Old Jan 31, 2013, 08:00 AM
Barn-E-Stormer is offline
Find More Posts by Barn-E-Stormer
Dark Yet??
Barn-E-Stormer's Avatar
United States, VA, Narrows
Joined Dec 2009
Why use the UBEC? The sound board can't take 11v? If so just use 7v from the balance tap on your battery. It may even work off one cell.
Barn-E-Stormer is offline Find More Posts by Barn-E-Stormer
Old Jan 31, 2013, 08:11 AM
quitcherbitchen is offline
Find More Posts by quitcherbitchen
Bombs away!!!
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
In all fairness the sound module warned about going over 9volts. I am sure the board could handle it, but not sure about the speaker. I wired it per the Turnigy manual which had the UBEC. I might tinker with it later and go directly to the 3s 11.1 volt used to fly the plane or use a Castle Link to adjust the UBEC and tap the UBEC directly for power. I think you can adjust the Castle 10 amp UBECs for different voltage output.
quitcherbitchen is offline Find More Posts by quitcherbitchen
Old Jan 31, 2013, 11:03 AM
Bombay is offline
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Quitcher:
Thanks for the inspiration and follow through with your solution. I have a 3-way siren from RAM that I will reconfigure in this way (with the switch). The siren is pretty loud and obnoxious.
Regards,
Bombay
Night Flying Accessories for Sale (LEDs, controllers)
Bombay is offline Find More Posts by Bombay
Old Jan 31, 2013, 12:56 PM
Dark Yet??
Joined Dec 2009
Wire the sound card directly to the balance tap on your battery. The 2 cell tap will give your 7.4v which will be fine for the sound card. This will eliminate the regulator.
I have plenty of these balance tap connectors or you can get them online.
Old Jan 31, 2013, 01:22 PM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Barn-E:
Is Digi-Key your recommended source?
BTW - nice crochet project you have going there in the background.
Old Jan 31, 2013, 01:44 PM
Dark Yet??
Joined Dec 2009
Yes I get them from DigKey.
Afghan covered biplanes finished in Stits are all the rage.
Old Jan 31, 2013, 02:09 PM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Just wondering regarding driving the sound card with 7.4v, 9v, 12v...
Would the input voltage affect the output volume? If so, if 9v isn't really loud enough when in flight, then 7v certainly will not cut it.
Old Jan 31, 2013, 02:21 PM
Dark Yet??
Joined Dec 2009
I don't have one of those cards but I bet it does. Easy to test. Just use the balance ports on a battery to test the card and try it at 3.8, 7.4 and 11V. The sound level would only stay the same if it had some type of regulator on the sound card.
If you want it louder a separate power amp and speaker could be added.
Old Jan 31, 2013, 03:43 PM
Bombs away!!!
Joined Jul 2011
Ralph from RAM mentioned that increasing the voltage will not increase the volume. Damage would be to the speaker. 7.4 volts in not powerful enough, but at least it wouldn't damage the speaker. I will try using a UBEC set to 9 volts Just need a Castle lInk to set up my UBEC.
Help! 4 Channel receiver to control 3 turnigy on/off switches acuralegendz Radios 0 Apr 24, 2012 05:22 PM
Help! Turnigy Receiver Controlled Switch wriggs Power Systems 4 Mar 07, 2012 08:08 AM
Sold NIP! Turnigy Receiver Controlled on/off switch sale!!! jeff489 Aircraft - General - Radio Equipment (FS/W) 6 Dec 15, 2011 12:53 AM
Sold NIP! Turnigy Receiver Controlled on/off switch $10.00 awayne Aircraft - General - Radio Equipment (FS/W) 2 Nov 11, 2011 12:38 PM
Wanted Turnigy Receiver Controlled Switch Floater73 Aircraft - General - Radio Equipment (FS/W) 3 Oct 24, 2011 03:04 PM
