Old May 02, 2012, 12:28 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
Originally Posted by ch701 View Post
But you can easily reverse the charging jack polarity and then magic smoke will appear instantly. Had a friend do it. Cooked the radio. Would not have happened it one had to remove battery for charging.
-john
the charging jack polarity?... unsure how you can reverse the polarity of the typical charging jack, but this transmitter wont have a charging jack installed at all. you have to remove the pack to charge it. Will have to apply some pretty cunning tricks in order to feed your transmitter reverse polarity current...
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old May 02, 2012, 01:34 PM
hawkz is offline
Find More Posts by hawkz
USA, CA, San Diego
Well...the multi-adapters have a plug for futaba, jr, hitec, etc. If you put use the wrong plug and the budget battery charger (not talking about OEM wall adapters) doesn't have some kind of reverse polarity detection...magic smoke?
hawkz is offline Find More Posts by hawkz
Old May 02, 2012, 03:41 PM
JimDrew is online now
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
There is no charge jack in the transmitter. The battery must be removed to charge it. If you charge that battery backwards outside of the transmitter then nothing will happen to the transmitter - unless there was a fire that burned down your house (including the transmitter).
JimDrew is online now Find More Posts by JimDrew
Old May 02, 2012, 04:50 PM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
...Tx will have the new official testing logo of "combustion outside" logo on it next to the FCC stamp...
Old May 02, 2012, 05:30 PM
E_ferret is offline
Find More Posts by E_ferret
E_ferret's Avatar
Launceston Arpt, Tasmania, Australia
Joined Jan 2004
Originally Posted by jgunpilot View Post
But it has to be a perfect battery, just like the one the smart guy in the club told me about...
"perfect battery" = absolute zero internal resistance = unlimited charging current = unlimited storage capability = short-circuit at your own risk
E_ferret is offline Find More Posts by E_ferret
Old May 02, 2012, 10:52 PM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
Originally Posted by JimDrew View Post
The voltage regulation system with soft on/off already has this protection built in. You can attach the battery backwards and nothing happens.
Good to have this safety feature. Perhaps not as good as what I mentioned, if it's only reverse polarity protection, but good enough.
chewy
chewytm is offline Find More Posts by chewytm
Old May 03, 2012, 01:07 AM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
But still not answered; is it switch mode and can take advantage of additional pack voltage?
Fred
flarssen is online now Find More Posts by flarssen
Old May 03, 2012, 02:23 AM
marhar is offline
Find More Posts by marhar
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
Originally Posted by CiprianGugu View Post
Jim, but if you attach the battery backwards the radio will not work, correct? But the radio will not fry.
It becomes a big receiver!
marhar is offline Find More Posts by marhar
Old May 03, 2012, 09:56 AM
Lake Havasu, AZ
Joined Jun 2005
Fred
The regulation system is not a switching type. There is nothing to take advantage of in this case.
Old May 03, 2012, 10:53 AM
Tony37803 is offline
Find More Posts by Tony37803
Tony37803's Avatar
United States, TN, Maryville
Joined Jun 2011
Jim, could you revisit a few things for me? The transmitter to transmitter communication, other than wireless buddy boxing, what other applications are there? And programming from a PC, that's possible, wireless too? Is there a PC interface device required? What all can be done from a computer? Is this the same device used to configure receivers?
Tony37803 is offline Find More Posts by Tony37803
Old May 03, 2012, 10:55 AM
hebertjj is offline
Find More Posts by hebertjj
United States, TN, Knoxville
Joined Jan 2001
Well, I've been lurking on this thread since it started and gone thru all the previous XPS Tx thread and I'm finally ready to post.
1st, as a member of the human race I'd like to apologise to JIm for all the knuckleheads who keep pestering him with various versions of "is it here yet?" I think the next person that pulls that ought to be required to wash your car or mow your lawn before receiving anything from XPS again.
2nd, I LOL at Tony's suggestion of just requiring 4 AA. That would shut up the all the people worrying about what kind of battery to get. Good grief !!! Even 4 AA's would get you 20 hrs of operation; with auto shut down that ought to get me thru the summer. ( I'm still probably going with a cheap LiFe or LiPo pack.)
3rd, What does "16X over sampling" mean? Is the ADC sampling at 16x200hz or 3200hz (5 ms frame is 200hz, right?) ?
