Old May 01, 2012, 05:45 PM
E_ferret is offline
Find More Posts by E_ferret
E_ferret's Avatar
Launceston Arpt, Tasmania, Australia
Joined Jan 2004
Originally Posted by SIRCOL View Post
2 life cells 18mmx65 mm side by side will fit in the place of a 8 cell nicad pack
(4x4x2 ) thats what in the JR XG11 you fit them on the diagonal
note that the ZIPPY 1800 LIFE tx battery sold by Hobby King is just a tad too wide to fit in an old JR 388S. rotating the pack does not help, then it is too high to fit.
E_ferret is offline Find More Posts by E_ferret
Old May 01, 2012, 06:26 PM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Originally Posted by dirtybird View Post
This equipment will be used to control large scale gas airplanes and jet aircraft capable of 200+mph. This is flight critical software, as much so as the software used in the aerospace industry. It should be tested and certified as per the guidelines of DO-178-B.
Can you provide some evidence that any other manufacturer of radios does this?
Pat MacKenzie
pmackenzie is online now Find More Posts by pmackenzie
Old May 01, 2012, 08:51 PM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
Good point. A 28x28 square has a 39mm diagonal so I can see how that would work. Thank you for pointing that out.
I added a correction to my earlier post.
kgfly is offline Find More Posts by kgfly
Old May 01, 2012, 09:05 PM
DaOldGuy is online now
Find More Posts by DaOldGuy
Flying Half Pound and Down
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
Pat MacKenzie
I personally like this part of the doc and find that it sums up the value of the testing that pertains to the risk being managed.
Consider two aircraft examples
– 1) Software controlling the coffeemakers in the aft galley fails
• Outcome: Likely some grumpy customers, but passenger safety not
compromised (air rage issues due to lack of coffee aside)
– 2) Software controlling the aircraft during an automatic landing in zero
visibility conditions fails
• Outcome: Possibly catastrophic and lives lost
DaOldGuy is online now Find More Posts by DaOldGuy
Old May 01, 2012, 10:41 PM
dirtybird is online now
Find More Posts by dirtybird
United States, AZ, Queen Creek
Joined Aug 2004
Pat MacKenzie
Probably not but they should.There are requirements for the hardware that must be met and they do. Its time to control the software. The software controls the hardware.
I would think they would want to do this in order to protect themselves in case something serious happens.
I was sitting in a stands at a jet rally in Phoenix watching the jets turn toward the runway. When they did this they had us in their aiming point for a large part of the turn on the final. All it would take is a short lapse of control for the jet to plow into the stands. I decided it was not a safe place to sit.
If something does happen you can be sure it wont be long before the FAA steps in and creates some restrictions.
dirtybird is online now Find More Posts by dirtybird
Old May 02, 2012, 12:27 AM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
...you should take a moment to read the other threads about how seriously Jim regards safety through reliability of products. Not just this industry but others as well...
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old May 02, 2012, 12:51 AM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
Jim,
How about adding a rectifier bridge for the batts input to make the polarity of the battery connector a non-issue, like the new Spektrum DX7s? Probably won't cost much, and would get rid of ALL battery polarity problems/worries when plugging in the tx battery.
chewy
chewytm is offline Find More Posts by chewytm
Old May 02, 2012, 01:40 AM
Hance is offline
Find More Posts by Hance
Expo is built into my thumbs
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
Originally Posted by JimDrew View Post
No battery is included. The input connection is a red two pin JST plug (common for small Lipos). The battery compartment is designed the traditional 8 AA type drycell batteries or Nicd/Nimh battery pack. Typical current draw ranges between 60mA and 90mA (full power), depending on the frame rate. So, a 2200mAh 2S Lipo is lasting about 24 hours of continuous on time. Obviously, we don't fly that way and since it has auto-power off, it won't let itself be left on by accident. So, the battery will last a long time.
I think all you guys worried about the battery need to step back and contemplate Jim's post. All but the most hardcore users will be able to go for weeks with out having to charge the transmitter. Most people I see flying don't do more than a dozen flights in a day. A dozen ten minute flights is two hours of run time per flying day. With about 24 hours of runtime out of a 2200mah pack that's a dozen flying days between charges.
