
Austria, Niederösterr., Eggenburg
Joined Jan 2010
@thomas,
Looks nice!
best regards
Ferdinand
EndOfDays is offline Find More Posts by EndOfDays
Old Aug 13, 2012, 02:41 PM
stanleyy is offline
Joined Feb 2011
thomasamoth: that one shot is great, very nice! What camera did you use, Nex-5?
Old Aug 14, 2012, 06:54 AM
Joined Aug 2008
I'm using NEX-5N, the only camera can be used with ECILOP, don't buy universal mount, just buy a nex-5N
One more :
River (1 min 5 sec)
Discussion Five easy piece f-14 tomcat bobdaeronort Foamies (Scratchbuilt) 80 Oct 25, 2012 05:43 PM
Discussion Easy Glider VS Easy Glider Pro (what's different?) MkFn Electric Sailplanes 7 Nov 17, 2011 07:42 PM
Discussion Easi Glider film boca55 Serbia 0 Apr 20, 2008 04:46 PM
Discussion Spring Easi* in NZ harrys one Aerial Photography 8 Nov 14, 2007 01:22 PM
