Old Nov 06, 2012, 10:51 AM
TAP993 is offline
Find More Posts by TAP993
TAP993's Avatar
Joined Aug 2012
Originally Posted by pabloreg View Post
About gyros i only find the options below:
HK 401b.........................................$12,0 0 - the new version doesn't work like the old
This is what I'm finding as I just bought 2 new ones
HK GA-250 MINI-MEMS...............$10 - maybe the best one at the momment?
I never managed to set these up, and gave up (I am new to all this though)
Futaba GY520 Gyro....................$130,00 - expensive
I got fed up trying to setup the GA250's and spent a fortune on 2 GY520's - They worked straight out of the box, were a delight to setup compared to the GA250's BUT I couldn't get rid of gentle rocking once the gyros had corrected the frame's movement
Turnigy Mini MEMS......................$70,00
These were out of stock everywhere and would have been my first choice...no experience
Still looking for the answer.....
TAP993 is offline Find More Posts by TAP993
Old Nov 06, 2012, 11:51 AM
stanleyy is offline
Find More Posts by stanleyy
Slovenská republika, Bratislavský kraj, Bratislava - Podunajské Biskupice
Joined Feb 2011
has anyone tried ga250 with modified firmware? I think I will give them a try...
stanleyy is offline Find More Posts by stanleyy
Old Nov 06, 2012, 12:00 PM
TAP993 is offline
TAP993's Avatar
Joined Aug 2012
Is that something you would do yourself or is there a download somewhere, as I have these GA250's hanging around?
Old Nov 06, 2012, 12:04 PM
stanleyy is offline
Joined Feb 2011
there is a thread about it on RCG..
http://www.rcgroups.com/forums/showthread.php?t=1610075
Old Nov 06, 2012, 12:38 PM
TAP993 is offline
TAP993's Avatar
Joined Aug 2012
Hmm, think I'll let you go first
Old Nov 06, 2012, 12:55 PM
stanleyy is offline
Joined Feb 2011
then it will take some time, I have to buy gyros and programmer Let's see..
Old Nov 06, 2012, 01:06 PM
pabloreg is offline
Find More Posts by pabloreg
Joined Jul 2011
So, my conclusion till now is that i must buy Turnigy Mini MEMS.
pabloreg is offline Find More Posts by pabloreg
Old Nov 06, 2012, 04:41 PM
InfinitR is offline
Find More Posts by InfinitR
United States, CA, San Diego
Joined Oct 2012
Can someone describe the sensitivity issue a bit more on the 401b? Just wondering if this is something that may be able to be filtered out.
InfinitR is offline Find More Posts by InfinitR
Old Nov 06, 2012, 04:53 PM
kevinlib is offline
Find More Posts by kevinlib
USA, IL, Chicago
Joined Mar 2010
cheapest hdmi cable, still waitting for the oversea shipping.
http://www.ebay.com/itm/180904056930...84.m1439.l2649
kevinlib is offline Find More Posts by kevinlib
Old Nov 06, 2012, 04:57 PM
kevinlib is offline
USA, IL, Chicago
Joined Mar 2010
where does the red cable connect to?
Old Nov 06, 2012, 05:40 PM
TAP993 is offline
TAP993's Avatar
Joined Aug 2012
I've got the red cable connected to the "5v Out" on my immersion video TX (black cable to "GND", yellow to "VID") power for HDMI converter comes from TX, otherwise camera may struggle to supply enough
Old Nov 06, 2012, 05:43 PM
InfinitR is offline
Joined Oct 2012
/edit ^ just saw another reply
Old Nov 07, 2012, 12:39 AM
Nordcopter is offline
Find More Posts by Nordcopter
www.flycamera.de
Nordcopter's Avatar
Joined Sep 2012
i would like to get more than 8 channels on my tx/rx:
as i run a futaba t8fg with 6208sb rx, is it possible to drive the naza via sbus and use the conventional outputs at the same time to connect gyro gains and cam shutter?
has anyone done this?
have i to move some channels in the t8fg then?
thanks.
Nordcopter is offline Find More Posts by Nordcopter
Old Nov 07, 2012, 03:03 AM
TAP993 is offline
TAP993's Avatar
Joined Aug 2012
Would this help at all Futaba CIU-2 USB, as it is plug and play, I'll be out of my depth with the GA250 mods. The controller allows you to set differential and dampening gain on the GY520 ? Is it relevant for Ecilop as most adjustable settings are aimed at AVCS mode?
Futaba Video Update: Programing the GY520 gyro with the GYLink software (6 min 50 sec)
Old Nov 07, 2012, 04:30 AM
RedSky is offline
Find More Posts by RedSky
Australia, SA, Renmark West
Joined Sep 2011
Thanks to you whizz, that help i find Aleksey mention ecilop can fly with 600g camera. And that post form RedSky... but nothing about the results of this flight with PJ760 (Cx760).
Hi Pablo, the PJ760 works but the camera does not stabilise in roll so in some ways the result is a bit disappointing, although the pitch stabilisation is excellent and the pan stablisation of the camera does a good job in smoothing out directional movement of the airframe. Also, there is more vibration with my set up (14 inch props) with the PJ760 than with the NEX-5N, probably to do with the camera being mounted by the tripod screw rather than the lens mount clamp on the NEX-5N.
Overall, I've not followed up any more with the experiment as the PJ760 was expensive and would be pretty fragile in a crash or even heavy landing compared with the NEX-5N which is super tough.
RedSky is offline Find More Posts by RedSky
Discussion Five easy piece f-14 tomcat bobdaeronort Foamies (Scratchbuilt) 80 Oct 25, 2012 05:43 PM
Discussion Easy Glider VS Easy Glider Pro (what's different?) MkFn Electric Sailplanes 7 Nov 17, 2011 07:42 PM
Discussion Easi Glider film boca55 Serbia 0 Apr 20, 2008 04:46 PM
Discussion Spring Easi* in NZ harrys one Aerial Photography 8 Nov 14, 2007 01:22 PM
