Folks, forget all pricey (and bad anyway) servo-driven gimbals. Just grab one of those new Sony "balanced steadyshot" camcorders. Mounted on an Ecilop it is probably the most you can get.
Here is a sample (not mine) from a MK machine:
CX760V $1499.... |
Joined Jun 2011
OK, my Ecilop kit is on my workbench too. I have used on my old quadcopter four of this motor http://www.hobbyking.com/hobbyking/s...dProduct=12922 together with APC 10x4.7 propellers. Do you think it is enough for the Ecilop with gopro? As I read on HK the trust is 800g for each, so overall max trust should be 3200g. It seems to be much more than needed for me with 5000mAh batterypack. Right?
At least for a testing purposes. |
White to receiver Yellow to servo Manual: Use the "normal" mode for gyroscopes. Start with the maximum reaction value. If the servo gear starts vibrating, reduce the gyroscope reaction value. Push the battery with a finger: if it swings, increase the gyroscope gain value. Quote:
| Thread Tools | |
| Discussion Five easy piece f-14 tomcat | bobdaeronort | Foamies (Scratchbuilt) | 80 | Oct 25, 2012 05:43 PM |
| Discussion Easy Glider VS Easy Glider Pro (what's different?) | MkFn | Electric Sailplanes | 7 | Nov 17, 2011 07:42 PM |
| Discussion Easi Glider film | boca55 | Serbia | 0 | Apr 20, 2008 04:46 PM |
| Discussion Spring Easi* in NZ | harrys one | Aerial Photography | 8 | Nov 14, 2007 01:22 PM |
