Old Feb 09, 2013, 08:47 AM
topgearuk is offline
Find More Posts by topgearuk
topgearuk's Avatar
United Kingdom, London
Joined Dec 2003
Wow, what sort of flight time do you get with that lot? I have 2 x 6s compacts I use in my scale heli and agree they are a good battery..
topgearuk is offline Find More Posts by topgearuk
Old Feb 09, 2013, 09:00 AM
thomasamoth is offline
Find More Posts by thomasamoth
Joined Aug 2008
I only have 20mn cause my engines are really powerful (350W) and my propellers are very heavy BUT there is definitively 000000 vibrations with this combo !!
My last showreel shot only with ECILOP :
THOMAERO - Showreel_2012 (1 min 40 sec)
And some other shot ...
ESTIA - Ecole Supérieure des Technologies Industrielles Avancées (1 min 25 sec)
thomasamoth is offline Find More Posts by thomasamoth
Old Feb 11, 2013, 09:21 AM
fabianabegglen is offline
Find More Posts by fabianabegglen
Switzerland, BE, Berne
Joined Jan 2012
How are your Gyroscopes Turnigy Mini MEMS settings
Can you please share your Gyroscopes Turnigy Mini MEMS settings for my ecilop with NAZA/11x5 Graupners?
fabianabegglen is offline Find More Posts by fabianabegglen
Old Feb 11, 2013, 11:18 AM
flyingdogfilms is offline
Find More Posts by flyingdogfilms
Joined Mar 2009
What Gyros are people using on their Ecilops now? I've got 401Bs on mine but heard the new ones are not the same and don't perform well. I want to pick up a couple more gyros as a backup.
flyingdogfilms is offline Find More Posts by flyingdogfilms
Old Feb 11, 2013, 11:42 AM
InfinitR is offline
Find More Posts by InfinitR
United States, CA, San Diego
Joined Oct 2012
I'm using G105, but nothing to compare to.
InfinitR is offline Find More Posts by InfinitR
Old Feb 11, 2013, 02:27 PM
Jelico is offline
Find More Posts by Jelico
Joined Jul 2008
I have played with 5 x different gyros. Here is my experience:
Assan mems gyro - CRAP. Dont even bother.
Align GP 780 gyro - OK but hard to get setup. Not the best for Ecilop but works with small movements.
Turnigy MEMS gyro - OK, similar to GP780. Harder to set up and difficult to get smooth "no movement:" footage. Hold horizon and returns to center very well though.
Futaba 401 - Couldnt get this to work well.
Hobbyking HK 401B. BEST GYRO I HAVE USED. Takes a lot of work to find two that are smooth, and can benefit from the hot glue gun modification, but works very well. Paired with a fast low deadband servo this works really well.
I have since taken the Turnigy mems gyros off my Ecilop and replaced with 401b's.
Servos seem less critical - used align, Turnigy and MKS a Align. All seemed to work ok.
Jelico is offline Find More Posts by Jelico
Old Feb 11, 2013, 03:56 PM
drumbum961 is offline
Find More Posts by drumbum961
Joined Dec 2010
I just got my hands on the second 401b that I needed to complete my build. Could you explain what you mean about the hot glue gun mod on that gyro.
Thanks dude!
KFM
drumbum961 is offline Find More Posts by drumbum961
Old Feb 11, 2013, 04:01 PM
Joined Aug 2008
Drum, you just should put hot glue around all gyros in them.
@JELICO I agree with you, but where do you find these old gyros 401B ?
Old Feb 11, 2013, 05:52 PM
Jelico is offline
Joined Jul 2008
mine arent the "old ones".. What I did was go through 12 (yes twelve) of the new ones until I found 2 that worked without too much jitter. Then did the hot glue mod, which is basically ipening the casing up and filling the space with hot glue so that the sensors cant move around inside the case. Then make sure they are mounted with a gel tape or gyro mounting tape ( I use the 3m picture mounting stuff). Viola!
Old Feb 11, 2013, 07:45 PM
Joined Mar 2009
Ah good to hear the 401Bs still do work. I've been very happy with the performance of the old ones. Hopefully I won't have to go through 12 before I find a good pair.
Old Feb 12, 2013, 12:53 AM
Joined Aug 2008
You have to find the old one, .... And there is nowhere to buy
Old Feb 12, 2013, 01:34 AM
Wreck_nz is offline
Find More Posts by Wreck_nz
Joined May 2012
I'm getting slightly unstable performance, and I think it's because the flight controller is mounted on the far left of the top equipment platform, and the platform itself flexes and moves quite a bit. The platform wobbles if I give it a tap with my finger. I've tried mounting the whole FC inside some foam, but that doesn't really help. Has anyone come across this and solved it? It doesn't seem like there is enough clearance for the camera arm to mount the FC to the rigid bottom part of the frame.
Wreck_nz is offline Find More Posts by Wreck_nz
Old Feb 12, 2013, 07:05 AM
Joined Jan 2012
Should i use Normal or AVCS mode with my turnigy mini mems with my ecilop?
Old Feb 12, 2013, 07:06 AM
topgearuk's Avatar
Joined Dec 2003
Normal
Old Feb 12, 2013, 07:08 AM
Joined Jan 2012
Originally Posted by topgearuk View Post
Normal
can you explain me why
Discussion Five easy piece f-14 tomcat bobdaeronort Foamies (Scratchbuilt) 80 Oct 25, 2012 05:43 PM
Discussion Easy Glider VS Easy Glider Pro (what's different?) MkFn Electric Sailplanes 7 Nov 17, 2011 07:42 PM
Discussion Easi Glider film boca55 Serbia 0 Apr 20, 2008 04:46 PM
Discussion Spring Easi* in NZ harrys one Aerial Photography 8 Nov 14, 2007 01:22 PM
