Old Apr 25, 2012, 09:40 PM
Evan03 is offline
Find More Posts by Evan03
Mtn Home, Idaho
Joined Feb 2010
what do you guys think of u can do 3d
I think I want the 60.
Evan03 is offline Find More Posts by Evan03
Old Apr 25, 2012, 09:52 PM
NEW222 is offline
Find More Posts by NEW222
Canada, MB, Oakbank
Joined Dec 2004
I think that U Can Do It!
NEW222 is offline Find More Posts by NEW222
Old Apr 26, 2012, 12:11 AM
dragonsm is offline
Find More Posts by dragonsm
United States, SD, Sioux Falls
Joined Jun 2011
I missed out on buying one with a saito 91....
I wanted it bad!
Only thing I was told by a few was to strengthen the landing gear.
Looks like a sweet plane! I still want one!!!!
dragonsm is offline Find More Posts by dragonsm
Old Apr 26, 2012, 12:44 AM
NACA0012 is offline
Find More Posts by NACA0012
Joined Mar 2012
Very capable design.
NACA0012 is offline Find More Posts by NACA0012
Old Apr 26, 2012, 07:05 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I think it is a really good design. My first impression was it is more of a pattern or aerobatic plane, But with the larger control surfaces it can do the 3D stunts including hovering too.
I plan on getting another one soon too.
earlwb is offline Find More Posts by earlwb
Old Apr 26, 2012, 08:49 PM
JeffinTD is offline
Find More Posts by JeffinTD
United States, OR, The Dalles
Joined Apr 2011
A buddy has the 60 size converted to electric. Kind of a neat plane IMHO.
JeffinTD is offline Find More Posts by JeffinTD
Old Apr 26, 2012, 10:34 PM
H&H is offline
H&H
Find More Posts by H&H
H&H
H&H Hobbies
H&H's Avatar
Old mystic CT U.S.A.
Joined Nov 2003
The model is a good flyer and nice 3d platform. Please consider my advice, If you do get oneReinforce the firewall. Seriously.
I never had problems with the landing gear area, but reinforcing the LG is never a bad idea.
Also I would recommend against mounting the engine inverted. The relationship of the tank to carb is a bad one and unless you clamp the fuel line between flights, the fuel will syphon out onto the ground and/or can fill up the cylinder with fuel causing a hydro lock.
For 3D performance a 1.2 four stroke is good.
H&H is offline Find More Posts by H&H
Old Apr 27, 2012, 07:27 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
Thanks for this post.
I have one in my shop, to repair for a friend. The firewall fell off while I was inspecting the fuselage.
Looking inside, the nose area is definately a week spot. I plan to use triangle stock on the back, and glass, on the front of the firewall. There isn't enough firewall depth, to pin it from the sides.
I'll look into the tank location, as the owner wants his Saito 91 to be mounted inverted.
The landing gear mount isn't broken, but there are cracks in the fuselage sides. I'll need to strip the covering, to see what is needed.
Thanks, again, for your post. It gives me some ideas as to what needs to be done.
TomCrump is offline Find More Posts by TomCrump
Old Apr 27, 2012, 11:04 PM
tacx is offline
Find More Posts by tacx
tacx's Avatar
United States, MI, Washington
Joined Apr 2009
One of my favorite planes. I love to fly it in the wind.
BE WARNED! It is not meant for speed. If you over power it and try to go to fast you will blow the wings off of it. Great Planes even says this in the instruction manual. It is a very light weight plane.
tacx is offline Find More Posts by tacx
Old Apr 27, 2012, 11:09 PM
JeffinTD is offline
Joined Apr 2011
Yeah, it has quite a thick wing and is meant for slow flying, as I recall.
Old Apr 27, 2012, 11:17 PM
Kyler1 is offline
Find More Posts by Kyler1
United States, SD
Joined Aug 2010
When someone says that the landing gear block needs to be strengthened that just means that they are bad at landings. LOL
Kyler1 is offline Find More Posts by Kyler1
Old Apr 28, 2012, 07:45 PM
Evan03 is offline
Mtn Home, Idaho
Joined Feb 2010
Thanks for all the replies. I'm now thinking a .46 ucando3d may fit into the hanger better
Old Apr 29, 2012, 04:11 PM
Fokker DII is offline
Find More Posts by Fokker DII
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
Sounds sooo true. I broke lots of lg blocks, but since landings have seriously improved it's been a long time since I broke one out.
Fokker DII is offline Find More Posts by Fokker DII
Old Apr 29, 2012, 06:11 PM
JeffinTD is offline
Joined Apr 2011
Something tells me you would be happier with the big one, if you can swing it.
Old Apr 29, 2012, 10:11 PM
Kyler1 is offline
United States, SD
Joined Aug 2010
Out of my 5 years of rc I have never broke a landing gear block, and I am a self taught pilot. I have never had a problem with landings, but I spent alot of time on realflight.
Discussion What do you guys think of this modification to bixler? cc151 FPV Talk 7 Mar 11, 2012 09:52 PM
For Sale What do you think i can get for this? gasman1129 Boats (FS/W) 1 Mar 05, 2012 06:04 AM
Discussion what do you guys think of this clone dynam 3D Flying 0 Feb 28, 2012 11:04 PM
Question What do you guys think of this? (FPV) Teamsherman FPV Talk 34 Sep 17, 2011 05:48 AM
Discussion What do you guys think of this? (FPV) Teamsherman Australia 1 Sep 14, 2011 05:48 AM
