Old Dec 03, 2012, 01:32 AM
topgearuk is offline
Find More Posts by topgearuk
topgearuk's Avatar
United Kingdom, London
Joined Dec 2003
Originally Posted by s6100021 View Post
Really i want to thanks Zaitsevsky for the great video / photography camera stabilization system
here first trip to my ecilop to the sea
http://www.youtube.com/watch?v=3AbgG...&feature=g-upl
Great video, very smooth.. Where in the world was that taken?
Did it need any post stabilisation?
topgearuk is offline Find More Posts by topgearuk
Old Dec 03, 2012, 02:03 AM
tritan is offline
Find More Posts by tritan
Joined Apr 2007
Originally Posted by Zaitsevsky View Post
There was an upgrade. Now Naza is working faster. But there is a problem with a linearization. It means that different gain must be used for 5 deg and for 30 deg. Im using laser level to balance it in plus/minus 10 deg. position.
Alexsey,
could you pls explain that more detailed - I am not sure I follow you.
tritan is offline Find More Posts by tritan
Old Dec 03, 2012, 02:16 AM
Jelico is offline
Find More Posts by Jelico
Joined Jul 2008
Originally Posted by drumbum961 View Post
I know there was some doubts in the beginning of this thread about the naza being a good choice for the gimbal control. It seems from some of the video I've seen posted here now, that naza works well and the outputs are sufficient for use on this gimbal. Any thoughts on this? I recall Jelico going through some trial and error with the naza. I'm about to make my purchase and I'm wondering if the naza will get me the results I'm hoping to get.
KFM
I have had solid results from my orinal setup with the Naza (original "pre-GPS" firmware) and MG930 servo/HK401B gyro combo. For those that have that setup here is my settings from the Naza assistant:
Gimbal
F2 Max 1000, 0 1000
F1 Max 1000, 50 1000
Pitch gain =16
Roll Gin =20
Speed =3
Aleksey - I am about to go through all this again with the new firmware and the Turnigy MEMS gyro/MKS DS9670 combo. Would you mind putting your Naza assistant settings online for us?
Jelico is offline Find More Posts by Jelico
Old Dec 03, 2012, 03:08 AM
Zaitsevsky is offline
Find More Posts by Zaitsevsky
Zaitsevsky's Avatar
Vilnius, Lithuania (EU)
Joined May 2009
Gimbal
F2 Max 1000, 0 1000
Pitch gain =16
Roll Gin =20
Speed =3
There are no universal values.
Gain for this Ecilop Esasy is 12
Gain for this Ecilop Stereo is 14
Here is a sample video from the drone which is now on sale:
Ecilop Easy test (4 min 33 sec)
Zaitsevsky is offline Find More Posts by Zaitsevsky
Site Sponsor
Old Dec 03, 2012, 03:54 AM
s6100021 is offline
Find More Posts by s6100021
Joined Oct 2011
9]Great video, very smooth.. Where in the world was that taken?
Did it need any post stabilisation?[/QUOTE]
Its on United arab emirates . Dubai
Yes shots between the trees has stabilisation . because the wind not stable
s6100021 is offline Find More Posts by s6100021
Old Dec 03, 2012, 04:33 AM
AliB is offline
Find More Posts by AliB
kitesurfer
United Kingdom, England, Hayling Island
Joined Dec 2005
whos running mt3506 motors?
what naza gains are you running with which props.
thinking of upgrading from my unknown motors, and getting some wooden props. xoar or poss those new gemfan ones,
also what flight times are you getting. im just being a litlte indecisive, because at 35 each, they're pretty pricey motors ha
AliB is offline Find More Posts by AliB
Old Dec 03, 2012, 06:18 AM
Nordcopter is offline
Find More Posts by Nordcopter
www.flycamera.de
Nordcopter's Avatar
Joined Sep 2012
Gimbal
F2 Max 1000, 0 –1000
F1 Max 1000, 50 –1000
Pitch gain =16
Roll Gin =20
Speed =3
Thanks. Very helpful.
Isnt speed setting too fast?
