Old May 02, 2012, 12:40 PM
EndOfDays is offline
Find More Posts by EndOfDays
EndOfDays's Avatar
Austria, Niederösterr., Eggenburg
Joined Jan 2010
This ones (with 530KV):
http://www.hobbyking.com/hobbyking/s...ter_Motor.html
From my point of view the motors are great, but you have to consider the different mounting and I am not using the prop-adapter coming with the motor.
best regards
Ferdinand
EndOfDays is offline Find More Posts by EndOfDays
Old May 02, 2012, 03:41 PM
Jelico is offline
Find More Posts by Jelico
Joined Jul 2008
Flew some more this morning (ran 2x 5000mah batteries through it). Didn't have a chance to change the gains or settings much but the footage is OK. There is movement in the image but its not jerky like a traditional mount.
My NAZA was playing up this morning, altitude hold was going nuts so some of the shots were ruined but I will cut some of the better stuff together and put it up later today. No stabilization I promise!
Intersting, with my prop/motor combo I get 9 mins of flying time (leaving 20% in the pack). 8 mins leaves just under 30% in the pack.
In my opinion this is a nice combo of economy and flight times etc. Very happy so far.
Jelico is offline Find More Posts by Jelico
Old May 02, 2012, 04:12 PM
~>Miha<~ is offline
Find More Posts by ~>Miha<~
~>Miha<~'s Avatar
Joined Dec 2009
Such kind of motion is prefectly acceptible. Some folks even prefer that as it makes things look more dynamic. Jerky motion is a no-no.
No post stab I assume
~>Miha<~ is offline Find More Posts by ~>Miha<~
Old May 03, 2012, 05:51 AM
Brombo is offline
Find More Posts by Brombo
Sardinia Multirotors
Italy, Sardegna
Joined Nov 2011
Hi,
i received and assambled mine, and the project is awsome but i figured out that some parts of the central frame could be a little stronger... about function i did not tested yet.
About the Setup i have:
1) NAZA and WKM but i think WKM due to the NAZA limitation in the position mount and drifting problem if not centred in the baricenter.
2) ESC HobbyWing FlyFun 30A
3) Motors NTM 28-30 750kw High Quality
4) FPV TxV RC Immersion 5.8Ghz 600mw
5) Antenna PinWheel 5.8Ghz Terry Built
6) Camera Lumix GF3 14" ..... Zaitsevsky PLEASE SEND US AN ADAPTER for all the other cameras than the NEX!!!!
7) Props APC SlowFly 10x4,7 and 11x4,7
I'm thinking if i need the Gyros too even if i use the WKM with his nice Gimbal functions..
and about servos..... where i can get 2 of the MKS DS8910 in Europe??
They will works with WKM??
They are very fast, the WKM will manage them?
I can avoid to buy 2 Gyros and spend other money and have good result?
Zaitsevsky did you tested with WKM (most diffuse FC with GPS)?
www.brombo.it
Brombo is offline Find More Posts by Brombo
Old May 03, 2012, 06:44 AM
Zaitsevsky is offline
Find More Posts by Zaitsevsky
Zaitsevsky's Avatar
Vilnius, Lithuania (EU)
Joined May 2009
Here is one more simple raw sample:
Ecilop Easy, simple RAW sample (2 min 32 sec)
original file: http://www.filehosting.org/file/deta...8200/00006.MTS
Originally Posted by Brombo View Post
Hi,
www.brombo.it
I haven't those cameras to produce mounts. May be it will be available in future.
You can use any srvo of that size. read recommendations in FAQ .
You must use additional gyro on the gimbal side.
Zaitsevsky is offline Find More Posts by Zaitsevsky
Site Sponsor
Old May 03, 2012, 07:12 AM
Jelico is offline
Joined Jul 2008
Sorry guys.... life got in the way today. Promise to put that footage together tomorrow and get it up. SOme of its quite nice, some of it is sh*it but overall its a good start.
Old May 03, 2012, 11:01 AM
w4Rd3n is offline
Find More Posts by w4Rd3n
w4Rd3n's Avatar
Switzerland, VS, Oberems
Joined Apr 2010
Originally Posted by Zaitsevsky View Post
nice. i like how stable it flies. i would like to see some test in windy conditions. do you fly with an MK Flight controller?
w4Rd3n is offline Find More Posts by w4Rd3n
Old May 03, 2012, 03:05 PM
EndOfDays's Avatar
Joined Jan 2010
Here some impressions from my first flights today. Not perfect, but I think I know what to do. I really love the "active damping" via gyro + servo, this is really a great idea!
Ecilop Easy with Naza (4 min 1 sec)
best regards
Ferdinand
Old May 03, 2012, 06:25 PM
Jelico is offline
Joined Jul 2008
HI Ferdinand, what equipment do you have on your Ecilop Easy? also what gauge of wiring did you go for with the Battery pack? Im using 14 AWG but a but worried its too small!
Old May 03, 2012, 06:37 PM
Zaitsevsky's Avatar
Joined May 2009
If your wires are not hot - it's ok. with AWG 14 you are loosing 0.1V (0.6%) of feed (average).
Site Sponsor
Old May 04, 2012, 02:46 AM
culexus is offline
Find More Posts by culexus
Norway Haugesund
Joined Jun 2010
best regards
Ferdinand
Can you show me how you did the propeller mount? I will use this engine too on my ecilop some day. Just have to order my ecilop first.
culexus is offline Find More Posts by culexus
Old May 04, 2012, 03:00 AM
EndOfDays's Avatar
Joined Jan 2010
@Jelico
I extended the leads of the esc by the same dimension (front ones by 12cm, back ones by 3cm) and then combined them and continued with a lead of thickness of a typical 4000er Lipo Pack. (Sorry but I am not used to the diameter specs of leads).
@culexus
Like this. I had do open the center hole (of the prop) to 9mm, then you get a nice fit on the Bell of the motor.
best regards Ferdinand
Old May 05, 2012, 04:16 AM
Jelico is offline
Joined Jul 2008
OK here you go. This video is completely raw, un stabilized and un graded. Obviously I picked the better shots and cut them together with some music. There is a LONG way to go before the gains/stabilisation is dialed but so far its OK.
Ecilop "flying steady cam" first impressions (3 min 41 sec)
Old May 05, 2012, 04:26 AM
EndOfDays's Avatar
Joined Jan 2010
But this is great right from the start! Well done!
best regards
Ferdinand
Old May 05, 2012, 04:42 AM
~>Miha<~ is offline
~>Miha<~'s Avatar
Joined Dec 2009
@Jelico: Great progress. Is that still with the Assan and MG930 on both axis?
Just roll seems too loose.
I'll finally get my hands on it next week.
Discussion Five easy piece f-14 tomcat bobdaeronort Foamies (Scratchbuilt) 80 Oct 25, 2012 05:43 PM
Discussion Easy Glider VS Easy Glider Pro (what's different?) MkFn Electric Sailplanes 7 Nov 17, 2011 07:42 PM
Discussion Easi Glider film boca55 Serbia 0 Apr 20, 2008 04:46 PM
Discussion Spring Easi* in NZ harrys one Aerial Photography 8 Nov 14, 2007 01:22 PM
