Old Jan 22, 2013, 05:33 PM
jocheluich is offline
Find More Posts by jocheluich
Mexico, JAL, Guadalajara
Joined Mar 2012
Does NAZA still the best option for the Ecilop?.... or a Wookong is to much for the performance Naza and Ecilop has?... Has somebody tried Openpilot CC3d on Ecilop? Since there is some debate about CC3d vs Naza performance w/o GPS.
I am making numbers and 700 dls more is something to think it twice I see a lot of nice videos with Naza and different opinions about Naza and the weight and prop size for Ecilop and that raised my doubts about which is the best FC for Ecilop today?.
Tk you all.
Cheers!...
jocheluich is offline Find More Posts by jocheluich
Old Jan 22, 2013, 07:45 PM
theSouthGA is offline
Find More Posts by theSouthGA
KK4LIK
theSouthGA's Avatar
United States, GA, Ocilla
Joined May 2012
Originally Posted by barney1959 View Post
AliB yes esc's etc all done. The parts have all flown on other quads with the exception of Motors/props.
Ive tried various gains from 90 through to 150 on basics and 120-180 on ATTI
I did a quick test fly tonight with some 10x4.5 which are to small but overall its a much closer to how it should be.
Maybe the Gemfan 12x4.5 are just to big. Its as if the motor RPM is to slow to stabilise the quad properly just at the point off liftoff.
I have some 900Kv motors as a last resort but will try the new Naza first
I found this in another thread I use. It might be helpful.
Mine stay around 100-130 on all of my settings I'm most comfortable in the 120's. I'm currently set at 120 for basic gains and 100 for Atti gain. 12 x 4.5 carbon props with Avroto 2814-11s running on 4s.
This is the NAZA gain test by Cervanchez
Naza Gain Effects (0 min 0 sec)
Note: this video, as it says, is for his setup. I fly my ECILOP with basically the same settings as my HT FPV and it's been fine.
This is a test with my ECILOP setup- VIDEO REPOST -
Ecilop Test, Sony Nex 5N (AVCHD1080) (3 min 56 sec)
theSouthGA is offline Find More Posts by theSouthGA
Old Jan 22, 2013, 10:51 PM
KK4LIK
theSouthGA's Avatar
Joined May 2012
Does anyone know of a remote zoom feature for the Nex 5n?
Old Jan 23, 2013, 01:04 AM
topgearuk is offline
Find More Posts by topgearuk
topgearuk's Avatar
United Kingdom, London
Joined Dec 2003
http://www.youtube.com/watch?v=zk6tyGdnkP8
Very nice flying! Nice and smooth... Got it well balanced!
What make of prop are you using for the 12x4.5? And are you using the light or stiff springs?
topgearuk is offline Find More Posts by topgearuk
Old Jan 23, 2013, 03:03 AM
LiutaS is offline
Find More Posts by LiutaS
LiutaS's Avatar
Ireland, County Louth, Dundalk
Joined Aug 2010
why would you need remote zoom? you cant fly closer or just use fixed zoom lens like 50mm.
Nex 5 lenses dont have auto zoom, only autofocus.
LiutaS is offline Find More Posts by LiutaS
Old Jan 23, 2013, 03:05 AM
LiutaS is offline
LiutaS's Avatar
Joined Aug 2010
Finally my Hexa Ecilop is flying with Naza and gimbal connected. Need to work more on stabilization, but going there. Tested RTH, works just fine
Naza RTH Test (2 min 1 sec)
Old Jan 23, 2013, 12:35 PM
TAP993 is offline
Find More Posts by TAP993
TAP993's Avatar
Joined Aug 2012
http://www.youtube.com/watch?v=K39TdPv7U6Q
I haven't dared try RTH yet....
BTW new Sony Nex lens announced 20mm F2.8
http://www.dpreview.com/news/2013/01...3-5-6-3-OSS-PZ
TAP993 is offline Find More Posts by TAP993
Old Jan 23, 2013, 01:29 PM
barney1959 is offline
Find More Posts by barney1959
Joined Oct 2010
Just to update my post concerning drift and tipping problem with my Ecilop. I substituted my original Naza with a new one out of box today and problem is gone.
