Old Jan 31, 2013, 11:28 PM
InfinitR is offline
Find More Posts by InfinitR
United States, CA, San Diego
Joined Oct 2012
Does anyone know if the standoff rod for the included LED is fiberglass or carbon fiber? I'm wondering because I am looking to mount an antenna on one.
InfinitR is offline Find More Posts by InfinitR
Old Feb 03, 2013, 09:08 AM
TAP993 is offline
Find More Posts by TAP993
TAP993's Avatar
Joined Aug 2012
I''m pretty sure it's carbon - it conducts electricity anyway
TAP993 is offline Find More Posts by TAP993
Old Feb 03, 2013, 11:32 AM
InfinitR is offline
Joined Oct 2012
Ok thanks. I guess I am going to have to replace it.
On another note, has anyone used a head tracker type device for gimbal control? I currently have a few channels on my transmitter dedicated to manual pitch and roll, but thought it may be interesting to move these controls to a tilt sensor attached to the transmitter.
Old Feb 04, 2013, 04:58 AM
fabianabegglen is offline
Find More Posts by fabianabegglen
Switzerland, BE, Berne
Joined Jan 2012
NAZA turnigy mini mems settings
Hi there
can anybody share their NAZA settings for the ecilop.
I have a NAZA for FC and the turnigy mini mems.
As transmitter is have the T8FG
Which channels would you bind on what.
- I mean is it necessary to adjust the the gyro gain from the T8FG?
Basically the eclop.tv setup.
Thanks for your support.
fabianabegglen is offline Find More Posts by fabianabegglen
Old Feb 04, 2013, 07:44 AM
theSouthGA is offline
Find More Posts by theSouthGA
KK4LIK
theSouthGA's Avatar
United States, GA, Ocilla
Joined May 2012
I have a small lcd screen for my 5.8 rx mounted on my tx. Its hard to see in the first place and would be even harder if I was moving my tx all the time to adjust the gimbal. I just use a knob for pitch at the moment but it works well. I think you'd find that sliders are the easiest. When I can afford a new Tx thats where I'm putting my controls on the sliders.
theSouthGA is offline Find More Posts by theSouthGA
Old Feb 04, 2013, 04:51 PM
barney1959 is offline
Find More Posts by barney1959
Joined Oct 2010
My Naza settings are set for good forward flight control.
Basic 115 115 145 90
ATTI 180 180
8FG set as follows using Heli memory.
Ch1 Ail ,Ch2 Elev, Ch 3 throttle, Ch 4 rudder, Ch 5 Naza Flightmode i.e. GPS/ATTI/Manual using the gyro menu on Switch SE, Ch 6 is Camera shutter on switch SA giving Vid/off/Shutter. Aux8 , Ch 7 Gear for both gyro gains on Switch SB using a Y lead for both roll/Pitch. Ch8 NDL is Pitch control for Gimbal.
barney1959 is offline Find More Posts by barney1959
Old Feb 04, 2013, 05:10 PM
AliB is online now
Find More Posts by AliB
kitesurfer
United Kingdom, England, Hayling Island
Joined Dec 2005
might be worth saying what motors and props your using,, otherwise its kinda worthless information
AliB is online now Find More Posts by AliB
Old Feb 05, 2013, 12:44 AM
LiutaS is offline
Find More Posts by LiutaS
LiutaS's Avatar
Ireland, County Louth, Dundalk
Joined Aug 2010
My naza was flying well with stock settings, just had to find best settings for gimbal.
LiutaS is offline Find More Posts by LiutaS
Old Feb 05, 2013, 02:39 AM
Joined Jan 2012
thx 4 that
i have the 11x5 graupners with the Motor MT2216-12
what means: Switch SE
what means: switch SA
what means: switch SB
what means: Ch8 NDL
thx
ATTI 180 180
Old Feb 05, 2013, 11:15 AM
Joined Oct 2010
Those are the Switch labels on your 8FG TX that I allocated my functions to. You need 3 position switches for some things etc. As I fly Helis I choose positions that I am used to using as under the Gogs FPV you have to know where the switches are.
If you look at your servo monitor and endpoints adjustments the functions are labeled, Aux 8 just happens to be called NDL which is the Needle Mixture normally.
Old Feb 05, 2013, 11:32 AM
Joined Oct 2010
LiutaS the std Naza settings are OK for slow flying in calm conditions but you can get blown backwards in any real breeze and easily end up on a one way trip.
To be able to cover ground fairly quickly std settings dont cut it in ATTI at least.
I could fly Manual easily enough but use the Naza to reduce the Pilot workload so I can concentrate more on what I'm seeing and try to get in the viewfinder.
Old Feb 05, 2013, 12:33 PM
Jelico is offline
Find More Posts by Jelico
Joined Jul 2008
Some Ecilop video footage in a TV shoot I did with a local wakeboarder here in NZ a few weeks back. Action starts at 4.17 and no post stabilization was used as far as I know (I didnt edit it):
NZ's first wakeboard double flip with Brad Smeele : Airtime Season 2 - Ep 3 (5 min 30 sec)
Ecilop is still the best value commercial machine around!
Jelico is offline Find More Posts by Jelico
Old Feb 05, 2013, 01:56 PM
InfinitR is offline
Joined Oct 2012
Jelico, you've probably answered these at some point but what do you use to frame your shots? Monitor, goggles, or just eyeball it? Do you usually shoot while in loiter or alt hold, or just flying? Do you use lens stabilization in cam or turn it off? Cheers.
Old Feb 06, 2013, 12:56 AM
Jelico is offline
Joined Jul 2008
No stabilization in lens (using 16mm pancake). I have an HDMI converter with a downlink to frame shots these days. Depending on the shot I either loiter with GPS and pan as required, or track the subject flying sideways etc. Easy peasy when the machine is setup right. P.s. my Ecilop is still for sale! hehe
Old Feb 06, 2013, 05:12 AM
Zaitsevsky is offline
Find More Posts by Zaitsevsky
Zaitsevsky's Avatar
Vilnius, Lithuania (EU)
Joined May 2009
few short samples
Sraigtasparnistų žiemos sąskrydis 2013 - 01 - 18/20 (10 min 55 sec)
Zaitsevsky is offline Find More Posts by Zaitsevsky
Site Sponsor
Discussion Five easy piece f-14 tomcat bobdaeronort Foamies (Scratchbuilt) 80 Oct 25, 2012 05:43 PM
Discussion Easy Glider VS Easy Glider Pro (what's different?) MkFn Electric Sailplanes 7 Nov 17, 2011 07:42 PM
Discussion Easi Glider film boca55 Serbia 0 Apr 20, 2008 04:46 PM
Discussion Spring Easi* in NZ harrys one Aerial Photography 8 Nov 14, 2007 01:22 PM
