Old Oct 30, 2012, 06:13 AM
FlyingMcCoy is online now
Find More Posts by FlyingMcCoy
Joined Mar 2010
Originally Posted by TAP993 View Post
I sympathise as there's info overload when starting all this. Previous posts seemed to have vital missing info such as plug colour.
Servo plug is the easy part as it plugs into the only female from the gyros
Plug both Yellow cables into servo a tester which stays on the Ecilop permanently and allows you to twiddle the knob for adjusting out the swinging movement of the camera gimbal. Or plug both yellow plugs via a Y-cable into Aux3 channel (Spektrum AR8000 RX) and use TX knob to adjust instead. In all cases make sure the plug is the correct way up so it's not in the + or - slots
If you have the Naza FC then Roll gyro black male plug into F1, Pitch gyro black male plug into F2
Instead of using the 401 gyros and carry the heavy servo tester onboard perhaps someone should try using this http://www.hobbyking.com/hobbyking/s...o_Gyro_JR.html .on each axis. There's a pot for adjusting the centering of the servo.
FlyingMcCoy is online now Find More Posts by FlyingMcCoy
Old Oct 30, 2012, 07:38 AM
RedSky is offline
Find More Posts by RedSky
Australia, SA, Renmark West
Joined Sep 2011
My servo tester only weighs abut 6 grams but the GWS Gyro does look interesting - and as you say the centering would be useful. However, out of stock atm.
RedSky is offline Find More Posts by RedSky
Old Oct 30, 2012, 10:13 AM
thomasamoth is offline
Find More Posts by thomasamoth
Joined Aug 2008
Originally Posted by EndOfDays View Post
@Thomas,
You could try an electronic V-mixer, one end on the Naza, another on the receiver or a servo-tester. You would need to adjust your gains on the Naza (double them), but then you should be able to "trim" roll.
best regards
Ferdinand
I GUYS,
From this long time i still don't have a solution for my roll camera problem.
I have tried a vtail mixer but i still can't trim de roll .... Have you succed with the Vtail ?
When you power your ECILOP the roll is never well centered, what is your solution for this ?
Aleksey, need your advice.
thomasamoth is offline Find More Posts by thomasamoth
Old Oct 30, 2012, 10:30 AM
stanleyy is offline
Find More Posts by stanleyy
Slovenská republika, Bratislavský kraj, Bratislava - Podunajské Biskupice
Joined Feb 2011
Originally Posted by thomasamoth View Post
I GUYS,
Thomas, what exactly is your problem? On my Ecilop I have trimmed the roll to zero using attached accelerometer on iPhone. After I power up the quad, I let it settle down for a few seconds (10-15 seconds), until accelerometers (or IMU or whatever ) on Naza finish their calibration. Then the roll reaches the correct position and I am ready to fly. Do you have different offset every time you power your quad or what?
stanleyy is offline Find More Posts by stanleyy
Old Oct 30, 2012, 10:32 AM
Joined Aug 2008
Yes exact i have offset each time i power my ecilop ...
Old Oct 30, 2012, 10:43 AM
stanleyy is offline
Joined Feb 2011
then you should recalibrate everything - magneto, imu, again set the roll center... I see no reason for such behaviour if the IMU is well calibrated and the device is stationary. What FC are you using, Naza?
Old Oct 30, 2012, 10:45 AM
Joined Aug 2008
Yes i'am using naza.
Why recalibrate magneto ?
How can i calibrate imu ?
Tom
Old Oct 30, 2012, 10:51 AM
stanleyy is offline
Joined Feb 2011
Tom
IMU can be calibrated using Naza Assistant, it is in the menu. And please don't tell me that you forgot to do a calibration of compass... This is a must, the sensor fusion doesn't work properly without calibration! Please follow the Naza manual (you have to do a bit of "dance" with the frame, but it is nicely written in the manual).
If the magneto is not calibrated, sensor fusion algorithm can create drifts and offsets, not mentioning issues with yaw during flight.
And of course you must compensate magnetic declination (check the declination here: http://magnetic-declination.com/ ) - you must rotate the gps module in the opposite direction to fix the difference between magnetic north and GPS north.
Good luck!
Old Oct 30, 2012, 11:04 AM
Joined Aug 2008
Hey, my compas is well calibrated, i my ecilop fly like a charm.
I just can't see why calibrate again my compas can affect my camera roll.
Cheers
Old Oct 30, 2012, 11:29 AM
stanleyy is offline
Joined Feb 2011
Cheers
It can affect your roll as the roll is calculated from device attitude which is calculated from fused sensor data. And if the FC gets invalid data, it generates invalid output. Magnetic sensor is extremely sensitive to *everything* and it can pretty much screw up the whole IMU calculation.
You can try to temporarily disconnect the GPS module and check if the problem is still there.
Old Oct 30, 2012, 11:40 AM
Joined Aug 2008
Hum interesting. Will test it
Old Oct 30, 2012, 11:56 AM
Zaitsevsky is offline
Find More Posts by Zaitsevsky
Zaitsevsky's Avatar
Vilnius, Lithuania (EU)
Joined May 2009
I GUYS,
Is you gimbal stable during power on? there must be no movements during few seconds to initialize properly. That is why I'm suggesting to use a different switch for an equipment.
Zaitsevsky is offline Find More Posts by Zaitsevsky
Site Sponsor
Old Oct 30, 2012, 12:56 PM
nycewheels is offline
Find More Posts by nycewheels
Bert'sEyeViews of NYC
nycewheels's Avatar
United States, NY, New York
Joined May 2011
Originally Posted by Zaitsevsky View Post
Retractable chassis look great, but I am not going to sell them. First of all they may cause some vibration. Secondly – they are easy breakable during hard landing. If the pilot already able to hang in place, it’s better to avoid chassis.
My experiments with the long balance beam are to be continued.
true, they are flimsy but its worth having some vibration in exchange for being the coolest guy in the park
nycewheels is offline Find More Posts by nycewheels
Old Oct 30, 2012, 12:57 PM
AliB is offline
Find More Posts by AliB
kitesurfer
United Kingdom, Blackpool
Joined Dec 2005
jus got my 12 38 apc. fingers crossed the work well. dont feel very stiff though
AliB is offline Find More Posts by AliB
Old Oct 30, 2012, 01:00 PM
nycewheels's Avatar
Joined May 2011
thus issue drove me crazy until i finally installed an independent gimbal controller. I now can center the roll via knob on radio.
Discussion Five easy piece f-14 tomcat bobdaeronort Foamies (Scratchbuilt) 80 Oct 25, 2012 06:43 PM
Discussion Easy Glider VS Easy Glider Pro (what's different?) MkFn Electric Sailplanes 7 Nov 17, 2011 08:42 PM
Discussion Easi Glider film boca55 Serbia 0 Apr 20, 2008 05:46 PM
Discussion Spring Easi* in NZ harrys one Aerial Photography 8 Nov 14, 2007 02:22 PM
