Old Feb 12, 2013, 07:11 AM
topgearuk is offline
Find More Posts by topgearuk
topgearuk's Avatar
United Kingdom, London
Joined Dec 2003
Originally Posted by fabianabegglen View Post
can you explain me why
You will have to search this thread to find out why, it's all in here (you need to understand how gyro's work in the 2 different modes)
I just answered your question..
topgearuk is offline Find More Posts by topgearuk
Old Feb 12, 2013, 07:15 AM
fabianabegglen is offline
Find More Posts by fabianabegglen
Switzerland, BE, Berne
Joined Jan 2012
ok i got it, i will go with NORMAL
can you tell me the settings you did with your mini mem?
For example RUD-GAIN? Default is 100. Is this okay.
Did you go with all default values?
thx
fabianabegglen is offline Find More Posts by fabianabegglen
Old Feb 12, 2013, 07:20 AM
topgearuk's Avatar
Joined Dec 2003
thx
I'm using a different make of Gyro..
It does cover briefly setting up gyro in the instructions..
http://ecilop.tv/data/ee1209manual.phtml
Old Feb 12, 2013, 07:31 AM
Joined Jan 2012
thx 4 all that man.
on ecilop.tv they mention to set the reaction level to the maximum. According
to my manual: http://www.hobbyking.com/hobbyking/s...47X4838X51.pdf
which config is that?
Is it 8 RUD-GAIN?
Old Feb 12, 2013, 08:30 AM
flyingdogfilms is offline
Find More Posts by flyingdogfilms
Joined Mar 2009
Originally Posted by thomasamoth View Post
You have to find the old one, .... And there is nowhere to buy
Jelico just said you can use new one's but they are inconsistent so you need to sort through them.
flyingdogfilms is offline Find More Posts by flyingdogfilms
Old Feb 12, 2013, 10:55 AM
AliB is online now
Find More Posts by AliB
kitesurfer
United Kingdom, England, Hayling Island
Joined Dec 2005
i had 7 new 401b's. and only 1 was good. managed to source an old one, and it was great straight away.
get 2 that match and you have a sick setup. went through a couple of servos to find 2 good ones as well.
AliB is online now Find More Posts by AliB
Old Feb 12, 2013, 11:26 AM
helidex is offline
Find More Posts by helidex
New Zealand, Hawke's Bay, Napier
Joined Jun 2011
Rant.
So now I just order 7 or 12 of anything mechanical from HK and hope I find one good one? Do these guys even consider that this they are making can cause mayhem when it fails? What confidence can you have that even when you have found the 1 /7 good component that it will keep working?
We all seem to be very polite about this.
helidex is offline Find More Posts by helidex
Old Feb 12, 2013, 01:45 PM
Joined Mar 2009
Well the hard part is there doesn't seem to be a better option than a properly working 401b. I would buy two $70 gyros if I knew they would perform as well as the good set of 401s
Old Feb 12, 2013, 02:01 PM
Jelico is offline
Find More Posts by Jelico
Joined Jul 2008
To be totally honest - you can get most gyros to work OK, but the HK401's seem to be the easiest way to get that super solid "Zenmuse" style locked in look.
Aleksey recommends the Turnigy mems gyros, and he got it to work extremely well in his earlier prototypes (better than HK401s). I just couldnt get to the same performance as my HK401s. Most likely it was due to something in my set up. The advanced gyros have a ton of heli specific features that, while making them great heli gyros, dont actually help us in this application. If I had more time on my hands I would try a bunch of different gyro combinations and settings on the mems gyros and see if I could get them to work better than the HK401's. I am sure it is possible.
Jelico is offline Find More Posts by Jelico
Old Feb 13, 2013, 05:21 PM
Stumptownflier is offline
Find More Posts by Stumptownflier
United States, OR, Portland
Joined Jan 2012
Need Some Help Please
I should have posted this here!
http://www.rcgroups.com/forums/showthread.php?t=1831286
Any help would be greatly appreciated.
Stump
Stumptownflier is offline Find More Posts by Stumptownflier
Old Feb 14, 2013, 01:26 AM
jocheluich is offline
Find More Posts by jocheluich
Mexico, JAL, Guadalajara
Joined Mar 2012
Turnigy mems gyro settings
I am going to build one Ecilop in the next month and reading bout Gyro and a bunch of threads of all the minimal adjustments, tricks, tips...
Anybody has an Ecilop with fine settings for Gyro/Servo, and maybe post them for the community.. I bet more people will be encourage to try Ecilop for AP if tips, tricks and nice settings were available easily, just my o2. The harder part for this marvel to work seems to be in the settings and combos that work, cause is not piece of cake getting to a that "Z15" feeling.
So anybody?
Turnigy mems/MKS --
HK401b/TG930 (hot glue, foam, lucky pair) ---
jocheluich is offline Find More Posts by jocheluich
Old Feb 14, 2013, 01:49 AM
AliB is online now
kitesurfer
Joined Dec 2005
just need to have a read of this thread.. its all in here.
and those 2 combos are basically your answer
Old Feb 14, 2013, 02:08 AM
Joined Mar 2012
Yep I got that from the thread... What I meant was the settings of those combos, for example.. there is only one for HK401b:
I just found one with HK401b:
HK401B gyros (gyro gain is about 80%, no delay, gyros running in digital mode)
Gimbal settings on Naza and HK401b
F2 Max 1000, 0 –1000
F1 Max 1000, 50 –1000
Pitch gain =16
Roll Gin =20
Speed =3
None with MEMS/MKS combo...
I know they must be some how specific to each Ecilop but a good starting point helps I guess..
Cheers!..
One doubt, could it be possible to use say one Multiwii controller/servo on gimbal function, maybe a custom program on arduino for it. Or am I saying something nonsense?
Old Feb 14, 2013, 02:22 AM
AliB is online now
kitesurfer
Joined Dec 2005
ok. cant help with the mems/mks
but with the 401 and 930,
yep as you say around 80% gain rate mode, digital mode.
F1 & F2 you just want 1000 0 -1000
the 50 is only if your servo is slightly out. you use the middle value to adjust the gimbal to perfectly centre without changing the servo. better to get it physically right on the servo though.
my pitch and roll gain are 18 i think, and speed 1
Old Feb 14, 2013, 02:24 AM
AliB is online now
kitesurfer
Joined Dec 2005
if theres anyone using the mt3506 motors able to tell me what props they are using and what naza gains they've got. upgrading motors so also looking for a starting point. :P
Discussion Five easy piece f-14 tomcat bobdaeronort Foamies (Scratchbuilt) 80 Oct 25, 2012 05:43 PM
Discussion Easy Glider VS Easy Glider Pro (what's different?) MkFn Electric Sailplanes 7 Nov 17, 2011 07:42 PM
Discussion Easi Glider film boca55 Serbia 0 Apr 20, 2008 04:46 PM
Discussion Spring Easi* in NZ harrys one Aerial Photography 8 Nov 14, 2007 01:22 PM
