Apr 26, 2012, 02:05 PM
United States, MD, Lusby
Joined Nov 2003
Josh,
I'm going to agree with Adam, you must test. I know on my DLG wings I use the reasonably lightest glass on the inside of the rohacell but this is to reduce weight as much as reasonably possible. I will say the layup is fairly balanced with 0.73oz glass on the inside and outside skins.
Perhaps more glass on the outside will be better, as you gain a bit more strength from laminates on the outside of the wing, but the thickness of your balsa shear web has a large say in the matter. If this is relatively thin, say 2-3mm, putting glass on the outside or inside is reasonably similar in overall structural performance. One factor that should be considered is warping, by running a highly unbalanced layup on the inside and outside of the skin, are you going to induce a twist into the wing? I don't have a good answer to that question other than I do my best to match up the glass on the inside and outside of the rohacell so I am at ease on this issue.
-Sam
