Old Apr 30, 2012, 05:44 PM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
Wishlist:
If there is still design flexibility, please set it up so LiFe packas can be used. I do not and will NEVER use a Lipo in a TX. Way too dangerous.
Also, can you please release your new Rxs and not wait for the Tx to be released.
TTRotary is offline Find More Posts by TTRotary
Old Apr 30, 2012, 06:26 PM
j_whitney is offline
Find More Posts by j_whitney
j_whitney's Avatar
United States, CA, Castro Valley
Joined Dec 2005
Jim has stated several times that there will be no charge jack; you will have to take the pack out of the Tx to charge.
j_whitney is offline Find More Posts by j_whitney
Old Apr 30, 2012, 06:44 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
Originally Posted by TTRotary View Post
Wishlist:
from the very first post in the thread...
"Power requirements: 6v-24v (Lipo, LiFe, Nicd, Nimh compatible)"
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Apr 30, 2012, 07:08 PM
TTRotary is offline
Joined Mar 2010
Yes but he states earlier no A123 will fit. Hopefully it can be set-up so the LiFe packs like the Hyperions or Hobbykings can fit.
Mostly (please please please Jim), give us the new 9-ch RX soon. Got some bigger birds running LiFe Rx packs and it would be nice to have pack voltage telemetry showing up on the A9.
Old Apr 30, 2012, 07:18 PM
RICHARD3851 is online now
Find More Posts by RICHARD3851
Joined Jan 2005
Do I understand correctly, that gear door sequencing capability, will be built in to the transmitter, and no extra sequencer hardware will be required on the plane?
Richard Browning
RICHARD3851 is online now Find More Posts by RICHARD3851
Old Apr 30, 2012, 07:33 PM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
There are rechargeable AA size lithium cells, so you should be able to build a 2S2P pack and have room to spare.
village_idiot is offline Find More Posts by village_idiot
Old Apr 30, 2012, 07:39 PM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
The Tx uses a standard off-the-shelf case designed for the standard 8-cell NiXx brick (typically 95mm x 28mm x 28mm) so you can use any (6v-24v) battery at all that you find or assemble that will fit inside that profile.
A123 cells are either 26650 (26mm diameter, 65mm long) or 18650 (18mm diameter, 65mm long). Those dimensions are not compatible with the available space so unless you hack the case, a 2S A123 setup won't fit.
On the other hand, the Hyperion and HK LiFe Tx packs are specifically designed to replace standard 8-cell Tx packs and so are very likely to fit.
HP-FG305-2100-3S = 95.0 x 30.3 x 27.1mm
Zippy LiFe (3S, 9.9V, 1800mAh) = 100 x 27 x 33mm
Correction
A 28 x 28 square has a 39mm diagonal. It was pointed out to me that in fact a side-by-side 2S 18650 LiFe pack does indeed fit, it just sits on the diagonal. So you can use a 2S A123 setup if you are happy with a 1000mAh solution.
kgfly is offline Find More Posts by kgfly
Old Apr 30, 2012, 08:39 PM
Hance is offline
Find More Posts by Hance
Expo is built into my thumbs
Hance's Avatar
USA, ID, Niter
Joined Jul 2008
I might have to grab one of these for a second radio. I am almost out of model memory on my 9503. Yes I have 40+ flying models.
Hance is offline Find More Posts by Hance
Old Apr 30, 2012, 09:35 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
kgfly is correct on the dimensions and compatibility.
Yes, the transmitter will be able to control multiple servos in sequences. So, with enough receiver channels (2-4) you could have gear door sequencing done, including split gear doors that return up after the gear goes down.
JimDrew is offline Find More Posts by JimDrew
Old May 01, 2012, 11:10 AM
Inciting Riots
Joined Dec 2006
This will probably cause major concern... Is there room for an 8AA battery holder? There are also some expensive Bulgin AA and AAA holders that are 6 cells in a triangle that might be better. I'm guessing that a 600 to 800mah pack will last for more than 2 hours.
Old May 01, 2012, 12:32 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
The slot is for a standard 8AA Nicd/Nimh pack, configured as 4 cells (2x2) x 2, stacked. So, a traditional pack found in just about every transmiter made.
Old May 01, 2012, 12:39 PM
GorillaBob is offline
Find More Posts by GorillaBob
Re-Kitting Expert :o
Bullhead City, Arizona
Joined Jan 2005
Like This:
GorillaBob is offline Find More Posts by GorillaBob
Old May 01, 2012, 03:39 PM
dirtybird is offline
Find More Posts by dirtybird
United States, AZ, Queen Creek
Joined Aug 2004
Originally Posted by theKM View Post
not really... software is soft and squishy... hardware needs to be built, so while it's being built, may as well keep playing with the squishy parts.
Jim has very high standards for the radio quality simply due to safety... I think we should just let him run his own project, when it's ready it'll be tested and ready.
This equipment will be used to control large scale gas airplanes and jet aircraft capable of 200+mph. This is flight critical software, as much so as the software used in the aerospace industry. It should be tested and certified as per the guidelines of DO-178-B.
dirtybird is offline Find More Posts by dirtybird
Old May 01, 2012, 03:45 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Yes, Bob - like that!
The RF portion of the flight control firmware has not changed since 2005, and I don't expect it to ever change. Since the transmitter input is all new, that does need to meet certain regulations for UAV use.
Old May 01, 2012, 04:59 PM
SIRCOL is offline
Find More Posts by SIRCOL
Old and grumpy
SIRCOL's Avatar
Australia, QLD, Gold Coast
Joined Aug 2010
2 life cells 18mmx65 mm side by side will fit in the place of a 8 cell nicad pack
(4x4x2 ) thats what in the JR XG11 you fit them on the diagonal
SIRCOL is offline Find More Posts by SIRCOL
Sold XPS 2.4GHz JR Transmitter Module (9x) az_heliguy Aircraft - General - Radio Equipment (FS/W) 19 Apr 04, 2012 11:07 PM
For Sale Hacker / Spin 170 Controller, XPS Pro Dynamax, 15S 6800 XPS packs in 3S bricks. penceaviation Aircraft - Electric - Jets (FS/W) 9 Oct 13, 2011 07:55 AM
Wanted XPS 6800mah 65c 6s want to trade for xps 5000mah 65c and will pay difference sherlockshah Aircraft - Electric - Batteries & Chargers (FS/W) 3 Oct 12, 2011 08:30 AM
For Sale 3s xps 5000mah 65c $60 shipped with warranty also 2s xps 5000mah 65c $45 shipped with sherlockshah Aircraft - Electric - Batteries & Chargers (FS/W) 2 Sep 24, 2011 12:48 PM
Sold TransMitt transmitter bag / warmer**price drop** aerosheldon Aircraft - General - Radio Equipment (FS/W) 5 Mar 31, 2011 12:40 PM
