Jim,have you seen the new A9? Looks like module is on the inside now. Do you have a swap over kit for those yet or had time to look at them?
Latest blog entry: Lil repair work.
The Villages, Florida
Joined May 2003
Anyway, thanx for answering the question..... It was not clear (at least to me) till now...... |
![]() But nothin wrong with the optima rx's,just i could tell the difference in latency when i tested out the xps module and nano's. I had a plate of crow that day because I had always said that the latency was bologna. But side by side comparison on the same plane told the truth. |
Lake Havasu, AZ
Joined Jun 2005
Well, obviously the module is NOT the only source of the latency, or our system would be even faster - remember, our A9 upgrade is a module.
7ms is good, but that is fully saturating the bandwidth for their system. I don't think any manufacturer cares about that, but I can tell you that this was the AMA's biggest concern back in 2007 when I demo'd our system to them. If you have a bunch of devices turned on that leave absolutely no 'space' between transmissions then at some point you are going to have collisions. With a very narrow band system using the CC2500 and simliar chipsets (Hitec/Futaba/Hott/FrSky/etc.) you can easily lose data when other systems are also being used. Using a wide band transmission system is virtually immune to interference from other signals. This is the advantage that JR has been touting in their new DMSS system - which is the exact same system that we have been using for over 6 years. |
Lake Havasu, AZ
Joined Jun 2005
Spektrum uses a narrow band (1MHz) tranmission. Hitec, Hott, FrSky, etc. all use an even narrower band transmission.
XtremeLink, JETI Duplex, and now JR DMSS all use 802.15.4 protocol. This has a 2.45MHz to 3.2MHz bandwidth, depending on the exact frequency. Because the bandwidth is wider it greatly increases the speed of which the entire packet can be sent, and also rejects spurious emissions and other valid signals. |
I decided not to challenge them on the full source of the latency, your upgrade makes a noticable difference and when not using the timer the system seems slightly faster. Although their 9x is on par with the other companies tx's now, they still are not very smart and I think they missed the mark again with the 9x
| Thread Tools | |
| Sold XPS 2.4GHz JR Transmitter Module (9x) | az_heliguy | Aircraft - General - Radio Equipment (FS/W) | 19 | Apr 04, 2012 11:07 PM |
| For Sale Hacker / Spin 170 Controller, XPS Pro Dynamax, 15S 6800 XPS packs in 3S bricks. | penceaviation | Aircraft - Electric - Jets (FS/W) | 9 | Oct 13, 2011 07:55 AM |
| Wanted XPS 6800mah 65c 6s want to trade for xps 5000mah 65c and will pay difference | sherlockshah | Aircraft - Electric - Batteries & Chargers (FS/W) | 3 | Oct 12, 2011 08:30 AM |
| For Sale 3s xps 5000mah 65c $60 shipped with warranty also 2s xps 5000mah 65c $45 shipped with | sherlockshah | Aircraft - Electric - Batteries & Chargers (FS/W) | 2 | Sep 24, 2011 12:48 PM |
| Sold TransMitt transmitter bag / warmer**price drop** | aerosheldon | Aircraft - General - Radio Equipment (FS/W) | 5 | Mar 31, 2011 12:40 PM |
