Old Apr 25, 2012, 03:39 PM
Bonestockz06 is offline
Find More Posts by Bonestockz06
Bonestockz06's Avatar
United States, FL, Orlando
Joined Sep 2011
Question
How do I get more power out of my Wing? Please read
Took the venture into the fixed wing side of the hobby. I decided to start to something scratch-built for the obvious economical and most logical rookie approach. I had few parts laying around and decided put them to good use.
I opted for a wing as it seem to be the easiest to build with the least amount of money. Using dollar tree foam it measures 28" wingspan and 17.5 at the main cord. No plans were used. I used the following for electronics:
2 DS520 helicopter tail servos
25 amp cheapo esc
ar6110 rx
TP 910mah 25c lipo
2200 kv motor with 5x5 prop
Weighs 22oz RTF
It's first time build and first time flying anything other than a Heli. Only got 3.5 minutes at WOT from the beginning. I think it has good stability but lacking power. Looking for a way to increase power without sacrificing too much flight time as it's short to begin with. Any help will be greatly appreciated.
Maiden flight vid. Best viewed in full screen. Wind 15-20mph
Mr.Blazinbones Scratchbuilt (dollar tree) Delta Wing maiden flight (5 min 54 sec)
Bonestockz06 is offline Find More Posts by Bonestockz06
Old Apr 25, 2012, 03:53 PM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
A 6 x 4 prop should give more thrust for little or no extra draw on the battery.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Apr 25, 2012, 03:59 PM
Joined Sep 2011
This is exactly why I love this place. You guys are fast and very efficient on the pockets. . Thanks JetPlaneFlyer
Old Apr 25, 2012, 05:09 PM
Pinky_d_brain is online now
Find More Posts by Pinky_d_brain
I don't do Normal
Pinky_d_brain's Avatar
Canada, NT, Yellowknife
Joined Dec 2011
looks like you have lots of power to me
Think you are lacking lift from what I can see it's just a flat plate wing.
Try taping some extra foam on your wing to create a kfm airfoil. try a kfm-2 to start then try a kfm-4
http://static.rcgroups.net/forums/at...ons%289%29.jpg
Pinky_d_brain is online now Find More Posts by Pinky_d_brain
Old Apr 25, 2012, 05:30 PM
Joined Sep 2011
Hey Pinky, this looks promising. I'm totally not familiar with the process of building those airfoils but I guess it's time for "Higher Learning". I'm going to read it carefully and build it as soon as I'm confident that I'm doing it right. In the mean time I'll change the prop as well. I think the combination of the two are going to make this baby sing very loud.. Thanks again for pointing me in the right direction.
Old Apr 25, 2012, 05:32 PM
miniprinter96 is offline
Find More Posts by miniprinter96
Psalms 23:4
Goshen, IN, USA
Joined Nov 2010
I can vouch for the KFm2. I had to carry about 4/5 throttle until I put the KF on it. Now my plane flies quite nicely at 1/2 throttle. It's a lot more stable too.
miniprinter96 is offline Find More Posts by miniprinter96
Old Apr 25, 2012, 05:39 PM
Joined Sep 2011
I was reading the Kfm2 illustration. I'm confused as to what does the thinckness percentage represents, can anyone elaborate what that number means?
Also, it says "Step at 50% of the cord". Does that mean the added foam will cover half of the wing from the front tip to the middle of the Chord? In my case the Chord is 17", so foam will have to cover half of that?
Sorry for the questions guys, This is truly my first time and I may have bit more than I can chew. Hoping you guys will have the patience.
Old Apr 25, 2012, 05:47 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Just add a 'top' surface to your wing in a passable imitation of a looks sorta like a Clark Y airfoil.. fairly easy and Far more effective (much more lift , far less drag) than a KFM bodge.
Bare is offline Find More Posts by Bare
Old Apr 25, 2012, 05:56 PM
Joined Sep 2011
Now this is something I can do, ..
Old Apr 26, 2012, 10:41 AM
I don't do Normal
Joined Dec 2011
either way think you need lift
kfm info
http://www.rcgroups.com/forums/showthread.php?t=1296458
http://www.rcgroups.com/forums/showthread.php?t=1117276
Wing build you can check out for some ideas
http://www.rcgroups.com/forums/showthread.php?t=1619684
Old Apr 26, 2012, 06:19 PM
63 nova is offline
Find More Posts by 63 nova
63 nova's Avatar
Lakewood, Colorado
Joined Apr 2009
You can check out my thread here and start from post 10 for my version 2 wing it has about 35 dollars into it and flies nice I have the same a 2200 kv motor and 5x5 apc prop and 1300 mah 3 cell battery and it is putting out like 250 watts it has plenty of power and around 6 min. flight times and it has the kfm2 airfoil.http://www.rcgroups.com/forums/showthread.php?t=1613073
63 nova is offline Find More Posts by 63 nova
Old Apr 27, 2012, 11:31 AM
Joined Sep 2011
I added the kfm-2 and gained one full minute of flight time but didn't notice any increase in power. Going with the bigger prop and 1300mah lipo and see what that does. I think I made it too heavy but I'm already working on a second one which will be less than half it's weight with the kfm2 airfoil. Hopefully it will turnout good. Thanks again
I've checked out your thread but see no plans or dimensions for th V2 after post #10. It seems to have a steeper sweep than the original version. Seems sweet but I can't really do much without the dimensions. Thanks
Discussion One more bug to iron out on my wing badlands Flying Wings 0 Feb 22, 2012 12:07 PM
Discussion Internal pushrods - How do you get them in and out? Fly2High Hand Launch 10 Feb 14, 2012 06:18 AM
Discussion How do ya'll get planes out of trees . . . PyroMan Electric Plane Talk 73 Feb 03, 2012 01:15 PM
Discussion How do you get small dents out of Multiplex foam? eng30 Foamies (Kits) 2 Nov 30, 2011 07:00 AM
Discussion How do i get more response out of my stock cx2? thumpingbeetle Coaxial Helicopters 8 May 05, 2008 10:35 PM