4th, What's the latest version to the TX box look like? Is it still the same as shown in the old thread?
5th, What's the 900mhz version about? If you're not supporting FPV, doesn't 2.4 ghz have more than enough range.
Thanks Jim
hebertjj is offline Find More Posts by hebertjj
Old May 03, 2012, 11:26 AM
Son, Norway
Joined Sep 2004
For a switch mode regulator, Pin = Pout (100% efficiency for simplicity). With 5V output, current drawn from a 3S pack would be less than 50%, compared to using a linear regulator. If it's linear, it's better to use the space/weight for capacity and not higher cell count, as higher voltage only means more heat generated. Must be quite a lot if using 24V(max).
Fred
Old May 03, 2012, 01:31 PM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
Originally Posted by hook57 View Post
["I decided it was not a safe place to sit.
If something does happen you can be sure it wont be long before the FAA steps in and creates some restrictions."
Not arguing your point, but I seriously doubt the FAA will be getting involved in something that is intended for sport/recreation use. Being responsible and being safe is being defensive (as in looking out for one's self) as you did in that situation. Not saying that the CD or sponsor shouldn't look at spectator safety, just saying....
hook
Think again. They are already up our skirt. The RC hobby just narrowly escaped the imposition of significantly more restrictive FAA rulemaking through an act of Congress. We got lucky this time. We may not get so lucky next time, and as alluded to by others, the hobby only needs a couple of fatality incidents in the current climate to wind up TOTALLY regulated, as in - we're all flying foamies. So agree with the point made that the hobby must demand the absolute highest standards when it comes to RF equipment. Much of the current radio stuff just does not meet that standard.
As the KM indicates, Jim and XPS appear to be committed to the highest robustness standard, I certainly do not expect XPS to incur significant additional expense while competitors like Hitec and HH don't bother, but there is definitely a case to be made that the RC stuff is no less dangerous than other UAV equipment and should be subject to the same tesing standard.
Better we pre-empt as a hobby than screw up, thus giving the feds an opening...
TTRotary is offline Find More Posts by TTRotary
Old May 03, 2012, 02:00 PM
j_whitney is offline
Find More Posts by j_whitney
j_whitney's Avatar
United States, CA, Castro Valley
Joined Dec 2005
Originally Posted by dirtybird View Post
I was sitting in a stands at a jet rally in Phoenix watching the jets turn toward the runway. When they did this they had us in their aiming point for a large part of the turn on the final. All it would take is a short lapse of control for the jet to plow into the stands. I decided it was not a safe place to sit.
Is there really ANY safe place? At some point all airplanes are going to have to turn towards the stands/spectators for at least the landing approach. I don't think anyone except maybe IMAC/Pattern pilots want to make an approach out of a cuban, split s or stall turn.
j_whitney is offline Find More Posts by j_whitney
Old May 03, 2012, 04:50 PM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
I don't think 4 AA (rechargeable) will do the job, I seem to remember that the display needs 5 volts so it would require 5 cells (rechargeable) or a boost regulator (or different display). That said my memory could be wrong and Jim changed to a lower voltage display.
village_idiot is offline Find More Posts by village_idiot
Sold XPS 2.4GHz JR Transmitter Module (9x) az_heliguy Aircraft - General - Radio Equipment (FS/W) 19 Apr 04, 2012 11:07 PM
For Sale Hacker / Spin 170 Controller, XPS Pro Dynamax, 15S 6800 XPS packs in 3S bricks. penceaviation Aircraft - Electric - Jets (FS/W) 9 Oct 13, 2011 07:55 AM
Wanted XPS 6800mah 65c 6s want to trade for xps 5000mah 65c and will pay difference sherlockshah Aircraft - Electric - Batteries & Chargers (FS/W) 3 Oct 12, 2011 08:30 AM
For Sale 3s xps 5000mah 65c $60 shipped with warranty also 2s xps 5000mah 65c $45 shipped with sherlockshah Aircraft - Electric - Batteries & Chargers (FS/W) 2 Sep 24, 2011 12:48 PM
Sold TransMitt transmitter bag / warmer**price drop** aerosheldon Aircraft - General - Radio Equipment (FS/W) 5 Mar 31, 2011 12:40 PM
