Old Nov 29, 2012, 03:21 PM
AliB is online now
Find More Posts by AliB
kitesurfer
United Kingdom, England, Hayling Island
Joined Dec 2005
looks a possible alternative to the xoar props.
http://www.rcgroups.com/forums/showthread.php?t=1779091
AliB is online now Find More Posts by AliB
Old Nov 29, 2012, 04:03 PM
Zaitsevsky is offline
Find More Posts by Zaitsevsky
Zaitsevsky's Avatar
Vilnius, Lithuania (EU)
Joined May 2009
Originally Posted by tritan View Post
May I ask why you use these instead of the MT3506?
Weigh, size, price, efficiency of the system. 100 % of throttle is not used with MT3506 & 2 kg RTF. Will sell it starting from December.
Zaitsevsky is offline Find More Posts by Zaitsevsky
Site Sponsor
Old Nov 29, 2012, 09:01 PM
InfinitR is offline
Find More Posts by InfinitR
United States, CA, San Diego
Joined Oct 2012
You guys in the 2.2kg range live on another planet than me. I know that there are a few places I can trim the fat a bit, and I guess I carry a few more items than a minimum setup, but my build looks to be between 2.6-2.75kg depending on the options. Mostly standard stuff though.
Video converter, video power filter, arduino, osd, vtx, motor size, larger props, a few extra wires and I guess the lens (18-55) add up. In this configuration it's also actually requiring a slightly heavier battery (offset by capacity) to counter balance unless I move some of my video stuff off the gimbal. But, if it works, I hope to actually get a bit better flight time and good stability. Time to finish wiring this beast and see what happens.
InfinitR is offline Find More Posts by InfinitR
Old Nov 29, 2012, 09:14 PM
Nordcopter is offline
Find More Posts by Nordcopter
www.flycamera.de
Nordcopter's Avatar
Joined Sep 2012
Very right.
Just ordered 11x4 to be run with mt2814 710kv.
Seem to be as stiff as graupner, but with more lift and less vibration.
Cant wait to test.
Nordcopter is offline Find More Posts by Nordcopter
Old Nov 29, 2012, 11:55 PM
tritan is offline
Find More Posts by tritan
Joined Apr 2007
I would like to see a head to head test with these and the Xoars.
I am very pleased with my Xoars - the first time I used them I sold all my Graupners and have never looked back.It was such a big difference.
More efficient, stiffer, quiter, better balanced from factory although I always balance them myself. And they are available in more sizes.
tritan is offline Find More Posts by tritan
Old Nov 29, 2012, 11:57 PM
tritan is offline
Joined Apr 2007
The MT2216 are great motors - i am using them on a Y6.
What props for the STEREO? On the picture it is XOAR but in text it is APC 12x3,8?
Old Nov 30, 2012, 02:36 AM
AliB is online now
kitesurfer
Joined Dec 2005
ooo. worth changing from apc 1238 which arnt very stiff
Old Nov 30, 2012, 03:44 AM
Zaitsevsky's Avatar
Joined May 2009
I'm waiting for 10*4.7 carbon props to use with MT2216.
Site Sponsor
Old Nov 30, 2012, 05:01 AM
TAP993 is offline
Find More Posts by TAP993
TAP993's Avatar
Joined Aug 2012
All this talk of propellers is making me question my setup:
Gemfan 12x4.5 on Torxpower 3536 Pro Heavy Lift Motor 700KV AUW 2.7kg .
I've been experimenting with gains and have broken a few when going too far, getting a wobble and tipping over. They break at the slightest contact with anything, I suppose this is normal? Curious thing is I've broken twice as many anti-clockwise blades as clockwise...
Would I benefit from some wooden ones and should I go for 12x4 or some other size?
TAP993 is offline Find More Posts by TAP993
Old Nov 30, 2012, 05:15 AM
www.flycamera.de
Nordcopter's Avatar
Joined Sep 2012
Yes, wooden props are definitely less sensible to contacts with ground etc.
But keep in mind, that this puts more impact to the motor itself in case of contacting any solid material. So if the prop stays intact, the motors may be harmed more easily.
I am going to try wooden props to have an even better performance (lift and vibration) than the Graupners. CopterCalc tells me to have slightly more flight time also. (11x4 gemfan wood compared to 11x5 Graupners)
Old Nov 30, 2012, 05:25 AM
~>Miha<~ is offline
Find More Posts by ~>Miha<~
~>Miha<~'s Avatar
Joined Dec 2009
You mean xcopterCalc (http://www.ecalc.ch/xcoptercalc_e.htm)? I can't see any of those props there. What am I missing? Or you input them as custom but then how to know the prop constant?
~>Miha<~ is offline Find More Posts by ~>Miha<~
Old Nov 30, 2012, 05:35 AM
~>Miha<~ is offline
~>Miha<~'s Avatar
Joined Dec 2009
Probably yes considering that they run at several kRPM into the ground. I wouldn't use those props anymore, even if they don't show external damage. And as someone mentioned, the bearings will get damaged on any hit, that's for sure.
Okay, you could still use such potentially damaged props for "testing" (say, far from other people and property, no expensive camera mounted), but you would still endanger yourself. I don't want to have a previously damaged blade coming off like a shuriken e.g. after start during the test hover a few meters in front of me right on eye height...
Old Nov 30, 2012, 07:17 AM
tritan is offline
Joined Apr 2007
During 35+ years of flying RC I have never had a wooden prop that broke.
I can't understand people flying a rather high cost multi with cheap plastic blade.
I fly with the intention not to crash but some people do the opposite - they use bad/cheap equipment so it won't cost so much money WHEN they crash .....
During the ~3 years I flown multi's I havent had a single crash.
Old Nov 30, 2012, 07:43 AM
~>Miha<~ is offline
~>Miha<~'s Avatar
Joined Dec 2009
Then you are not the average RC guy. I am not either. I started RC with a 23ccm 1.8m 10kg Vario Benzin Trainer (autolevel or RTH? LOL) and it is still in one piece without a single scratch. I am however very thankful to anyone who does crash frequently during learning because it's those people who keep the RC industry running with their regular apprentice's due, not us <pissing contest OFF>
Old Nov 30, 2012, 08:08 AM
tritan is offline
Joined Apr 2007
OMG, a Vario Benzin Trainer!
Big and rather stable I presume - I started flying heli in the 70's with a Schluter Heli-baby fixed pitch and no gyro.....
I may not be the average guy beacuse of my long time experience in RC but I was a total noob when I started with multis. But I did my homework and went through the rather long learning curve before I bought my first one.
I also always do a pre-flight checklist on my multis (and planes & helis) before take off, a habit I learned from flying real airplanes, gliders and ultralights.
Many crashes can be avoided using a checklist!
Discussion Five easy piece f-14 tomcat bobdaeronort Foamies (Scratchbuilt) 80 Oct 25, 2012 05:43 PM
Discussion Easy Glider VS Easy Glider Pro (what's different?) MkFn Electric Sailplanes 7 Nov 17, 2011 07:42 PM
Discussion Easi Glider film boca55 Serbia 0 Apr 20, 2008 04:46 PM
Discussion Spring Easi* in NZ harrys one Aerial Photography 8 Nov 14, 2007 01:22 PM
