Czech Republic, Hlavní město Praha, Prague
Joined Sep 2012
Here is the cheapest Xoar propeller I have found http://www.electriflite.co.uk/store/...s/pjn12x4.html
But they dont sell it in the pair unlike others. Could it be a problem? Is the pair better matched/balanced? BTW the Zenmuse crashes are realy heartbreaking. And the stabilisation unbelievable! |
Joined Jul 2011
Thanks! I have some batteries Turnigy nano-tech 4500mAh 25-50C and other 35-70C that almost same weight, and one Zippy 5000 mAh 40C that is very heavy, i will buy more and will try 25C.
About using cameras like Sony CX760 with more weight, there is any frame Ecilop-family project ready? Or the ecilop can handle 500g or 600g camera? Thanks! |
Joined Oct 2012
Joined Oct 2012
Are you sure you have 5mm hubs and not 6mm? Otherwise, I saw these that should fix your problem. http://www.quadrocopter.com/MK-Prope...638_p_268.html |
Joined Sep 2012
You did not understand me well, sorry. I meant there is not hole through. It is predrilled, not drilled. So there is only little hollow or dimple or how to say it. I dont know the english word. |
United Kingdom, England, Southampton
Joined Dec 2005
interesting. jus opened up one of my hk401b gyros.
and it seems i have this new type gyro. ![]() now alot of what i have read online about this gyro, is that the new one is really sensitive and twitchy compared to the old one. i have a feeling my roll gyro might be an old one, but all my others are the new type one. because i can have the gain on roll almost full before it starts twitching. |
Gradually getting there - I managed to get a couple of HK401b's at last and fitted them instead of the GY520's, as well as a new Tower MG930 on the roll (to try to eliminate a twitching MKS9760a). This immediately cured most of the pitch pitching. The GY520's worked well at handling the major movements, but I could not dial out the mild swinging that followed compensation. The 401b's cut out most of the problem but are very sensitive to gain adjustments. I have 10 set in the naza assistant for roll and pitch, then nearly the same on the servo tester (ie 15% beyond the centre point).
This first clip was around 20% on the servo tester, second clip reduced to about 15% which was an improvement. Any lower and the horizon rolls, any higher and it starts twitching...not sure what to adjust next? conditions: light wind
| Thread Tools | |
| Discussion Five easy piece f-14 tomcat | bobdaeronort | Foamies (Scratchbuilt) | 80 | Oct 25, 2012 05:43 PM |
| Discussion Easy Glider VS Easy Glider Pro (what's different?) | MkFn | Electric Sailplanes | 7 | Nov 17, 2011 07:42 PM |
| Discussion Easi Glider film | boca55 | Serbia | 0 | Apr 20, 2008 04:46 PM |
| Discussion Spring Easi* in NZ | harrys one | Aerial Photography | 8 | Nov 14, 2007 01:22 PM |
