Old Nov 18, 2012, 06:55 AM
stanleyy is offline
Find More Posts by stanleyy
Slovenská republika, Bratislavský kraj, Bratislava - Podunajské Biskupice
Joined Feb 2011
Originally Posted by Zaitsevsky View Post
One month ago I send my suggestions about Naza to DJI , but it may be useful for another controllers:
1. While setting a quadrocopter output M5 and M6 are not used. I offer to make an option which allows to give to these outputs the signals for a gyro gain control. Signal GAIN for the gyro TILT may have one meaning chosen by the user. Signal GAIN for the gyro axel ROLL has to have two meanings: one for vertical position and another in case of camera skewed forward or backward on the axel TILT. The case is when the cameras gimbal skewed forward or backward it is preferable to lower the GAIN for the gyro of axel ROLL. These three values are to be chosen by user experimentally. For the proper work of all types of the gyro it is necessary that PWM impulses would be submitted in the same order as on the helicopter: first the signal of position, then GAIN signal, then a gap (not less than 10 msec).
2. Add a possibility of more precise linearization for setting automatic compensation. Now we have three parameters set: neutral position, two end points, ratio. I suggest taking a table with 9 meanings for different angles: -40, -20, -10, -5, 0, +5, +10, +20, +40 degrees. So user has to skew the gear frame to the indicated angle and choose the meaning of compensation signal for each position. Program makes a more precise compensation graphic based on the chosen meanings. This function could be as a separate menu point “Exact settings”
3. Produce own external MEMS gyros, which are attached to NAZA controller. That is two little sensors with flexible wires of necessary length set on the gimbals axels. In this case servos are attached directly to controller avoiding using extra gyros.
Your point 2) I have implemented by myself using external arduino connected between Naza and gyros. Was not worth the effort, the output was not much better (I did software that measured a few points in the interval and created a 3rd order polynomial to compensate the shift).
But anyway, it could be interesting option to play with
stanleyy is offline Find More Posts by stanleyy
Old Nov 18, 2012, 12:07 PM
InfinitR is offline
Find More Posts by InfinitR
United States, CA, San Diego
Joined Oct 2012
Gonna have to re-read that a few times. One other note on APM is that there are also several spare inputs/outputs and it is open source. I haven't tapped into the code yet but a mod like you describe could potentially make it into the official build by your own specification.
Thanks for info.
InfinitR is offline Find More Posts by InfinitR
Old Nov 18, 2012, 04:14 PM
TAP993 is offline
Find More Posts by TAP993
TAP993's Avatar
Joined Aug 2012
Originally Posted by TAP993 View Post
my second G105 hasn't turned up yet....
Has now and I can confirm the Mystery G105 is the same as the E-Tech G105 inside. Hooked it up and I've got servo tester gain on max and no twitching, so looks promising, but as I've learned it's one thing to look good in your hands, another out there in the wind. Test flights to follow when I get a free moment.
TAP993 is offline Find More Posts by TAP993
Old Nov 18, 2012, 06:41 PM
nycewheels is offline
Find More Posts by nycewheels
Bert'sEyeViews of NYC
nycewheels's Avatar
United States, NY, New York
Joined May 2011
Originally Posted by s6100021 View Post
Pretty cool shots, did you ever hit the X8? - seems like you got very close a few times. I like the fence around your playground...
nycewheels is offline Find More Posts by nycewheels
Old Nov 19, 2012, 12:16 AM
s6100021 is offline
Find More Posts by s6100021
Joined Oct 2011
thanks nycewheels .. yes the next day i had accident with x8 . so my Ecilop broked and my nex 5n 2 ..
s6100021 is offline Find More Posts by s6100021
Old Nov 19, 2012, 06:01 PM
kenzky is offline
Find More Posts by kenzky
Joined Jul 2008
Does anyone know if the naza controller will work better if it's placed in center of the frame?
Now i have mounted it on the side of the frame, and it seems like there is more gain to one side than the other on the camera gimbal.
Anyone noticed the same?
kenzky is offline Find More Posts by kenzky
Old Nov 20, 2012, 01:37 AM
thomasamoth is offline
Find More Posts by thomasamoth
Joined Aug 2008
I just modified my ecilop.
Instead of the naza on one side, now it is centered.
Will test in some days.
thomasamoth is offline Find More Posts by thomasamoth
Old Nov 20, 2012, 02:40 AM
Jelico is offline
Find More Posts by Jelico
Joined Jul 2008
how did you do that?
Jelico is offline Find More Posts by Jelico
Old Nov 20, 2012, 03:17 AM
Joined Aug 2008
Just added a piece of PCB back of the frame.
Old Nov 20, 2012, 08:47 AM
lao is offline
lao
Find More Posts by lao
lao
Joined May 2012
1. Ecilop = 599.00
2. MR Mini650 = 129.00
3. ZERO-Steadicam = 4xx.00
4. Glyder 600 = 240.00
5. Ellipse Mini 600 = 77.00 (488.00 Chinese Yuan)
tell me why?
lao is offline Find More Posts by lao
Old Nov 20, 2012, 08:52 AM
AliB is offline
Find More Posts by AliB
kitesurfer
United Kingdom, Blackpool
Joined Dec 2005
ecilop,,, original design, proven works, very good build quality.
others all clones. aleksey has done all the hard work and design to come up with this concept, and has put the time into it to make it right.
the others are still all playing catchup, and everyone of them is still missing a crucial part of the concept.
its the same with anything. why is a Tmotor more expensive than a sunnysky?
AliB is offline Find More Posts by AliB
Old Nov 20, 2012, 08:53 AM
fotogear302 is offline
Find More Posts by fotogear302
Hong Kong, Sham Shui Po
Joined Jun 2012
Ecilop is still the best one.
Originally Posted by lao View Post
1. Ecilop = 599.00
5. Ellipse Mini 600 = 79.00 (488.00 Chinese Yuan)
tell me why?
fotogear302 is offline Find More Posts by fotogear302
Old Nov 20, 2012, 11:00 AM
TAP993 is offline
TAP993's Avatar
Joined Aug 2012
1. Ecilop = 599.00
tell me why?
Well, I've started from scratch so have had to buy everything including TX/RX. The frame counted for only about 25% of total cost so it wasn't really an issue.
Old Nov 20, 2012, 12:11 PM
InfinitR is offline
Joined Oct 2012
I like the idea of supporting the innovator rather than the copier.
Old Nov 20, 2012, 12:25 PM
helidex is offline
Find More Posts by helidex
New Zealand, Hawke's Bay, Napier
Joined Jun 2011
1. Ecilop = 599.00
tell me why?
1) Clones start to look more expensive if you have to trash them or buy another frame because you can't get spare parts after a crash or something wears out.
2) I had a minor issue with a component in the Ecliop kit. I emailed with a photo. Next day an apology and despatch details for the new part. 1 week later I have the new part in New Zealand.
Standard response in China is send us the faulty part - then usually nothing happens - then a series of unanswered emails - then if you push you get the replacement after you pay for freight. You get what you pay for in the end.
helidex is offline Find More Posts by helidex
Discussion Five easy piece f-14 tomcat bobdaeronort Foamies (Scratchbuilt) 80 Oct 25, 2012 06:43 PM
Discussion Easy Glider VS Easy Glider Pro (what's different?) MkFn Electric Sailplanes 7 Nov 17, 2011 08:42 PM
Discussion Easi Glider film boca55 Serbia 0 Apr 20, 2008 05:46 PM
Discussion Spring Easi* in NZ harrys one Aerial Photography 8 Nov 14, 2007 02:22 PM
