Old Dec 01, 2012, 04:06 PM
InfinitR is offline
Find More Posts by InfinitR
United States, CA, San Diego
Joined Oct 2012
Originally Posted by TAP993 View Post
Help: something is producing an annoying glitch that I've never had before. I keep getting sudden lurches. I've checked everything I can think of like connections, wires. Can anybody think of what to look for? The only thing I've changed since successful flights last week is addition of the new alloy landing gear fixings. FC settings I put back to default, (from 120,120,0, 120, atti110,110 and then lowered then to 90% but that didn't change things. Gimball settings are 13 on both roll and pitch with 2 G105. Changing the servo tester gain doesn't change anything so it's on full. The ESCs ping all clear, props are tight...
http://youtu.be/t6vYja_BOyg
I would start with recalibrating each ESC one by one. From there, be sure you don't have a similar power issue like I seemed to have had where you are overloading a bec (possible brown out condition?). I would take a look at the front left esc because it looks like it is consistently dipping in that corner first before the opposite motor compensates.
InfinitR is offline Find More Posts by InfinitR
Old Dec 01, 2012, 04:46 PM
InfinitR is offline
Joined Oct 2012
Originally Posted by Nordcopter View Post
Subscribed!
Y6 would be the best!!
One thing you have to watch is the pitch angle of the gimbal towards the tail leg props.
Old Dec 01, 2012, 07:36 PM
kenzky is offline
Find More Posts by kenzky
Joined Jul 2008
I have some problems with the ecilop system.
I have spent hours trying to fix it perfectly, but I can't find the problem(s).
Ecilop problems2 (1 min 47 sec)
kenzky is offline Find More Posts by kenzky
Old Dec 01, 2012, 07:48 PM
Jelico is offline
Find More Posts by Jelico
Joined Jul 2008
http://www.youtube.com/watch?v=_cWXF...ature=youtu.be
Are you sure your gyros are in rate mode?
Jelico is offline Find More Posts by Jelico
Old Dec 02, 2012, 12:59 AM
tritan is offline
Find More Posts by tritan
Joined Apr 2007
My Y6 will be longer than that so no problem.
/tritan
tritan is offline Find More Posts by tritan
Old Dec 02, 2012, 05:40 AM
kenzky is offline
Joined Jul 2008
Yes. the blue light is normally off, but it starts blinking when I tilt or roll it, I don't know if this is how it should be?
Old Dec 02, 2012, 08:44 AM
s6100021 is offline
Find More Posts by s6100021
Joined Oct 2011
Really i want to thanks Zaitsevsky for the great video / photography camera stabilization system
here first trip to my ecilop to the sea
alharmyah (2 min 44 sec)
s6100021 is offline Find More Posts by s6100021
Old Dec 02, 2012, 08:57 AM
~>Miha<~ is offline
Find More Posts by ~>Miha<~
~>Miha<~'s Avatar
Joined Dec 2009
http://www.youtube.com/watch?v=3AbgG...&feature=g-upl
Nice shots. If you don't have a second and third unit yet, now is the time to get it, because any unplanned "landing" in saltwater will ground you otherwise for a long time
~>Miha<~ is offline Find More Posts by ~>Miha<~
Old Dec 02, 2012, 09:50 AM
s6100021 is offline
Joined Oct 2011
thanks Miha , i do have 2 ecilop , but i can't Imagine landing in saltwater
Old Dec 02, 2012, 10:20 AM
~>Miha<~ is offline
~>Miha<~'s Avatar
Joined Dec 2009
Neither could I But that had no influence on the likelihood of such an event happening when flying over the Sea.
Old Dec 02, 2012, 10:26 AM
~>Miha<~ is offline
~>Miha<~'s Avatar
Joined Dec 2009
BTW, if you fly over really deep Sea where you don't want to dive to recover the rig (the mechanics and the SD card... everything electric will be toast anyway), this will help: google for waterbuoy
Each one will lift 1kg so adding three of them to the Ecilop will keep if floating slightly below water surface.
Old Dec 02, 2012, 07:42 PM
emarketwiz is offline
Find More Posts by emarketwiz
emarketwiz's Avatar
United States, NC, Mooresville
Joined Sep 2011
Can you list your kit components including FC, etc.? That is great video!
emarketwiz is offline Find More Posts by emarketwiz
Old Dec 02, 2012, 10:29 PM
s6100021 is offline
Joined Oct 2011
thanks emarketwiz
My setup is:
Ecilop Easy
Naza with GPS
Turnigy Mini MEMS gyro
SM-3481M Servo(GVS031)
sunnysky V2814-11 700kv
DJI OPTO 30A ESC
Xoar 12x5
Sony Nex-5R 18-55mm
5000 mah 4s
Video Tx/Rx (5.8 - 500mw )
Old Dec 02, 2012, 11:06 PM
drumbum961 is offline
Find More Posts by drumbum961
Joined Dec 2010
I know there was some doubts in the beginning of this thread about the naza being a good choice for the gimbal control. It seems from some of the video I've seen posted here now, that naza works well and the outputs are sufficient for use on this gimbal. Any thoughts on this? I recall Jelico going through some trial and error with the naza. I'm about to make my purchase and I'm wondering if the naza will get me the results I'm hoping to get.
KFM
drumbum961 is offline Find More Posts by drumbum961
Old Dec 03, 2012, 12:38 AM
Zaitsevsky is offline
Find More Posts by Zaitsevsky
Zaitsevsky's Avatar
Vilnius, Lithuania (EU)
Joined May 2009
KFM
There was an upgrade. Now Naza is working faster. But there is a problem with a linearization. It means that different gain must be used for 5 deg and for 30 deg. I’m using laser level to balance it in plus/minus 10 deg. position.
Zaitsevsky is offline Find More Posts by Zaitsevsky
Site Sponsor
Discussion Five easy piece f-14 tomcat bobdaeronort Foamies (Scratchbuilt) 80 Oct 25, 2012 05:43 PM
Discussion Easy Glider VS Easy Glider Pro (what's different?) MkFn Electric Sailplanes 7 Nov 17, 2011 07:42 PM
Discussion Easi Glider film boca55 Serbia 0 Apr 20, 2008 04:46 PM
Discussion Spring Easi* in NZ harrys one Aerial Photography 8 Nov 14, 2007 01:22 PM