My No1 Naza is faulty
The faulty Naza is an early one although firmware updated. Its mostly been on small quads with high KV motors and always had a mild right drift issue. Even when DJI introduced IMU calibration it still has a tendency to move around a little.
I tried 10X5 EleKtro props on my TBS Disco a 4S 900Kv setup a while back but it flew rubbish. and switched back to 9x5 EleKtro's immediately. Now I think about it, in my previous videos, you see me constantly adding slight Aileron corrections. So thinking its not been 100% since new.
It's still working but just not as good as it should be. Time to send it back Quadcopters.co.uk under warranty
barney1959 is offline Find More Posts by barney1959
Old Jan 23, 2013, 04:37 PM
AliB is online now
Find More Posts by AliB
kitesurfer
United Kingdom, England, Hayling Island
Joined Dec 2005
people with naza gps unit,, what are your co-ords for the GPS? mainly Z direction..
how do you guess the vertical centre of gravity.. it will be around the centre of the axial unit, but is there anyway of getting it more accurate? i think this might be causeing slight porposing while flying foreward,
AliB is online now Find More Posts by AliB
Old Jan 23, 2013, 05:38 PM
LiutaS is offline
LiutaS's Avatar
Joined Aug 2010
I did not change any settings for gps, left stock parameters, and it works perfect on my hexa.
Old Jan 23, 2013, 06:04 PM
Joined Oct 2010
AliB Assistant only accepts the distance to the nearest cm
Old Jan 23, 2013, 07:23 PM
KK4LIK
theSouthGA's Avatar
Joined May 2012
Yes they are 12 x 4.5. I'm using the stiffer springs. I think the manual recommended them. They were a PITA to get on though. I actually have some cheap-o CF props on it now but I used my "cheapER" APC props in the video I posted. To be honest I really cant tell the difference between either set but the CF props make it look pretty!
Old Jan 23, 2013, 07:25 PM
KK4LIK
theSouthGA's Avatar
Joined May 2012
I would think "Z" would be "0" if you have it mounted directly off the frame/level with the frame.
Old Jan 23, 2013, 07:32 PM
KK4LIK
theSouthGA's Avatar
Joined May 2012
I have a video project I was going to help a friend with and I thought it would add a cinematic quality to the project if I could zoom in and out. Thanks for the heads-up on the lens though. I'm not very familiar with photography equipment. I was crossing my fingers though. I did recieve my pic/video IR switch to attach to my reciever today though. Looking forward to figuring that system out!
Old Jan 24, 2013, 01:20 AM
Parsec3d is offline
Find More Posts by Parsec3d
Joined Jan 2013
Originally Posted by jocheluich View Post
Hi...I confess, I am saving for an Ecilop cause I stupidly ordered another frame for fpv (budget wise according to me).... and in the end I spent the same as a new Ecilop, motors, esc...
... so my concerns is Does NAZA still the best option for the Ecilop?.... or a Wookong is to much for the performance Naza and Ecilop has?... Has somebody tried Openpilot CC3d on Ecilop? Since there is some debate about CC3d vs Naza performance w/o GPS.
Tk you all.
Cheers!...
+1 to know about the cc3d...
Parsec3d is offline Find More Posts by Parsec3d
Discussion Five easy piece f-14 tomcat bobdaeronort Foamies (Scratchbuilt) 80 Oct 25, 2012 05:43 PM
Discussion Easy Glider VS Easy Glider Pro (what's different?) MkFn Electric Sailplanes 7 Nov 17, 2011 07:42 PM
Discussion Easi Glider film boca55 Serbia 0 Apr 20, 2008 04:46 PM
Discussion Spring Easi* in NZ harrys one Aerial Photography 8 Nov 14, 2007 01:22 PM
