Old Apr 30, 2012, 11:30 AM
Bombay is offline
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
By series, I mean this configuration:
Bombay is offline Find More Posts by Bombay
Old Apr 30, 2012, 11:34 AM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Got it. If you're running 3S, go + to + and - to -. If you have some sections with a number of LEDs not divisable by three, some of the LEDs probably won't work.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Apr 30, 2012, 11:57 AM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Thanks. I've used these led strips extensively. I usually wire the strips and segments in parallel for the reasons mentioned, but I am now curious about electrotor's calculations. I'll see if I can wire up a few segments in series in the next couple of days to test his statement.
Old Jan 17, 2013, 04:23 AM
Tomkfly is online now
Find More Posts by Tomkfly
Tomkfly's Avatar
United Kingdom, England, Birkenhead
Joined Jan 2013
These strips have buzz bar type strips running the full length and the LEDs are connected, sets of three in series, to the buzz bar. To power them up as series strips, the positive front end of each strip should be connected to the positive tail end of the previous strip. The same for the negative to negative. Connecting them as shown in the above diagram would leave the circuit open and they would not work.
Sorry brain not in gear this morning. I was thinking strips and not individual groups of three. The diagram is correct and the individual LEDs would be connected in series, but the would glow very dim on 12 volts. The strips are meant to be connected as I describe above, in order to work correctly on 12 volts.
Tom
Tomkfly is online now Find More Posts by Tomkfly
Old Jan 17, 2013, 06:12 AM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Like so...
Old Jan 17, 2013, 02:00 PM
Barn-E-Stormer is offline
Find More Posts by Barn-E-Stormer
Dark Yet??
Barn-E-Stormer's Avatar
United States, VA, Narrows
Joined Dec 2009
You can make a dimmer with a few diodes.
Barn-E-Stormer is offline Find More Posts by Barn-E-Stormer
Old Jan 27, 2013, 11:21 AM
quitcherbitchen is offline
Find More Posts by quitcherbitchen
Bombs away!!!
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
My question is on a sound module running on 2s I cannot get this thing to work. I have it wired exactly the way the wiring diagrams have, but no joy. Can anyone help? I can send a picture it that helps. Just have to take a picture.
quitcherbitchen is offline Find More Posts by quitcherbitchen
Old Jan 27, 2013, 12:26 PM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Quitcher:
I would recommend posting it over in the DIY electronics area. I realize it is not DIY, but that is where the diode heads hang out.
I would recommend posting the link to the source along with pics of the item.
http://www.rcgroups.com/diy-electronics-199/
Old Jan 27, 2013, 12:34 PM
Bombs away!!!
Joined Jul 2011
Thank you very much.
Old Jan 27, 2013, 01:37 PM
Dark Yet??
Joined Dec 2009
You need to make sure the ground on the RX switch is also tied to the battery ground.
Look at the dimmer schematic.
Old Jan 27, 2013, 01:46 PM
Bombs away!!!
Joined Jul 2011
OK, so I am using a separate battery to power the sound unit. So I need to tie into the ground of that battery for the switch to work? How do I do that? I am not using a separate UBEC. If a UBEC is the key I can add one.
Old Jan 27, 2013, 04:03 PM
Dark Yet??
Joined Dec 2009
Just use a wire to connect the ground (-) of each battery together. The RX switch needs a ground reference to operate.
Old Jan 27, 2013, 05:43 PM
Bombs away!!!
Joined Jul 2011
So the 2s battery for the sound unit will share a negative with the plane battery which is 3s?
Old Jan 28, 2013, 06:08 AM
Dark Yet??
Joined Dec 2009
Yes, the ground is a reference point. The number of cells does not matter.
Tie the two grounds together and it will work.
Old Jan 30, 2013, 10:38 PM
Bombs away!!!
Joined Jul 2011
Got it working guys. Thanks for all your help. Don't know if I saved very much weight getting rid of the servo and momentary switch by adding a UBEC and the Remote receiver switch, but the trigger on the machine gun is more precise now.
Help! 4 Channel receiver to control 3 turnigy on/off switches acuralegendz Radios 0 Apr 24, 2012 05:22 PM
Help! Turnigy Receiver Controlled Switch wriggs Power Systems 4 Mar 07, 2012 08:08 AM
Sold NIP! Turnigy Receiver Controlled on/off switch sale!!! jeff489 Aircraft - General - Radio Equipment (FS/W) 6 Dec 15, 2011 12:53 AM
Sold NIP! Turnigy Receiver Controlled on/off switch $10.00 awayne Aircraft - General - Radio Equipment (FS/W) 2 Nov 11, 2011 12:38 PM
Wanted Turnigy Receiver Controlled Switch Floater73 Aircraft - General - Radio Equipment (FS/W) 3 Oct 24, 2011 03:04 PM
