Old Nov 07, 2012, 07:44 AM
pabloreg is offline
Find More Posts by pabloreg
Joined Jul 2011
Originally Posted by RedSky View Post
Hi Pablo, the PJ760 works but the camera does not stabilise in roll so in some ways the result is a bit disappointing, although the pitch stabilisation is excellent and the pan stablisation of the camera does a good job in smoothing out directional movement of the airframe. Also, there is more vibration with my set up (14 inch props) with the PJ760 than with the NEX-5N, probably to do with the camera being mounted by the tripod screw rather than the lens mount clamp on the NEX-5N.
Overall, I've not followed up any more with the experiment as the PJ760 was expensive and would be pretty fragile in a crash or even heavy landing compared with the NEX-5N which is super tough.
Thanks, that information is very valuable, so i can concentrate to others problems. I'm looking to use the PJ760 mostly because the use of Zoom. Some people are using the zoom while fly, that was a great funcion to AP and AV.
I will look to other solution frame and gimbal to use with PJ760.
pabloreg is offline Find More Posts by pabloreg
Old Nov 07, 2012, 07:48 AM
nycewheels is offline
Find More Posts by nycewheels
Bert'sEyeViews of NYC
nycewheels's Avatar
United States, NY, New York
Joined May 2011
Originally Posted by kevinlib View Post
cheapest hdmi cable, still waitting for the oversea shipping.
http://www.ebay.com/itm/180904056930...84.m1439.l2649
Thanks for that link. I have never seen one with the angled plug, gives the swinging camera the needed clearance.
nycewheels is offline Find More Posts by nycewheels
Old Nov 07, 2012, 08:04 AM
AliB is online now
Find More Posts by AliB
kitesurfer
United Kingdom, England, Hayling Island
Joined Dec 2005
just got some new gyros.
Old style hk401b with glue mod... totally changed my rig. SO SO much better than the new hk401b.
easy to setup and works great. winner.
Also tried an E-tech G105 which also works well.
Both work better than new 401b
AliB is online now Find More Posts by AliB
Old Nov 07, 2012, 08:07 AM
stanleyy is offline
Find More Posts by stanleyy
Slovenská republika, Bratislavský kraj, Bratislava - Podunajské Biskupice
Joined Feb 2011
great.. so now we have to visit junkyard and look for old gyros
stanleyy is offline Find More Posts by stanleyy
Old Nov 07, 2012, 10:33 AM
TAP993 is offline
Find More Posts by TAP993
TAP993's Avatar
Joined Aug 2012
OK, so much for the 401b purchases then. Anyone got a few old ones to sell? I found just 1 E-tech G105 on ebay uk and have snapped that up just in case...
TAP993 is offline Find More Posts by TAP993
Old Nov 07, 2012, 01:14 PM
stanleyy is offline
Joined Feb 2011
hm, I just opened all my four 401 gyros and guess what.. all have the new design...
Weird thing is that I got quite nice results with these gyros.
So does it really make that big difference??
Old Nov 07, 2012, 02:24 PM
LiutaS is offline
Find More Posts by LiutaS
LiutaS's Avatar
Ireland, County Louth, Dundalk
Joined Aug 2010
I wander, is it only 401b will be good for this gimbal? As i have GA410 assan sitting at home for long time, would this be good at all?
LiutaS is offline Find More Posts by LiutaS
Old Nov 07, 2012, 05:19 PM
InfinitR is offline
Find More Posts by InfinitR
United States, CA, San Diego
Joined Oct 2012
Try it. I am waiting for some 401b gyros as well so we'll see.
InfinitR is offline Find More Posts by InfinitR
Old Nov 07, 2012, 05:21 PM
InfinitR is offline
Joined Oct 2012
Progress...
Old Nov 07, 2012, 06:09 PM
AliB is online now
kitesurfer
Joined Dec 2005
just a note, i would put the LED boom on one the motor booms like shown on the ecilop site. allows the gimbal more travel.
Old Nov 07, 2012, 07:25 PM
InfinitR is offline
Joined Oct 2012
Thanks, I'll take a look.
In an effort to relocate my HDMI converter, I realized that at a cost of 20 grams you can use the alternate camera mount as a backpack. I just had to add a spacer on the tripod mount screw.
Old Nov 08, 2012, 09:43 AM
TAP993 is offline
TAP993's Avatar
Joined Aug 2012
I decided to try stronger & weaker springs to see what happens (currently running pre-update Ecilop with standard springs). Result with my setup (new HK401b + MG930) was that the stronger springs (i put cable ties around last 3 rings of spring to tighten them up) made oscillation and horizon wobble worse. I then tried weakend springs and definitely got a better result, in fact almost useable footage...will have to order some proper ones. I think the weaker springs allow you to run a slightly higher gain before servo oscillation happens. However, I still can't run sufficient roll gain to compensate for frame roll without causing gimbal roll oscillation.
Old Nov 08, 2012, 02:54 PM
s6100021 is offline
Find More Posts by s6100021
Joined Oct 2011
Ecilop Chasing X8
here is my first video
Ecilop Chasing X8
Ecilop Chasing X8 (2 min 31 sec)
s6100021 is offline Find More Posts by s6100021
Old Nov 08, 2012, 05:09 PM
TAP993 is offline
TAP993's Avatar
Joined Aug 2012
Ecilop Chasing X8
Pretty good for a first, way better than my first ! There's quite a lot of horizon wobble, which I've learnt is the hardest thing to dial out. I'm still trying....The sand must play havoc, do you have to vacuum it after each session?
Old Nov 08, 2012, 05:21 PM
TAP993 is offline
TAP993's Avatar
Joined Aug 2012
You could get that 20gms back by removing the HDMI casing and phono plugs. Reasonably easy to do, there's a good tutorial somewhere on RCGroups but can't find it right now
Discussion Five easy piece f-14 tomcat bobdaeronort Foamies (Scratchbuilt) 80 Oct 25, 2012 05:43 PM
Discussion Easy Glider VS Easy Glider Pro (what's different?) MkFn Electric Sailplanes 7 Nov 17, 2011 07:42 PM
Discussion Easi Glider film boca55 Serbia 0 Apr 20, 2008 04:46 PM
Discussion Spring Easi* in NZ harrys one Aerial Photography 8 Nov 14, 2007 01:22 PM
