Old Apr 25, 2012, 06:42 PM
pmdevlin is offline
Find More Posts by pmdevlin
pmdevlin's Avatar
Wirral, UK
Joined Jan 2007
how do you fly boys manage to get google earth tracks with gps speed points?
Hi all,
I have noticed on various posts, that when flying, and then recording with google earth, you can reproduce your path with a graph below that appears to give gps speed, and plots on the google earth map. I may be talking total rubbish here, but its exactly what I want, but, I am using a fast model boat, with v3 data logger, lcd, gps and rev counter, but really want to see my path, and the speed at given points, on a google earth map.
I have tried for so long to get this info, and am sure its user error, so would appreciate any guidance if its possible
pmdevlin is offline Find More Posts by pmdevlin
Old Apr 26, 2012, 06:17 AM
camship is offline
Find More Posts by camship
Resistance is Futile
camship's Avatar
United States, FL, Panama City Beach
Joined Oct 2001
In Google Earth right-clicking anywhere on the track and choosing Show Elevation Profile will bring up a dialog that allows you to select any two elements in the data depending on how much data is provided in the file.
Hope this helps,
Rob
camship is offline Find More Posts by camship
Old May 03, 2012, 04:11 AM
cuprum is offline
Find More Posts by cuprum
cuprum's Avatar
Joined Mar 2012
Yep. This is a good question - how much data is provided in the KML file
For me i solved the problem with a little Perl script - sorry, cause the upload limitations You can rename it to convert.pl
But, before downloading - i hope, You have a little knowledge about Perl, programming and different environments ( i use this one under CygWin, but hope, it's easy to run on every env with basic Perl)
What it does? It takes a FDR file (EagleTree saved session) as input (arg1) and a name of KML file as arg2, and parses from FDR to a KML file - simple.
What it doesn't? Multiple sessions - they are taken just as only one. If You want to view only one session, pls. save only this session with ET app
What it can do? To save ANY FDR data in KML. But, for that You must use a text editor and change the printparams hash definition.
cuprum is offline Find More Posts by cuprum
Old May 03, 2012, 06:47 AM
camship is offline
camship's Avatar
Joined Oct 2001
That's really cool but doing it on the fly in "Live Mode" is the trick.
Have a good one,
Rob
Old May 04, 2012, 12:35 AM
cuprum is offline
cuprum's Avatar
Joined Mar 2012
Hmm, do You mean "Live Mode" with or without ET soft?
The first one can only fix some silly bugs/unchanged GE formats in ET output.
Second one needs a (USB-HID) interface description. I'm not sure, i have a time to rev-eng this one.
Discussion What race track do you fly? holensum Beginner Training Area (Aircraft-Electric) 13 Apr 24, 2012 08:02 PM
Question Where do you get your trim designs and how do you test them? dedStik The Builders Workshop 16 Mar 15, 2012 03:32 PM
Discussion PH problem and google earth tracks! IconFlyer Hoverfly Technologies 10 Mar 07, 2012 02:09 PM
Help! GPS V4 Expander - how do you get UTC format when you load the data into Excel? Mikey G Eagle Tree Systems 2 Jul 13, 2010 11:12 AM
