Old Nov 08, 2012, 06:25 PM
TAP993 is offline
Find More Posts by TAP993
TAP993's Avatar
Joined Aug 2012
I took some stills yesterday with the 16mm 500th sec f7.1 and couldn't believe how bad this lens is in the corners. Fine for video, but shocking for stills. So I used the 18-55mm, way better. Has anyone tried the Sigma 19mm F2.8 ?
http://www.dpreview.com/news/2012/01/10/SigmaDigitalNeo
TAP993 is offline Find More Posts by TAP993
Old Nov 08, 2012, 08:57 PM
RedSky is offline
Find More Posts by RedSky
Australia, SA, Renmark West
Joined Sep 2011
I have, the 19 Sigma is really good for stills. Even on the 24MP NEX-7 it looks great.
RedSky is offline Find More Posts by RedSky
Old Nov 09, 2012, 12:26 AM
s6100021 is offline
Find More Posts by s6100021
Joined Oct 2011
Pretty good for a first, way better than my first ! There's quite a lot of horizon wobble, which I've learnt is the hardest thing to dial out. I'm still trying....The sand must play havoc, do you have to vacuum it after each session?
thanks . yes i have to vacuum it after each session
s6100021 is offline Find More Posts by s6100021
Old Nov 09, 2012, 01:53 AM
InfinitR is offline
Find More Posts by InfinitR
United States, CA, San Diego
Joined Oct 2012
Thx for the video.
InfinitR is offline Find More Posts by InfinitR
Old Nov 09, 2012, 01:59 AM
InfinitR is offline
Joined Oct 2012
You could get that 20gms back by removing the HDMI casing and phono plugs. Reasonably easy to do, there's a good tutorial somewhere on RCGroups but can't find it right now
True. Depending on how it performs, I may want to keep the case (which is also 20g). That's 560g plus a few cables. I wish the HDMI cable was like 6" with 2 90 degree plugs.
Love to see some stills from the 16mm Sony and the 19mm Sigma.
Old Nov 09, 2012, 03:49 AM
InfinitR is offline
Joined Oct 2012
fyi, selling a new set of 12x5 Xoars if anyone needs them...
http://www.rcgroups.com/forums/showthread.php?t=1767088
Old Nov 09, 2012, 03:58 AM
AliB is offline
Find More Posts by AliB
kitesurfer
United Kingdom, Blackpool
Joined Dec 2005
what props you going to?
AliB is offline Find More Posts by AliB
Old Nov 09, 2012, 05:04 AM
TAP993 is offline
TAP993's Avatar
Joined Aug 2012
Here's a jpg straight out of the camera, reduced to 1600pixel ( ©2012 TAP993 ) but centre & top left corner are crops from full size image at 100%. 250th sec at F6.3 400iso Foliage and grass is a difficult test for cameras. There's tons of in camera sharpening going on. If you look at the RAW file (I always shoot RAW but did RAW+JPG) the edges are rubbish. I've shot some at 500th F6.3 100iso which are no sharper. Look at the tree in top left pic, all the leaves are mushed and oversharpened to hide the lack of definition. Basically, 16mm is OK if you put the main subject in the centre.
Old Nov 09, 2012, 11:20 AM
TAP993 is offline
TAP993's Avatar
Joined Aug 2012
You should probably take off and land on an old piece of carpet ?
Old Nov 09, 2012, 12:07 PM
InfinitR is offline
Joined Oct 2012
Going to Xoar 13x5 with Sunnysky X4108S 600kv motors. The two are close but I should get a better hover throttle for my setup and weight with the 13's.
Old Nov 09, 2012, 12:08 PM
InfinitR is offline
Joined Oct 2012
Thanks for the pics. Have you tried a slower shutter speed with higher f-stop? Maybe 6.3 isn't enough depth of field?
Old Nov 09, 2012, 12:24 PM
AliB is offline
kitesurfer
Joined Dec 2005
those motors look pretty tasty. 12g/w at 50% throttle on 13x4 props. pretty sweet
Old Nov 09, 2012, 12:52 PM
InfinitR is offline
Joined Oct 2012
Yeah, pretty stoked to try them out. Just waiting on the deliveries...
Old Nov 09, 2012, 01:40 PM
s6100021 is offline
Joined Oct 2011
Ecilop Chasing X8 part 2
Ecilop Chasing X8 part 2 (2 min 9 sec)
Old Nov 09, 2012, 03:34 PM
Ulda is offline
Find More Posts by Ulda
Czech Republic, Hlavní město Praha, Prague
Joined Sep 2012
Progress...
I'm very curious about your APM gimbal settings. After many many trial and errors I left there default values. And I'm quite satisfied.
Ulda is offline Find More Posts by Ulda
Discussion Five easy piece f-14 tomcat bobdaeronort Foamies (Scratchbuilt) 80 Oct 25, 2012 06:43 PM
Discussion Easy Glider VS Easy Glider Pro (what's different?) MkFn Electric Sailplanes 7 Nov 17, 2011 08:42 PM
Discussion Easi Glider film boca55 Serbia 0 Apr 20, 2008 05:46 PM
Discussion Spring Easi* in NZ harrys one Aerial Photography 8 Nov 14, 2007 02:22 PM