Just grab a battery that will fit in the transmitter and don't worry about it. If you are really that concerned get a spare battery THEY ARE CHEAP.
Hance is offline Find More Posts by Hance
Old May 02, 2012, 06:58 AM
hook57 is offline
Find More Posts by hook57
hook57's Avatar
United States, IL, North Aurora
Joined Sep 2009
["I decided it was not a safe place to sit.
If something does happen you can be sure it wont be long before the FAA steps in and creates some restrictions."
Not arguing your point, but I seriously doubt the FAA will be getting involved in something that is intended for sport/recreation use. Being responsible and being safe is being defensive (as in looking out for one's self) as you did in that situation. Not saying that the CD or sponsor shouldn't look at spectator safety, just saying....
hook
hook57 is offline Find More Posts by hook57
Old May 02, 2012, 08:48 AM
jgunpilot is offline
Find More Posts by jgunpilot
Joined Jun 2005
But it has to be a perfect battery, just like the one the smart guy in the club told me about...
jgunpilot is offline Find More Posts by jgunpilot
Old May 02, 2012, 10:38 AM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Originally Posted by chewytm View Post
Jim,
chewy
The voltage regulation system with soft on/off already has this protection built in. You can attach the battery backwards and nothing happens.
JimDrew is offline Find More Posts by JimDrew
Old May 02, 2012, 10:46 AM
CiprianGugu is online now
Find More Posts by CiprianGugu
Look Up
CiprianGugu's Avatar
United States, TN, Jamestown
Joined Nov 2003
Jim, but if you attach the battery backwards the radio will not work, correct? But the radio will not fry.
CiprianGugu is online now Find More Posts by CiprianGugu
Old May 02, 2012, 11:46 AM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
...I can't say I've ever managed to connect a red JST connector backwards, you would have to reshape the male plug to do it. the plug in the Aurora 9, you have to get at it from an angle, there's no shroud around the receiving female, and you can indeed get that to connect up incorrectly... and it doesn't like it, magic smoke will happen. having the radio do nothing instead is perfect.
Old May 02, 2012, 11:56 AM
ch701 is online now
Find More Posts by ch701
Aeronca Driver
ch701's Avatar
USA, CA, Westlake Village
Joined Jul 2006
But you can easily reverse the charging jack polarity and then magic smoke will appear instantly. Had a friend do it. Cooked the radio. Would not have happened it one had to remove battery for charging.
-john
ch701 is online now Find More Posts by ch701
Old May 02, 2012, 12:10 PM
Tony37803 is offline
Find More Posts by Tony37803
Tony37803's Avatar
United States, TN, Maryville
Joined Jun 2011
Battery battery battery. Sheesh, enough already. Ask about the cool stuff!
Jim, use 4 AA's next time.
Tony37803 is offline Find More Posts by Tony37803
Sold XPS 2.4GHz JR Transmitter Module (9x) az_heliguy Aircraft - General - Radio Equipment (FS/W) 19 Apr 04, 2012 11:07 PM
For Sale Hacker / Spin 170 Controller, XPS Pro Dynamax, 15S 6800 XPS packs in 3S bricks. penceaviation Aircraft - Electric - Jets (FS/W) 9 Oct 13, 2011 07:55 AM
Wanted XPS 6800mah 65c 6s want to trade for xps 5000mah 65c and will pay difference sherlockshah Aircraft - Electric - Batteries & Chargers (FS/W) 3 Oct 12, 2011 08:30 AM
For Sale 3s xps 5000mah 65c $60 shipped with warranty also 2s xps 5000mah 65c $45 shipped with sherlockshah Aircraft - Electric - Batteries & Chargers (FS/W) 2 Sep 24, 2011 12:48 PM
Sold TransMitt transmitter bag / warmer**price drop** aerosheldon Aircraft - General - Radio Equipment (FS/W) 5 Mar 31, 2011 12:40 PM
