Old Nov 11, 2012, 11:03 AM
AliB is offline
Find More Posts by AliB
kitesurfer
United Kingdom, England, Hayling Island
Joined Dec 2005
had some nice flights today.. much better performance with the gyro change.
and also really nice having fpv cam for checking where the cam is pointing
hardest thing now is setting cam up to not be under or over exposed. nex5n is aweful in auto mode.
AliB is offline Find More Posts by AliB
Old Nov 11, 2012, 11:28 AM
TAP993 is offline
Find More Posts by TAP993
TAP993's Avatar
Joined Aug 2012
Got an E-tech G105 gyro in the post yesterday and took it apart immediately. Looks like it has the gyro component of the old HK401b, so hooked it up and it seems much more mellow in response and completely unlike the new HK401b. I did a quick flight which was reasonable but I can't judge properly till I've got another one for the pitch. I've ordered a "Mystery G105" branded one which I'm assuming is the same as E-Tech as I couldn't get a second E-Tech.
TAP993 is offline Find More Posts by TAP993
Old Nov 12, 2012, 12:05 PM
AliB is offline
kitesurfer
Joined Dec 2005
this is where i got the etech
http://www.rchelihaven.co.uk/
when i was emailing that shop, he said the GAZ-126 was similar to the etech, and both these were better than the new 401b. pretty helpfull really when i was on my hunt for old HK's
my new props arrived today so got them on and ready to test. 12 38 instead of 11 47
should have better flight time and more thrust according to ecalc
reckon ill have to change the gains much? think i need to up my gains abit anyway because in manual mode it was very hard to control. think upping gains will hlelp.
Old Nov 12, 2012, 12:37 PM
TAP993 is offline
TAP993's Avatar
Joined Aug 2012
Oh yes they look identical, never mind I'm sure the Mystery branded one will be too
I haven't thought too hard about props yet and have been running the Gemfan 12x45's that were suggested when ordering Naza/motors/lipos etc.
Old Nov 14, 2012, 02:44 AM
InfinitR is offline
Find More Posts by InfinitR
United States, CA, San Diego
Joined Oct 2012
Interested to hear some more results with G105. I am thinking about trying that gyro too depending on the 401B performance.
InfinitR is offline Find More Posts by InfinitR
Old Nov 14, 2012, 03:06 AM
stanleyy is offline
Find More Posts by stanleyy
Slovenská republika, Bratislavský kraj, Bratislava - Podunajské Biskupice
Joined Feb 2011
I am gonna test GA250 with custom firmware... I will post results here (maybe tomorrow)
stanleyy is offline Find More Posts by stanleyy
Old Nov 14, 2012, 03:25 AM
AliB is offline
kitesurfer
Joined Dec 2005
tested this mornign with the new bigger props. feels much safer now, actually have power in reserve. and hopefully its as efficient, if not slightly more.
weather was pretty rubbish, so had to have iso real high, and it doesnt look very good haha.
was adjusting my gains though, and increased them loads ( over 200 on basic gains) but its now controllable in manual mode. woop.
atti gain adjustment next flight. really should have done this to start with, but when it flew on the original gains i couldnt be bothered haha.
Old Nov 14, 2012, 05:36 AM
Camron1981 is offline
Find More Posts by Camron1981
Belgium
Joined Aug 2008
Originally Posted by InfinitR View Post
Going to Xoar 13x5 with Sunnysky X4108S 600kv motors. The two are close but I should get a better hover throttle for my setup and weight with the 13's.
Hi,
What esc do you use? SimonK? Because I d like to order 4 X4108S and I have plenty simonK 30A...
Camron1981 is offline Find More Posts by Camron1981
Old Nov 14, 2012, 06:26 AM
Belgium
Joined Aug 2008
Great price here: http://www.befr.ebay.be/itm/GAZ-126-...item19cf684cc5
What do you thing about this servo if I modify the mount?
http://www.hobbyking.com/hobbyking/s...06sec_21g.html
I receive my ecilop yesterday
Old Nov 14, 2012, 07:54 AM
TAP993 is offline
TAP993's Avatar
Joined Aug 2012
my second G105 hasn't turned up yet....
Old Nov 14, 2012, 11:15 AM
InfinitR is offline
Joined Oct 2012
Originally Posted by Camron1981 View Post
Hi,
I have 30A Turnigy Plush, standard firmware. I am not off the ground yet though, still waiting for a few parts...
Old Nov 14, 2012, 11:19 AM
InfinitR is offline
Joined Oct 2012
Ok. Thinking I may order a set too just in case. The layout looks identical to GY401. I haven't been through this gain stuff yet so I still don't fully understand the issue.
Old Nov 14, 2012, 11:27 AM
InfinitR is offline
Joined Oct 2012
Please do. Which firmware are you using?
Old Nov 14, 2012, 12:33 PM
TAP993 is offline
TAP993's Avatar
Joined Aug 2012
see page 109 of this thread:
Old Nov 14, 2012, 12:44 PM
InfinitR is offline
Joined Oct 2012
Discussion Five easy piece f-14 tomcat bobdaeronort Foamies (Scratchbuilt) 80 Oct 25, 2012 05:43 PM
Discussion Easy Glider VS Easy Glider Pro (what's different?) MkFn Electric Sailplanes 7 Nov 17, 2011 07:42 PM
Discussion Easi Glider film boca55 Serbia 0 Apr 20, 2008 04:46 PM
Discussion Spring Easi* in NZ harrys one Aerial Photography 8 Nov 14, 2007 01:22 PM