Nordcopter is offline Find More Posts by Nordcopter
Old Dec 03, 2012, 06:39 AM
s6100021 is offline
Joined Oct 2011
my Gimbal setting
F1 Max 1000, -50 –1000
Pitch gain =14
Roll Gin =13
Speed =1
first test for my new ecilop
first test for my new ecilop (1 min 37 sec)
Old Dec 03, 2012, 11:51 AM
kenzky is offline
Find More Posts by kenzky
Joined Jul 2008
Originally Posted by kenzky View Post
I have some problems with the ecilop system.
I have spent hours trying to fix it perfectly, but I can't find the problem(s).
http://www.youtube.com/watch?v=_cWXF...ature=youtu.be
I have been doing some work on my ecilop and I posted another video with a new problem.
What is going on with the tilt?
Ecilop problems 3 (0 min 34 sec)
kenzky is offline Find More Posts by kenzky
Old Dec 03, 2012, 11:55 AM
AliB is offline
kitesurfer
Joined Dec 2005
your gyro gains deffo arn't high enoughif you can push and swing it that much. it should be hard to push
Old Dec 03, 2012, 12:00 PM
kenzky is offline
Joined Jul 2008
Yes I thought so too. But if I turn it a little up my servos starts vibrating. Should it be like that?
Old Dec 03, 2012, 12:01 PM
AliB is offline
kitesurfer
Joined Dec 2005
no, they shouldnt vibrate. sounds like your gyro's are in headlock mode instead of rate mode if its vibrating lots.
Old Dec 03, 2012, 12:09 PM
Zaitsevsky's Avatar
Joined May 2009
http://www.youtube.com/watch?v=HOpMM...ature=youtu.be
Do not use a cable ties to fix the gyro, use a soft pad only. Noise of the servo is transferring to the gyro by a plastic belt.
How to configure gyroscopes on the Ecilop mount:
As gyroscope is responsible only for swinging avoidance, it can be adjusted without flying controller by giving signal directly from receiver.
Adjustable parameters of gyroscope:
If gyroscope is not weakening but straightening the swinging - reverse to be turned on;
Delay parameter - minimum;
Limitation of the servo motion - maximal motion with no limits;
Exponents and proportions - not to be used;
Reaction speed - maximal;
Servo type - establish according to the factual;
Work mode - necessarily "Rate" or "Normal"
Adjustment of gain rate is as follows:
Start with maximal reaction rate. If mechanism starts to tremble when gimbal is not moving then lower the reaction rate. Push the gimbal with You finger – it has to move back smoothly to its place with no swinging. If swinging appears than gyroscope reaction is insufficient, increase the gyroscope gain value. If during maximal gain rate swinging is noticeable following may help: use faster servo with minimal dead band, use more tight springs, use another gyroscope. When the equipment is turned on, the gimbal must be stable, otherwise the gyroscopes will be initialized incorrectly and the camera will be tilted. If the onboard controller generates a high-frequency PWM signal, some simple gyroscopes may not work.
Site Sponsor
Old Dec 03, 2012, 12:34 PM
kenzky is offline
Joined Jul 2008
I think I maybe found the problem. I used the gyro programmer and turned down LPIRGAIN and RPIRGAIN fro 200 to 100, and it seems to help on the servo vibrating, what value do you use on these?
But I still have problem with roll gain in naza, beacause there seems to be more gain to one side than the other.
Old Dec 03, 2012, 12:44 PM
InfinitR is offline
Find More Posts by InfinitR
United States, CA, San Diego
Joined Oct 2012
Is anyone using the Sigma 19mm/30mm, Zeiss 24mm or any of the Rokinon lenses for video? Opinions versus the 18-55mm kit?
InfinitR is offline Find More Posts by InfinitR
Discussion Five easy piece f-14 tomcat bobdaeronort Foamies (Scratchbuilt) 80 Oct 25, 2012 05:43 PM
Discussion Easy Glider VS Easy Glider Pro (what's different?) MkFn Electric Sailplanes 7 Nov 17, 2011 07:42 PM
Discussion Easi Glider film boca55 Serbia 0 Apr 20, 2008 04:46 PM
Discussion Spring Easi* in NZ harrys one Aerial Photography 8 Nov 14, 2007 01:22 PM
