Old Nov 22, 2012, 12:00 AM
Joined Nov 2012
Originally Posted by lao View Post
1. Ecilop = 599.00
2. MR Mini650 = 129.00
3. ZERO-Steadicam = 4xx.00
4. Glyder 600 = 240.00
5. Ellipse Mini 600 = 77.00 (488.00 Chinese Yuan)
tell me why?
Subscribed !!!
RENATAO000 is offline Find More Posts by RENATAO000
Reply With Quote  (Disabled)
Old Nov 22, 2012, 12:50 AM
Joined Oct 2012
This thread is kind of getting sidetracked. Maybe you guys can start another thread about these other platforms please so that we can focus on getting our Ecilop's tuned up here.
InfinitR is offline Find More Posts by InfinitR
Old Nov 22, 2012, 01:43 AM
Adriatic Coast (expat@Croatia)
~>Miha<~'s Avatar
Joined Dec 2009
Just watch the post history of these spammers. Apparently not enough dumb clients who buy their junk, so they come here to post links to their garbage "steadicams" (sic!).
~>Miha<~ is offline Find More Posts by ~>Miha<~
Old Nov 22, 2012, 09:47 AM
Joined Oct 2012
Figures. One more post toward the next page...
btw just received G105 gyros so I will be trying those too. Just motors, battery, and fpv gear to go...come on postman.
Old Nov 22, 2012, 09:59 AM
Joined Oct 2012
Originally Posted by AliB View Post
Just saw this photo, thumbs up
Old Nov 23, 2012, 07:12 AM
kitesurfer
United Kingdom, England, Southampton
Joined Dec 2005
cheers love the colours from that day
heres a clip from today, straight of the camera. no editing
morning (2 min 47 sec)
AliB is online now Find More Posts by AliB
Old Nov 23, 2012, 07:48 AM
Joined Jul 2011
http://www.youtube.com/watch?v=oO6DEEKXX5o
Hi AliB, seams that u use a small FPS, because the flicker at image.
Can you post what was your camera config?
pabloreg is offline Find More Posts by pabloreg
Old Nov 23, 2012, 08:07 AM
kitesurfer
Joined Dec 2005
im using the nex5n at 50fps, but then it gets converted to 25fps in premier.
the slight flicker could be the rendering, or my motors/props slightly out
Old Nov 23, 2012, 08:39 AM
TAP993's Avatar
Joined Aug 2012
Originally Posted by TAP993 View Post
Got an E-tech G105 gyro in the post yesterday and took it apart immediately. Looks like it has the gyro component of the old HK401b,
I was talking to an engineer about gyros the other day. This is what he had to say:
"The reason why bigger rather than smaller size gyros will be working for you is likely because the bigger the sensor has higher capacitance and therefore has better low frequency sensitivity. This is usually offset in the smaller MEMS devices by coupling the sensor to a higher input impedance preamplifier to get good low frequency performance but which then also gives you a correspondingly higher electronic input noise (laws of physics). Low frequency noise can also be difficult to decouple mechanically"
TAP993 is offline Find More Posts by TAP993
Old Nov 23, 2012, 08:41 AM
Joined Jul 2011
Its more visible when panning. Also great footage!
Old Nov 23, 2012, 08:43 AM
kitesurfer
Joined Dec 2005
ahh ok. i always thought that was a problem with panning quickly with cams on multicopters. anyone know how to get round it? is it setup/editing/rendering problems?
cam settings were.. iso200 f6.3 1/160 50p
Old Nov 23, 2012, 10:34 AM
Joined Oct 2012
One note to APM FC users regarding the camera gimbal. In the documentation, it suggests hooking up the roll and pitch servos to OUT10 and OUT11. However, these only have a refresh rate of 50hz. Alternately, you can instead hook them up to OUT7 and OUT8 (on the rail where your esc's and motors connect) which have a refresh rate of 490hz. These outputs will not function until they are provided power on that rail (which usually occurs when your esc's are connected).
I still do not have a complete test, but from my understanding this should smoothen gimbal operation with high speed digital servos.
On a side note, for those who like to tinker with this kind of stuff, I came across an open source headtracker thread (cool in itself) that could probably be modified to be a stand-alone gimbal controller if mounted on a frame.
http://www.rcgroups.com/forums/showthread.php?t=1677559
Old Nov 23, 2012, 10:52 AM
AlanGold's Avatar
Joined Oct 2012
I think your video really shows the smoothness of the camera platform. The flickering is not so bad as to bother me. But it may be due to using too short a shutter speed (1/160th)... noticeable especially when panning. This is counter-intuitive to many as people think a higher shutter speed will give sharper images. True, but it can also make the video choppy. The slowest possible shutter speed is generally the way to go but you'll need a shorter shutter speed at faster frame rates of course as you can't film at 50 fps using 1/30th second shutter speed.
Try filming at 30fps using 1/30th of a second and see if it is less choppy between frames.
Have you or anyone else on this thread used a GoPro on the Ecilop? If so can you mount it so that it won't show props or landing gear in 170 degree fisheye view?
AlanGold is offline Find More Posts by AlanGold
Old Nov 23, 2012, 10:53 AM
TAP993's Avatar
Joined Aug 2012
I think you should shoot on multiples of your fps speed, so ideally 1/50th for 50fps (so 1/60th for 60 fps) or 1/100th (and 1/125th for 60fps) if too bright or use a neutral density filter. Higher shutter speeds don't allow adjacent frames to blend together smoothly so moving objects or pans appear to stutter.
Old Nov 23, 2012, 10:57 AM
TAP993's Avatar
Joined Aug 2012
I didn't want to risk my Nex5 on my first few flights so put a balasted GoPro 170º here:
Ecilop first flight (1 min 16 sec)
Discussion Five easy piece f-14 tomcat bobdaeronort Foamies (Scratchbuilt) 80 Oct 25, 2012 05:43 PM
Discussion Easy Glider VS Easy Glider Pro (what's different?) MkFn Electric Sailplanes 7 Nov 17, 2011 07:42 PM
Discussion Easi Glider film boca55 Serbia 0 Apr 20, 2008 04:46 PM
Discussion Spring Easi* in NZ harrys one Aerial Photography 8 Nov 14, 2007 01:22 PM
